Question about Apple Ipod Touch 8gb 2nd Gen Generation 2 Itouch A1288 Mp3 Player Fast Ship B118
How many volts needed in it? my charger is broken can i use other charger with the same voltage?
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 56 Answers
Make sure the new charger is designed for Ipod combatibility, it can be dangerous using chargers not designed for the device. http://www.amta.org.au/.../Consumer-warning-on-dangers-of-fake-mobile-pho..
Posted on Apr 25, 2015
    New Friend:
  • 3 Answers
Yes buy i will be of same power and the charging point must be same like your old one.
Posted on Apr 23, 2015
Battery and or charger won't work. Charged a full 18 hrs. Help
Possible suspects are:
1. A severely drained battery.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
Nov 27, 2015 | Motorcycles
Car battery charger
It is possible that the unit needs to see a battery load before it engages the charge circuit. To test this measure the voltage of the battery without the charger. Then attach the charger and measure the voltage again. If the charger is working the voltage should be 13 to 14 volts.
Jul 26, 2013 | HP Pavilion ze5185 Notebook
How do u charge a edelbrock power wheel corvette for kids 12 volt batteries and a 6 volt charger
Hello! Due to Charger Voltage Compatibility: Never use a battery charger unless the battery voltage matches the output voltage rating of the charger...Therefore do not use a 6-volt charger on a 12-volt battery and visa-versa...
guru...........
saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Sep 27, 2011 | Cars & Trucks
How do you charge the 12 volt battery with a 6 volt charger
  • A 6 Volt charger will charge a 12 Volt battery, it will just take twice the time to get the 12 Volt battery to full charge as a 12 Volt charger would take. V*I=W. It will take up to 36 hours to get a full charge from near dead but it will work just fine.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 27, 2011 | Electric Kid Trax C6 Corvette Ride On
My charger is not putting out dc voltage, but is putting out ac voltage. for example, if i select 24 volts it will put out 24 volts ac, not dc. what failed to cause this problem? I am getting no amps on...
Hi, you're Rectofier has failed if you have A/C voltage and no D/C voltage. This is what converts A/C volts to D/C volts. If you have a diagram or any parts manual, you can locate this part and replace it. You will need to go to a place that repairs these chargers, or where you bought it to order or but a new one.
Sincerely,
Shastalaker7
Dec 30, 2010 | Heavy Duty Associated Equipment 6002B...
I HAVE DEWALT CHARGER DE9116.ITS OUT PUT VOLTAGE WITH OUT LOAD IS 51 VOLT.AND WITH LOAD IS 15 VOLT.THE BAATERIES BECOME VERY HOT WHILE CHARGING
check output voltage on charger label most chargers are not regulated so if it says 18 volt output it may put out 24 volts but if its putting out 51 volts it may have a short batteries will get warm but not hot replace charger
May 18, 2010 | Dewalt 7.2-18.0 Volt One Hour Charger
My charger blinks and doesent charge...changed fuses and still doesent work
This usually means the charger is broken but it could be a wiring loom problem, a fault with the charger plug or socket, a main control box problem (unlikely) or even very low battery voltage. Most chargers require a combined voltage of at least 16 volts before the charger will work.
Mar 07, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
My chair wont charge in either of the charging ports
It's either a dead charger or dead battery(ies). You will need a voltage tester meter to check. First check the charger by setting your meter to a setting over 24 volts (your chair is a 24 volt system). Test the voltage at the charging port by placing the two probes into the two outside ports (there's three ports in a triangle...test the two opposite ports.) You should get a reading in excess of 24 volts but less than 26. Now plug the charger into one of the ports and check the voltage again. If the voltage is now higher than the first reading, your charger is working and you will need to replace the batteries, if it is the same, your charger is bad.
Aug 06, 2009 | Pride Mobility Products New Pride Mobility...
I have a scooter and it was working perfectly but now i plug in the charger and doesen´t charge what should i do?
Assuming you didn't get the PC board mounted inside the top of the tiller assembly wet, or the power controller located under the shroud, then you likely either have one or two of the batteries that are bad, or a bad charger. You will need a voltage tester that you can pick up cheap for about $6.00. Set to the DV voltage setting in the 50-100 volt scale. Remove the seat and the shroud and test the voltage at each battery. If good, they should read about 12.25 volts or more, not higher than 14. If one is normal and the other lower, say 10 Volts, that low one is bad, but you should probably replace both with fresh gel batteries, fully charge before using. If both batteries are about 12 VDC, then plug in the charger to the chair as usual, and take another voltage test on each battery. The voltage should read higher now that the charger is on. If they aren't, then your charger has no output. Some chargers you can test output voltage on without them plugged in by testing across the two horizontal pins on the 3-pin connector that you plug into the chair. The output voltage should be about 26 volts. If it is 24 or less, you need a new charger. Good luck.
Jul 22, 2009 | Pride Mobility Products Health & Beauty
Apple Ipod Touch 8gb 2nd Gen Generation 2 Itouch A1288 Mp3 Player Fast Ship B118 Logo
80 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
