This one has a horizontal interference that takes up mabey a fourth of the screen from the bottom up.
The interference screws up what you'd be watching. If, for instance the numbers of the channel, and some other info were on the screen, it will double up. You'll see that on that interference part, and the rest of the screen. It jiggles in that sace too. I know it's not a great explanation, but what it is I guess is that a quarter of the screen from the bottom up is messed up!
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
If you wish to get some details; visit this site " Electro help "for more details. Google for it. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Apr 23, 2015
4 Suggested Answers
1joester2
  • 74 Answers
SOURCE: I'm new to the HD world...just purchased a LG
Check in the manual or with the manufacturer, but the TV should auto configure the picture based on the signal.
I have a Toshiba that does the same thing.
There is no mistake when HD is in effect, as the picture is superb.
Posted on Jan 09, 2010
John-INSG
  • 312 Answers
SOURCE: i have these faded lines running across the top
Horizontal lines like you describe can be caused by interference from another device. Ensure that you don't have other electronic equipment near the TV. It can also be indicative of trouble with the display itself for which repairs might be required. If needed, service can be obtained by carrying the unit in to the place of purchase.
Posted on Mar 19, 2010
Slinteriors
  • 8617 Answers
SOURCE: Toshiba 46XV645U Shadow Effect Problem
thats usually caused by a flex tab bond on the panel itself especially if the screen appears slow motion in that area.
Posted on Aug 07, 2012
I HAVE HORIZONTAL LINES ON THE LEFT SIDE OF MY LAPTOP SCREEN.. THEY INTERFERE WITH MY PAGE I AM WORKING ON..HOW DO I REMOVE THEM...
It sounds like the LCD is cracked. I'm afraid the only way to solve this problem is to either get the screen replaced by a computer repair shop, or purchase a replacement laptop.
Best of luck with whichever route you choose to take!
Jul 24, 2014 | Acer Computers & Internet
Screen has horizontal lines and fading
bad screen u have to get new screen take it apart from top side pop off top panel 2 screw on back use flat head unscrew screen get new one one ebay ect ok cheak cables in ther also thx nick
Feb 09, 2008 | Computers & Internet
Horizontal lines high and low on screen top and bottom also bright flecks of red color
Are the bright flecks of red color where it is supposed to be black? That could the one of the sustain boards going out also could cause the horizontal lines too depending on the board - worst case scenario - would be a bad ribbon cable on the panel itself - best case scenario - plug the tv in to an outlet that is by itself to isolate interference as a possibility.
Thanks,
phatcav
Feb 05, 2011 | Samsung HP-T4254 42 in. Plasma Television
I have red and green horizontal lines moving up from the bottom of screen
Red and Green Hor. Lines moving up through picture can be a bad filter in power supply or some equipment hooked up with interference from ac supply
Nov 30, 2010 | Vizio GV42L 42 in. LCD Television
Kv-35xbr48 turns on fine nice picture then horizontal lines form distorting picture like interference also is the back hard to take off and put on needs a good vacum thanks for any suggestion
At first the picture is ok, and then distorted with horizontal lines i thinks. If the horzontal lines are parellel acros the screen, with an inch apart across the whole screen, your tv needs screen adjustments. Screen voltage may be high. look into the crt base also. Change it first. These also not resolve the problem, LOT may be faulty, with respect to screen focus pack. May need replacement. Try first setting screen voltage to a lower settings and observe.
Oct 14, 2010 | Sony KV-35XBR48 35" TV
Line at bottom of screen takes time to clear
if the line is horizontal and kind of rolls up the picture, or you get a dark picture at first, its probably a bad capacitor. there are 2 - 100uf 16v caps that go bad c2p05 and c2p08 on the signal board
if the picture just shrinks, it can be these caps bad, or maybe your pump up cap on the vertical IC
all parts are solder in
estimate = 100-200$
Jun 01, 2010 | Mitsubishi VS-60609 60" Rear Projection...
I get lines running across my television (wd62525), especially noticeable when screen goes black. video noise? and it moves horizontally across the screen.
Sounds like interference or signal contamination. Does it occur on OTHER inputs? If not..then the input signal is corrupt, weak, has interference, wrong cable, or othewise defective.
Jun 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
KP-61HS10 with 6 blinks
Set screen voltages. To get to the adjustment board, take the front speaker grill off (two screws at the bottom left and right) and set it aside. No need to disconnect any wires. Then remove the plywood board with 4 screws that exposes the screen/focus adjustments. The top 3 adjustments are for focus, and you need not mess with these. The bottom 3 adjustments are for Red/Blue/Green screen voltage rough adjustments. My screen showed red lines, so I had to turn the bottom right adjustment with a philips head screwdriver just slightly until the red gun retrace lines where no longer visible.
Hope This Helps
Aug 19, 2008 | Sony KP-51HW40 51" Rear Projection...
The laptop screen
This is going to be a hardware issue. Start by checking the screen connections, they sometimes work loose. If the connections are good and the problem persists, it's going to be the inverter or screen, and unfortunately, replacement is your only option.
Jun 28, 2008 | Dell Inspiron E1505 Notebook
Televison & Video Logo
Top Televison & Video Experts
