Question about Irulu 10.1"tft Wifi 3g Android 2.2 Tablet Pc Touchscreen 0.3mp Camera 2gb 512mb Ddr2
Where can I send to fix my tablet
Where you plug the charging port on the tablet
2 Suggested Answers
  • 43064 Answers
SOURCE: The pin in the charging port is loose,and it hard to charge irulu expro1 tablet how can I fix this?
Google repair shops in your local area .
Posted on Aug 17, 2015
Why want my tablet charge Where do I return my tablet it will not charge anymore
Most common cause of this is faulty charger, the metal connector at end of wire won't connect properly to device charging port.
Test it by putting plug back in Tablet charger port and very very gently wiggle it around very slowly, see if the charging light comes on or flickers. They usually make a beeping noise when successfully charging or the screen lights up. If you get intermittent charging then it's the charger and time to get a new one. Very common, most are USB connectors or small pin types.
If it's still under warranty then send it back to the place you bought it before you try testing it.
Oct 07, 2016 | Tablets & eReaders
Port on 10 inch tablet not working can it be fix
Linda, if it is the charge port, mini USB, yes they can be fixed or replaced by cell phone/computer repair shop.
Check the attached links videos showing port replacement. Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
Toshiba Tablet AT300SE AT305SE Charging Port Repair
Samsung Galaxy Tablet 10 1 Tab 3 10 1 P5200 P5210 Micro USB Port Replace HD
May 03, 2016 | Tablets & eReaders
The charger wont go in to the port to charge it and the tablet needs to be charged it was working just fine last night dont know if my son did something or not
Robin, the charge ports can be changed at a computer or cell phone repair facility. Check the attached links,instruction and guides, Good luck
How to replace the fixed charging port
How to Fix Tablet Charger Port
Amazon com 2 pcs Replacement Micro USB Charging Port Connector for Vizio...
Apr 24, 2016 | Tablets & eReaders
I CANNOT CHARGE THE TABLET THRU EITHER PORT- THE REGULAR CHARGING PORT OR THE USB PORT THAT I FOUND ALSO CHARGES IT. WHAT COULD BE WRONG AND WHAT ARE POSSIBLE SOLUTIONS?
could be software issue reset it would fix it:?
damage to ports both broken sounds unlikely
try usb plug into a different computer
the cables inside the tablet are loose or not connected
check for damage to ports and loose connections inside device
Jun 29, 2015 | Proscan PLT7223G 7" 4 GB Wi-Fi Black...
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
How can I fix the RCA 7in power port?
You should contact Authorized Dealer or Service Center to get it serviced.
Apr 26, 2014 | Tablets & eReaders
Power port needs repaired
Are you sure it is the port that needs fixed, or is it your usb cord you plug into? If it is the port you need to send the tablet in for a technition to repair. First try a new charger or usb cord and see if it works.
Feb 23, 2014 | Android Ainol Novo 7 Paladin Tablet PC
Arnova 7k g3 wont charge
You probably destroyed the port plate of the charger. You should check if it is bent or dented and if they are the price to get it fixed is $50-$150
Jan 20, 2014 | Archos Arnova 7 G3 Tablet
Htc wont charge and turn on
If it won't charge then you may have a defective charger, a failed battery or a loose solder joint at the charging port. If your charger plug is fitted with a fuse then consider checking the fuse is okay by trying a new one. Also, check your charger on a friends HTC, check their charger on your HTC. It really is a process of elimination to find the issue yourself.
The HTC won't turn on because it isn't charged, until you fix charging prob it won't turn on.
May 02, 2013 | HTC Flyer 7 inch 32GB Android Tablet PC...
7" touch andoid tablet won't charge
It may be the charger has a loose wire. In that case a new charger would fix the problem. Mine has a problem with the charging port itself. I am fortunatly that my tablet is under warrenty they are going to replace the tablet for me.
Dec 27, 2012 | Nextbook Premium 7 Capacitive Touch...
Irulu 10.1"tft Wifi 3g Android 2.2 Tablet Pc Touchscreen 0.3mp Camera 2gb 512mb Ddr2 Logo
44 people viewed this question
Top Irulu Tablets & eReaders Experts
David Clark
David Clark
john smith
David Harrelson
David Harrelson
Are you an Irulu Tablet and eReader Expert? Answer questions, earn points and help others
