Question about Sony Televison & Video
All of a sudden we have margins on our Sony Bravia 2013 which we have never had before. If I change the settings the channel logos are cut off.
I bought a sony bravia from amazon in 2009 in the last few weeks when i go on channel selection it sometimes cuts out if i try and scroll through channels it wont scoll or takes ages and then cuts out
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Sep 30, 2014 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
How to change channel from one to any one channel in sony bravia
I need more info. Are you using antenna connected to RF input or are you using cable box, sat box or ATT Uverse? If connected to antenna . go in menu or Home on Sony. Press setup and look for channel scan. Set to antenna and do auto scan. If cable or other provider box set tv to ch 3 or what ever provider says. You are then using the tuner in that box. You will use providers remote to change channels. Be sure in setup that tv is set to cable if cable box is used. Hope this helps but the info you posted could be more descriptive.
Oct 02, 2013 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony bravia v series 32"
hi,
IT normally happens after factory reset is done. You need to reprogram the channels. Try the auto program (AUTO TUNING) Process.
  1. On your remote commander " Press HOME or MENU button"
  2. Scroll down to " SETTINGS or SET-UP"
  3. Then to "CHANNEL SET-UP"
  4. Select " AUTO PROGRAM " To Auto program your LCD TV and it's done..
Jan 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Hi. Sunday evening the picture on my Sony Bravia suddenly went very red and there are blurry lines after action. Type can hardly be read, even the TV menus are hard to read. The next day, hoping...
Hi. Sunday evening the picture on my Sony Bravia suddenly went very red and there are blurry lines after action. TypeHi. Sunday evening the picture on my Sony Bravia suddenly went very red
Aug 03, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Sep 07, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
We lose audio on our Sony BRAVIA KDL-52W4100
This problem appears to be an issue with numerous Sony Bravia owners of the same model. Although still seeking a soulution, it would appear that our cable provider (Verizon) has replaced all of their components and the Geek Squad from Best Buy where we purchased the unit, points the finger at Verizon. None of our other Fios-equipped TV's exhibit this problem so I am glad we bought the service plan with the TV and will continue to seek a remedy.
Mar 04, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My Sony KDL40XBR4 Bravia TV sounds keeps cutting in and out
I'll buy your broken tv from you. I need some part to fix my own tv. Thanks. email me at lbarzola at gmail . com. Remove the spaces and change the at for an @. Thanks.
Feb 04, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I have a Sony Bravia, KLD-40S4100, Serial # 1041915. When I am watching my TV (I have digital cable, if that means anything), the picture does not always fit the screen, (i.e., sometimes the channel logo...
Different channels have different aspect ratios on digital cable. Go in your book that came with set and find changing aspect ratio...or call 4.3 16.9....or zoom.....full....streach...etc. Also look on your remote control. There may be a button to change that also. Simple problem. The hardest thing with these new sets is learning how to operate them properly. Read your book. Put it in the bathroom. You'll have alot of time to learn about your set if you do that..I'm serious. This new stuff has so many things it can do, it's crazy!! And you thought setting the time on the vcr was hard!!!! Good luck and let me know if you need more help.
Dec 05, 2008 | Sony Bravia KDL-40S4100 40 in. LCD TV
Televison & Video Logo
27 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
