Question about Dryers
What causes the blade to stop spinning - Dryers
    Genius:
  • 1,617 Answers
What make/model of fan is it? Remote? Wall control? Pull chain?
Posted on Apr 23, 2015
How to replace a blade shaft on d105 JD
Did the blade come off?? I believe it's time for a trip to the "John Deere man".. Stop "trying" this.. you could cause more damage to other parts..$$$$...
Jul 19, 2017 | Garden
I have installed a new blade in my circular saw R32021 and the blade stalls even before I begin to cut wood
by stalling do you mean that the blade stops spinning or the motor stops turning
if the blade stops spinning then the mounting bolt for the blade is not tight enough
if the motor stops spinning , junk it and get a new unit
Jan 20, 2017 | Blade Saws
My Ryobi 10" chop saw was stopping mid-cut. Why is it making an awful noise now?
The nut that holds the blade on May gave come loose. Or motor is shot
May 02, 2015 | Saws
What would cause the PTO not to disengaged the blades from turning?
A faulty switch if the blades are spinning at full cutting speed
Not cutting the current to the engaged blade clutch so the blades are stil on even when the switch is in the off position.
The blade brakes not gripping the pulleys fully to stop blades so anything brushing against the blade will start them spinning
Or the clutch medium is damaged and is not releasing the blades fully so they spin but slowly when you switch the switch they just slow down get the deck alignment switch for clutch and the wireing to the blades system checked and the braking system for the blades pulleys checked as soon as possible the machine is dangerous
With the blade continuously rotating you risk injury from the blades catching.g you or someone else who's not aware the blades don't stop.etcetera.
Jun 09, 2014 | Toro Garden
Cultivator spinning slow
If the blades are turning slowly while the machine is on tick-over, then it is more than likely a clutch issue. Clutch springs will stretch and occasionally break. With less resistance on the clutch shoes they grip the clutch drum and this in-turn will cause the blades to turn.
Check clutch springs.
Apr 10, 2013 | Stihl Garden
John Deere L110 blade brakes wont stop blades from spinning
Are the brake pads on brake levers good? May need replace levers.
Apr 01, 2012 | Garden
My Craftsman 8 1/4 Radial Arm saw
tighten retaining bolt if still spins remove bolt and add a washer to the out side of blade between the bolt head and retaining washer and retighten
Jan 29, 2010 | Craftsman Saws
Krups blender blade stops
well it looks to me there is some thing not tight enough connection to ur blade.....as u say it works when empty but when u put soemting in its stops....this means ur blade is not tight on the shaft to the motor......or u may have done something wrong when u had the blender open........recheck ur work and make sure its tight,,,,,
if so u will have ur ice cold drink....cheers i hope so for ur shake
Jul 03, 2009 | Blenders
Craftsman DYT 4000, 24 hp 48" deck. While I was mowing, the blades stopped turning, started again, and then stopped. I shut down, all looked OK, tried to start and nothing. No click, nothing. Any ideas?
there is a fuse in engine compartment that might have blown causing the engine or blades not to start but what probably happened was something got caught in the blades check under the deck & see if there is & also try spinning blades by hand & see what happens
Jun 12, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Dryers Logo
77 people viewed this question
Top Dryers Experts
