Which way should the flue handle be to open flue
  • 954 Answers
Usually straight up and down. But I would test the draw with a small roll of lit newspaper.
Posted on Apr 23, 2015
Testimonial: "thanks"
Damper on a smith boiler is not working right and boiler won't stay on
If it's a flue damper, which I think you are talking about. You will see what looks like the tip of a 1/4" slotted(flat head) screw driver. That is the indicator if open or closed. It should be paralel with the direction of flue pipe. If it's not nearly exect unit will shut down. turn t'stat off or if that's not an option, turn temp down below room temp. wait a few min, turn t'stat on or above room temp and go to boiler as fast as possible.
See if damper is opening and stopping short of opening completely.
You may have built up soot and/or debris in flue causing it not to open all the way.
Please give full model # and do not force open. You may have dectectors that are picking up vapor,-gas probs.You mayl have to do a draft test. Better to be cold, than dead. Sorry for short explination
Mar 05, 2013 | Heating & Cooling
I have a old chimney flue which is uncovered letting rain water in what do i need
You don't need a plumber what you need is to have the flue inspected to make sure that the water you are getting is from the opening on the top of the flue. If it is the opening that is causing the problem it will need to be capped. This can be done by an individual that specializes in flue work as well as an inspection of the flue. Some masons will do this type of work.
Jul 14, 2012 | Plumbing
How do i know if the flue is open?
Put a smoke pellet in to the flue light it if it is open the flue will draw the smoke up the flue .
Feb 24, 2012 | Heating & Cooling
I have a sfw 55 which i put coal in overnight when banking but im finding i have to clear the flue both liner and the flue inside the firebox every month which has a large build up of a bitumen...
It may be the type of coal you're burning. Have you tried burning anthracite coal rather than Bituminous coal? It's a little more expensive, but it burns cleaner. Also, you may need to open the air intake a bit with what you're currently burning. That way it will burn a little hotter and hopefully cleaner.
Mar 07, 2011 | Heating & Cooling
I installed the heater to the minimum distance from the ceiling due to the vent cap on the outside wall. The way I read the instructions it appeared the the end of the vent cap could not be within...
the flue is what is called a balanced flue, air in the other flue to burn inner flue is outlet gases , so you cannot just put any flue on there if is not in the makers instructions i would say no or contact the makes to be sure, how far is it from the fence
Dec 03, 2010 | Williams 1403622 Gas Compact Heater
Can i use a normal gas flue for my stove
You can use single wall flue pipe with no problems, but any double wall would be more expensive than needed, but yes, you can use either as long as you can seal any seems or openings.
Aug 17, 2010 | Heating & Cooling
Worcester combi gas boiler 3.5 highflow is constantantly dripping water at the external flue position over flow pipe
water vapour is one the main products of combustion of gas. With a standard efficiency boiler, upon initial heat up when the flue is cold this vapour can condensate on the inner wall of the flue but should stop once the flue heats up, to stop this condense dripping back on to the heat exchanger the flue should be tilted towards the outlet and thus on initial heat up water can drip from the flue. with high efficiency (condensing) boilers, condensation will occur in the flue and secondary heat exchanger during normal operation, dispense of this condensate is accommodated for in the boiler and therefor the flue should be tilted towards the boiler, if not the flue will drip constantly.
Apr 06, 2010 | Water Heaters
I have just opened up my chimney and took it back to the bare bricks and was giong to install a wood burner but decided to fit a gas stove instead. there was originally a gas fire installed so it has a...
You will need to install a flue liner ( i know its a nuisance) to allow the products of combustion to escape as quickly and as safely as possible.
If you installed a gas appliance without a liner, due to the temperature of the flue gases (lower than solid fuel) the emissions would struggle to exit via the flue terminal.
If you install the appliance following the manufacturers instructions, you cannot go wrong. The other recommendation is get a 'Gas Safe' engineer to carry out the commssioning/testing.(house insurance void if not certified)
I hope this helps.
Jul 07, 2009 | Ovens
RED HOT FLUE EXHAUST
Hello. Yes this is normal for this type of fryer, meant more to cook the product, as efficiently as possible, and guzzle gas pretty good. If the orange is near the bottom of the flue, that is pretty good, there is , or should be insulation on the outside of the flue, or if the air gap is large enough, no insulation at all. Not getting near the exhaust pipe is advisable, or you will be burned. The gas pressure is important thought, if the burners are over/under pressured, it will affect the burn enough to damage, and shorten the life of the fry vessel. Call a local authorized servicer and have a check up, will not be free, but will save expense of something not being correct, most places, you pay an hour to check it good enough.
Hope that helped, and thank you.
May 05, 2009 | Imperial IFS40 Deep Fryer
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
