Question about Coffee Makers & Espresso Machines
Knob for selecting steam/water becomes hard to turn when hot.
  • Coffee Maker... Master
  • 1,237 Answers
Shame you were unable to let us know make and model.
Posted on Apr 23, 2015
I need to descale my machine, now the screen says descale and "purge" and nothing happens when I press hot water on OR want to let steam out
There is a blockage in the steam/hot water circuit . Try poking the end of the steam tip on wand with a paper clip. Make sure turn the hot water on by pressing the hot water button and turning the steam wand.
Apr 08, 2015 | Saeco Magic Comfort Plus Espresso Machine
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
How to descale machine-is there a video showing how? I have the Saeco Magic Comfort + machine.
Hi
I put this next statement in so your machine will last longer.
Enter the menu by pressing the menu button. Scroll down until you reach "water hardness" and then press the menu button to activate. Scroll down to the hardness of your water (chose 4 to be safe) and press the menu button again for the computer to remember. Push escape (esc.) and scroll to "Descale) about 4 up from water hardness, and push enter.
To descale your Magic Comfort +, enter the menu and scroll to descale. Push the menu button to descale. Mix your solution in your water tank. Use warm to hot water and dissolve all the solution. Place the water tank on your machine. With a container under the steam wand that is large enough to catch all the water in the tank, you are ready to begin. To start the descaling process, open the steam knob. The machine will automatically start the descaling process and when it is finished, it will shut off and tell you that it needs to be rinsed. Remove the water tank and rinse with fresh water. Refill the water tank and place it on the machine. Turn off the machine, wait a moment, and then turn it back on. Press the hot water button to start pumping fresh water through the boiler. Pump out about 16 oz. of water and then turn off the hot water button and open the steam knob to rinse the steam boiler. When it starts to go to steam, turn off and turn on the hot water button again. Pump out another 16 oz. Repeat this process with the steam knob until you have emptied the water tank. Descaling is complete. Go to your menu and scroll to "reset descale", push the enter button and chose "Yes" and push the enter button. Now it will tell you we next to be descaled.
Feb 14, 2011 | Saeco Magic Comfort Plus Espresso Machine
Gaggia Titanium. Fault suggests ventilation required. Followed manual instructions, nothing happens. Tried rinsing, nothing happens. Tried hot water nothing happens? Have taken out and cleaned all pbvious...
Do you hear the pump working but no water flows?
You should select hot water (the third button from the right) and the display should say "hot water" at the same time it is saying VENTILATE --- open the steam valve all the way and the pump should start and you should see water from the steam wand.
If you don't hear the pump at all, then that is a different problem.
If you do hear the pump but still don't get any water with the steam valve open, then you need to prime the pump by using a turkey baster or the accordian pump that came with the Titanium to pump water into the valve where water from the tank goes. Remove the tank and use the turkey baster to pump water into that valve while the pump is running and the steam valve is open all the way with HOT WATER selected. the second water starts to come out the steam valve you want to stop the pump (turn the power off or turn the steam knob shut) and put the water tank back on and make sure there is plenty of water in the tank - then start the pump again by opening the steam valve all the way and let it pump water out the steam wand for a few minutes.
Oct 05, 2010 | Gaggia Titanium Espresso Machine
I have lost manual so i am trying to find out how i descale my machine
Hi
To descale your Magic Comfort +, enter the menu and scroll to descale. Push the menu button to descale. Mix your solution in your water tank. Use warm water and dissolve all the solution. Place the water tank on your machine. With a container under the steam wand that is large enough to catch all the water in the tank, you are ready to begin. To start the descaling process, open the steam knob. The machine will automatically start the descaling process and when it is finished, it will shut off and tell you that it needs to be rinsed. Remove the water tank and rinse with fresh water. Refill the water tank and place it on the machine. Turn off the machine, wait a moment, and then turn it back on. Press the hot water button to start pumping fresh water through the boiler. Pump out about 16 oz. of water and then turn off the hot water button and open the steam knob to rinse the steam boiler. When it starts to go to steam, turn off and turn on the hot water button again. Pump out another 16 oz. Repeat this process with the steam knob until you have emptied the water tank. Descaling is complete. Go to your menu and scroll to "reset descale", push the enter button and chose "Yes" and push the enter button. Now it will tell you we next to be descaled.
Jun 18, 2010 | Saeco Magic Comfort Plus Espresso Machine
How do you descale a Saeco Magic Comfort Plus coffee machine? do you buy some fluid from somewhere and pump it through or what?
Hi
Jun 11, 2010 | Saeco Magic Comfort Plus Espresso Machine
We dont have a manual for our Saeco Magic comfort coffee machine and the declcify message is up on the screen. What do we do?
Hi
Enter the menu by pressing the menu button. Scroll down until you reach “water hardness” and then press the menu button to activate. Scroll down to the hardness of your water (chose 4 to be safe) and press the menu button again for the computer to remember. Push escape (esc.) and scroll to “Descale) about 4 up from water hardness, and push enter.
To descale your Magic Comfort +, enter the menu and scroll to descale. Push the menu button to descale. Mix your solution in your water tank. Use warm to hot water and dissolve all the solution. Place the water tank on your machine. With a container under the steam wand that is large enough to catch all the water in the tank, you are ready to begin. To start the descaling process, open the steam knob. The machine will automatically start the descaling process andwhen it is finished, it will shut off and tell you that it needs to be rinsed. Remove the water tank and rinse with fresh water. Refill the water tank and place it on the machine. Turn off the machine, wait a moment, and then turn it back on. Press the hot water button to start pumping fresh water through the boiler. Pump out about 16 oz. of water and then turn off the hot water button and open the steam knob to rinse the steam boiler. When it starts to go to steam, turn off and turn on the hot water button again. Pump out another 16 oz. Repeat this process with the steam knob until you have emptied the water tank. Descaling is complete. Go to your menu and scroll to “reset descale”, push the enter button and chose “Yes” and push the enter button. Now it will tell you we next to be descaled.
Apr 20, 2010 | Saeco Magic Comfort 103467 Espresso...
Ventilate message, then no steam coming out
Sounds like you have an internal blockage in one of the boilers.
Take it to your local service agent for repair.
Did you remove the milk frother and try the hot water again?
A blocked frother is a very common problem .
Feb 24, 2010 | Gaggia Titanium Espresso Machine
How do I descale the saeco magic deluxe coffee machine?
Try this:
Standard descaling
Switch off the machine.
Pour a descaling product into the water tank.
Switch the machine on to the programming mode(see below). Place a large container under the steam/hot water dispensing tube and open the steam/hot water knob slowly, turning it counterclockwise.
Turn on the machine by pressing the main switch and let the descaling product flow out of the dispensing tube for approx. 1 min.
Close the knob again.
Turn off the machine with the main switch and let the solution take effect for approx. 5 minutes.
Repeat this procedure two or three times, to allow all of the descaling product in the water tank to flow out of the dispensing tube.
As soon as descaling has been carried out, rinse the tank thoroughly and fill it with fresh water.
Switch on the machine and let fresh water (approx. 2 l) flow out of the steam/hot water dispensing tube in order to rinse away residue.
The machine is now ready for operation.
When the machine is on, the warning light switches off automatically, by pressing the steam selection button for at least 5 seconds.
To enter the programming mode, turn the machine
off with the main switch.
Press steam , espresso coffee and the
main switch at the same time.
Release the buttons.
Hope this will help you.
/Mirran
Aug 16, 2008 | Saeco Magic De Luxe Espresso Machine
Descaling
(Button 26 is the right-most one (2 intersecting
ovals.)
From the Manual:
Press the button (26) for at least 5 seconds to
select the descaling operating mode; the LED
emits a fixed light.
• Direct the steam nozzle (14) toward the drip
tray.
• Position a vessel of adequate capacity under
the steam nozzle and turn the hot water knob
anticlockwise (16). The appliance starts an
automatic descaling cycle with pauses preset
by the manufacturer and managed
automatically by the appliance.
• At the end of the cycle, the flow of the
descaling solution is shut off and the 5 buttons
start flashing simultaneously.
• Turn the knob of the hot water nozzle (16)
clockwise to OFF. In this case, also the warning
light (27) flashes.
• Rinse the water tank and fill it with fresh
drinking water.
the steam nozzle and empty 2/3 of the
contents of the water tank by turning the steam
knob (16) anticlockwise; to shut off the flow,
turn the knob (16) clockwise.
• Let the appliance heat up and empty the
remaining contents of the water tank by turning
the steam knob (16) anticlockwise; to stop the
flow, turn it clockwise.
HTH
dave
Aug 14, 2008 | Gaggia Syncrony Compact Coffee...
Coffee Makers & Espresso Machines Logo
46 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
