Question about ASUS Computers & Internet
When I turn on the laptop, the asus screen comes up and it seems to be booting but after a long while shows an error and restsrts never actually booting up
    Habit-Forming:
    Scholar:
  • 74 Answers
While it starts to boot up, press the ESC key, or appropriate key that allows you to enter into setup. From the setup area, look for an option to boot into safe mode or into a Command Prompt. Once in safe mode, if it works, press start, and go to run and enter CMD. In this window type in bootrec /fixmbr and press enter. Next type in bootrec /fixboot and press enter. Restart your computer normally.
If you can start in the command prompt, enter in the same commands.
Also if you have a windows recovery or windows installation disk you can access the command prompt as well as fix any issues that are cauing your machine to not boot.
Here is a step by step guide on how to solve such problems.
How to Manually Repair Windows 7 Boot Loader Problems
Posted on Apr 28, 2015
5 Suggested Answers
  • 700 Answers
SOURCE: It suddenly will not boot up. WHen we turn it on, it shows the Asus load screen, and then goes to a "Windows Error Recovery" screen, asking us to start in a number of "safe modes"
Try all, if this not go into its expected boot up. Your options are repair, restore to factory, reinstalled depends on the features of recovery of your unit.
Back up your important files, drivers if needed, installation code if needed first before performing said solution
Posted on May 09, 2009
benwabnick
  • 2404 Answers
SOURCE: comes on but screen is black....doesn't want to boot up
Take out the battery and only plug in the AC adaptor.
If that doesn't work, then reseat each memory stick one at a time in each slot one at a time checking each time for video.
If that doesn't work, then take out the dvd drive, also take out the hard drive to make sure neither of those are shoring out the motherboard.
Also see if the hard drive light is flickering away at all. If it is then reseat the lcd cable to the motherboard and possibly reseat the cable to the lcd itself.
If none of this works, then the motherboard is bad and would either need to be repaired or replaced.
Your laptop is probably under warranty and you can verify it thru HP's website.
If you need more help let me know.
Ben
Posted on May 21, 2009
RescueTechLA
  • 2653 Answers
SOURCE: my asus laptop will turn on but not boot up, the
Have you tried connecting the laptop to an external monitor and starting the computer up?
Posted on Nov 29, 2009
  • 261 Answers
SOURCE: my asus disney laptop stopped
HI disconnect the adapter and battery wait then connect adapter and check it out if problem exist check the RAM is it ok or not? (replace then change) otherwise graphic chip(GPU BGA) need an expert to repair
Posted on Oct 21, 2010
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
Screen won't come on my asus laptop.
Laptop screen won't turn on, but works with external monitor ...
www.tomsguide.com/.../laptop-screen-turn-works-external-monitor.html
Oct 16, 2015 - Hello, my laptop screen won't display anything. It boots up and ... External Monitor; Function Keys; Laptop Screen; Windows 8; Asus. Display.
ASUS laptop screen won't display anything - Tom's Guide
www.tomsguide.com/answers/id.../asus-laptop-screen-display.html
Aug 28, 2013 - My laptop screen won't display anything Forum; Asus n56vz laptopwont ... i cant remove the asus battery to my laptop and the screen wont turn ...
Asus laptop black screen problem - YouTube
? 7:52
https://www.youtube.com/watch?v=gRQgN5AT3a0
Aug 2, 2011 - Uploaded by mrwangyanfei
Black screen when switch on Asus laptop (N61J) ... I turn on mypc and the screen stays black. I tried ...
Dec 13, 2015 | ASUS Computers & Internet
I have Acer 4710 laptop. 1. The screen becomes white during start up or when computer is left without usage for some time. 2. Also, sometimes, split screen come suring startup itself and booting...
It maybe one of three things:
1) Bad windows installation. IF you ONLY see this problem during the time you work with windows and NEVER during bios boot up process it could be your Windows installation but I doubt it. It is most likely a hardware problem:
2 a) The hinges of your laptop are becoming bad and there is a short in the wires that carry the video signal up to the screen
2 b) the video card of your laptop is failing.
Jul 05, 2011 | Computers & Internet
The laptop just wont come on, it briefly shows a bit of writing on the top left-hand corner- too quick to read.???
Possible failure of the memory as the screen does not boot on. Please check the bios battery as this can also cause the PC from booting up. Look under the notebook for the small button cell- 3 V.
If not the fault is the memory or the errors in main board.
Mar 28, 2011 | ASUS Eee 4G Notebook
Ihave ASUS M2N68-AMSE2 nmotherboard- on starting up, my computer shows ASUS green screen for ages and nothing happens, I press reststart, motherboard boots up and starts windows
hardware related issue, check your bios settings to see if halt on errors in enabled, also disable
the ASUS splash screen, you should be able to see the initial boot error..
Feb 19, 2011 | ASUS M2N68-AM SE2 Motherboard
No video, no boot. continually cycles trying to boot
Well, if you've already checked all the necessary hardware and they all check out, it seems the only problem is the motherboard.
Actually, the more recent DV#### models from HP have had hardware defects, and they have offered to repair these computers if they show any symptoms of defect.
The chipset product line coming from ASUS was faulty, and have caused hardware failures such as this.
Call customer support for HP and have them schedule a repair for your laptop. They should repair it free of charge, whether the warranty expires or not.
Hope that helps.
Jan 14, 2010 | HP Pavilion dv9000z Notebook
Problem with my ASUS W3J also with BIOS.
Sounds like your hard drive is toast. Replace your hard drive and try again. If it continues, it may be time to replace your laptop.
Also check your recovery disks for heavy or concentrate scratches.
Nov 25, 2009 | ASUS W3J PC Notebook
Eee pc 701 doesnt turn on
Make sure no external devices are plugged in.
If it's still under warranty you will have to return it.
Or take to an Asus support center as it seems to be a hardware problem.
Jul 13, 2009 | ASUS Eee PC 701 Notebook
May 09, 2009 | Computers & Internet
Chassis Intruded, Fatal Error...System Halted
you need to go into the bios of your pc.....usually pressing the delete key when you see the first logo screen after booting up....look for a section that relates to errors and what the bios is supposed to do when it encounters an error.
i.e if you see a line in the bios that says "halt on all errors" disable it and when you next boot up the bios will not stall.
Mar 20, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Computers & Internet Logo
64 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
