Question about Video Cameras
I need a charger + baters
Serial #304111374 twin cam
How to install timing chain with timing marks both crankshaft and camshaft
Hellen, For the second time, Re POST year, make, model, engine size and complete question so we, here at fixya can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Still pulling hair Twin Cam timing marks How accurate Engine Exhaust...
16v fast tbelt swap
Twin cam 16 valve timing marks Google Search
Aug 11, 2016 | Cars & Trucks
I have a Yamaha that I cant find out what model it is. I think its the xs 650 but im not for sure. All I know is that it was made 7/78 and the Serial number is 2Lo - 105468. It has twin cams, elc. starter...
It is a 1979 Yamaha XS400F. Although it was built in 78 it is a 79 model year with that serial number. 392cc plus the serial number both ties up with it being an XS400.
Jun 02, 2011 | Yamaha XS 650 A Motorcycles
How to replace a broken timing belt for a 1998 daewoo lanos?? Would there be any head damage?
yes it is quite possible that valves are bent if the cam belt broke or teeth stripped off of old belt, which unfortuneately means removing the cylinder head and getting it repaired (valves replaced and possibly guides) see some of my other posts for cam belt timming marks locations etc...
depending what motor is in your vehicle twin cam or single?
stevenhurc_14.jpg and if its twin cam you usually need cam locking tool for cam gears.
Apr 20, 2011 | Daewoo Lanos Cars & Trucks
How do I find out if my 1999 Lanos is a twin cam or single?
you can read it in the manual, or if your familiar with the engine parts remove the cylinder head cover, you'll seethe valves and cams, then you'll know if its single or twin... but i think its a twin cam... if im not mistaken...
Mar 31, 2011 | 1999 Daewoo Lanos
How do you recharge the vector? Don Rutledge
VECTOR VECO12B, JUMP´N CHARGE SMART BATTERY CHARGER.
Hola a todos, yo he comprado recientemente (Febrero 2011) este sistema. Yo he tenido el mismo problema el cual no carga la bater?a interna del sistema. El sistema de carga de bater?as funciona bien pero el sistema de jump-starter no funciona.
Luego de hacer varias pruebas, de leer en internet y analizar el problema, yo llegu? a la conclusi?n de que la bater?a interna esta da?ada o fuera de especificaci?n.
Que sucede? Lo que pasa es que la bater?a interna del jump-starter se encuentra en un nivel de tensi?n (Voltios) se encuentra demasiado baja, lo cual no es suficiente para que el cargador lo vea como suficiente para iniciar la carga, muestra la falla F01 o F02.
Lo que yo realice fue lo siguiente: usando el cable de carga de 12 volt DC, yo coloque un extremo conectado al salida de 12 volt DC desde jump-starter y el otro extremo del cable yo lo conect? con los cables auxiliares a una bater?a externa. Esto hace que se conecte la bater?a interna del jump-starter, con la bateria externa. Esto sin usar los cables de pinzas para bater?as.
Bajo esta condici?n yo conect? el jump-starter a una toma de 110 volts AC y yo lo encend? y luego yo seleccion? el nivel de carga (2, 4 o 6 Amps). El cargador inici? la carga de las dos baterias, (la bateria interna del jump-starter y la externa).
Esto hace que la corriente de carga se distribuya equitativamente (dependiendo de la impedancia de cada bater?a) entre las dos bater?as.
Yo lo deje en esa condici?n por 12 horas, siempre chequeando la condici?n del sistema.
Luego de ese tiempo, yo desconect? el sistema y yo medi en el socket de 12 volt DC, la bater?a interna y subi? a un nivel de 11,50 volts DC. Desde ese momento el jump-starter, comenz? a reconocer la bater?a interna como buena, y yo lo deje dos horas carg?ndose a si mismo, y luego de esto, el nivel de tensi?n era de 14,40 volts DC.
Yo apagu? el cargador y el sistema quedo cargado dispuesto para trabajar.
De todo esto yo deduzco que el problema era la bater?a interna la que no tenia suficiente nivel el?ctrico para que iniciara el cargador de baterias su trabajo.
Saludos, yo espero que esto le sea de ayuda para todos.
Ali, desde Venezuela.
alilo07@hotmail.com.
Electronic translate
VECTOR VECO12B, Jump'n CHARGE SMART BATTERY CHARGER.
Hello everyone, I recently purchased (February 2011) this system. I have had the same problem which does not charge the internal battery system. The battery charging system works fine but the jump-starter system does not work.
After various tests, online reading and analyzing the problem, I came to the conclusion that the internal battery is damaged or out of specification.
What happens? What happens is that the internal battery jump-starter is in a voltage (V) is too low, which is not enough for the charger to see it as sufficient to start charging, it displays the fault F01 or F02.
What I made was this: using the power load of 12 volt DC, I placed one end connected to 12 volt DC output from jump-starter and the other end I connected with the auxiliary cable to an external battery . This makes connecting the internal battery jump-starter, with the external battery. This without using the battery cable clamps.
Under this condition I connect the jump-starter to a power of 110 volts AC and I turned it on and then I select the level of charge (2, 4 or 6 amps). The charger begins charging the two batteries (internal battery jump-starter and external).
This makes the load current is distributed equally (depending on the impedance of each battery) between the two batteries.
I leave it in that condition for 12 hours, always checking the condition of the system.
After that time, I disconnect the system and I measurement in the 12-volt DC socket, the internal battery and up to a level of 11.50 volts DC. Since then the jump-starter, began to recognize the internal battery as well, and I leave two hours charging himself, and after that, the level of tension was of 14.40 volts DC.
I turned off the charger and the system is loaded ready for work.
From all this I deduce that the problem was the internal battery which did not have enough power level to initiate the battery charger work.
Greetings, I hope this is helpful for everyone.
Ali, from Venezuela.
Jan 30, 2011 | JUMP START SYSTEM
Battery malfunction. both lights flashing on charger.
your batery has shorted you need a new batery I sugest you get another tool with same bater and charger just the batery alone will almost 1/2 this much
Oct 24, 2010 | Ridgid 18v Drill R86007 Rigid
Machine Elna Supermatic 722010 When I sew with a single cam all works properly the problem comes with any twin cam, the upper cam follower has a spring holding it away from the cam, how do I get the upper...
tally_girl_2.jpg I don't suppose it would be so simple as setting the wheel inside the elnagraph to "A" to engage the automatic stitches? I've done it myself once or twice LOL.
Mar 29, 2010 | Elna Heirloom Edition 6005
Need new car charger adapter and cords for Coby Twin DVD Players
i need tis car charger adpter and relating cords to my twin coby dvd players replace how to do htis; where to buy im in jacksonville florida .thank you
Jun 25, 2009 | Audiovox PVS72901 Portable DVD Player
Video Cameras Logo
57 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
