Question about Pool & Spa
Where do I connect the air hose to the motor?
  • 1,631 Answers
AIR Hose?
What do you mean?
what are you working on?
Make and Model?
Posted on Apr 29, 2015
How to repace switch button
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor.
The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches and sends the power to the motor.
When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
Oct 18, 2014 | Jacuzzi Home
When I push the start button motor running but not stay on
Air Switch Repair
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
May 30, 2014 | Jacuzzi Home
How to install whirlpool jacuzzi switch
Air Switch Repair
US Parts Center
Apr 27, 2014 | Jacuzzi Home
When i push the start button, nothing happens. The motor has power, but does not switch on.
Air Switch Repair
US Parts Center
Mar 03, 2014 | Jacuzzi Fuzion Whirlpool
Jets won't pump water
Air Switch Repair
US Parts Center
Jan 19, 2014 | Whirlpool Pearl Navarre 7242 True Bathtub...
My whirlpool motor/pump will not start but hums occasionally. The switch does not function properly during these periods. Do I have a switch problem, pump/motor problem or both?
Air Switch Repair
US Parts Center
Jan 12, 2014 | Home
My Aker Swirlbath pump hums but ther is no water action when I turn it on
Air Switch Repair
US Parts Center
Jan 11, 2014 | Home
My air tub will not turn off
Air Switch Repair
US Parts Center
Dec 02, 2013 | Home
Air switch
Air Switch Repair
Search for TBS-339 Air Switch
US Parts Center
Sep 27, 2013 | American Standard Home
How do I get the F1 code to go away? It pops up before the machine will start washing and then again before it will start rinsing. (Kenmore Elite) Oasis HE
It sounds like the error code F1 appears whenever the machine is filling. The machine/motor control senses an error in the signal coming the pressure sensor circuit. Either there is an air leak and/or moisture is present in the pressure sensor hose, lint and/or flashing in the air dome hose connection port, or the machine/motor control is malfunctioning.
Remove the three screws from the rear of the console assembly then pull console towards the front of washer to hinge it open and remove console. The machine/motor control assembly is located on the right hand side of the machine that is enclosed in a casing with a clear tube/hose connected to it.
The clear tube/hose is the pressure hose. Check to make sure that everything connected to the machine/motor control assembly is properly attached and fully inserted and the pressure hose has no air leak, kinks, or moisture.
Turn off the water supply to the washer and disconnect the hot and cold water hoses from the rear of the washer then remove the end of the drain hose from where it is installed. Remove the eight screws from the rear panel and remove the panel.
Inspect the pressure hose for evidence of water then replace the hose if water or moisture is present. Inspect the air dome hose connection port for lint or flashing.
Use a small round device such as a small screwdriver to ensure that there is nothing blocking the air dome outlet on the tub.
Replace the machine/motor control assembly if and only if verified that there are no issues with the air pressure system. Remove all the wire connections to the machine/motor control then remove the screw holding it to the console tray. Two plastic legs on the rear of the machine/motor control assembly are fitted into the console tray. Lift the front of the control assembly to pivot it out from the console tray. Reinstall the new machine/motor control assembly then secure it to the console tray and reconnect the wire harnesses.
NOTE: It is a good idea to take note of the wire harness connections before disconnecting them to prevent messing them up upon reconnection.
Dec 29, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Pool & Spa Logo
150 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
