Question about Sanyo Microwave Ovens
Timer wiring diagram - Sanyo Microwave Ovens
  • Sanyo Master
  • 932 Answers
Ruben,
We need a model number for your Sanyo to be able to help you.
Posted on Apr 23, 2015
Jes1451bj02
That is most likely a failed door switch or its mount may be loose, misaligned or broken.
It's most often caused by opening the door while it's cooking instead of hitting "Stop" first, or slamming the door.
It would either be the top or bottom switch, whichever one has the thicker wires, probably black wires.
(Sorry, but I don't have the wiring diagram on this model and the door sense switch [not a suspect] will have thinner, more colorful wires).
See these help files first:
http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt
Then my help file on door switches:
http://031d26d.namesecurehost.com/mwd/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number (JES145BJ02) here.
May 22, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
WIRING DIAGRAM FOR CLOCK TIMER
You will need to post the make and the model of whatever this is before I can determine if we have the diagrams.
Jul 01, 2011 | Microwave Ovens
INtermatic Model ST01 timer is to be used in a 3 way switch arrangement. The unit works in one switch position but fails to allow the light to turn on in the other switch position. Several other switches...
ST01C timer replaces one 3-way switch and the other 3-way switch remains.
The ST01C timer does not work exactly like a 3-way switch.
When the timer blue and red wires are connected together, they reverse whatever program is in effect.
When the timer is wired for single-pole, the red wire is capped off. When timer is wired for 3-way, the red wire is used to reverse the timer, thus causing the 3-way effect.
So if timer is ON, and red and blue wires are put together, the timer turns OFF.
That's why the remaining 3-way switch has to be rewired.
The remaining 3-way switch is rewired so it will connect and disconnect the red and blue wires, causing the timer to reverse program each time, and creating 3-way effect.
Other requirements of ST01C is that the black wire must connect to Hot wire, and the blue wire must always connect to Load. This means that you have to correctly pick which 3-way switch to replace, where the hot wire from breaker arrives.
Open following link for wiring diagram showing how to wire for 3-way:
http://waterheatertimer.org/ST01C-program.html#ST01C
All 3-way timers require rewiring second 3-way switch to create 3-way effect.
Jun 21, 2011 | Microwave Ovens
INTALLED A INTERMATIC TIMER AND EVERYTHING IS WORKING WITH THE EXPTION ON THE TIMER ITSELF. DO YOU HAVE ANY SUGESTIONS
1) First suggestion is for you to add a comment and say what model number Intermatic timer you are working with.
If this is a box timer, then model number shows on inside of door.
In any case, we are guessing at your problem without knowing model number.
2) If this is a box-type timer, main thing folks do wrong is reverse the line and load wires.
Line wires come from the breaker box, and Load wires go to the fan, light, motor.
Line wires have to be connected to the clock terminals or the dial will not rotate.
The clock terminals are usually visible as small white wires connect to two of the terminals. Again, this is dependent on model number.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 23, 2011 | Microwave Ovens
When drying cycle is set on timer.circuit breaker trips Timer has been replaced but don't know if it is good. shipped with no packing or paperwork from Sears There is 2000 ohm short between the black power...
if you are sure you have wired the timer correctly you may have a faulty element as to the short between your black wire and ground are you checking this with the dryer disconnected from wall socket also run the dryer on cool if does not trip the power element faulty if it still trips you may have a wiring problem and you will have to check further let me know how you go
Nov 12, 2009 | Microwave Ovens
F9 code on mod 721-80869400 kenmore elite
This is usually inverter trouble, but it may be the magnetron, controller, wiring, etc.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
May 17, 2009 | Kenmore 63792 Microwave Oven
GE Spacemaker Model JVM1860CD002 The oven comes on all by itself, starts in the express cook mode. This could be dangerous Rob
Beelow statmwent is refering to you appliance manual with also contains the wiring diagram. I woudl speculate that the clock/ timer wil turn out to be the problem since you said that you cannot set it.
Microwaves: Inside the actual case. It is not consumer accessible. Over-the-range models have the manual behind the grille or control panel
http://www.geappliances.com/service_and_support/faqs/
Dec 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
50 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Oscar Netto
Oscar Netto
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
