Question about Refrigerators
Fridge is freezing over even with thermostat set low. Is replacing thermostat a DIY job?
  • Refrigerators Master
  • 5,323 Answers
Fridge freezing up- and no fan or air circulation:
God is so good:
AT TIMES The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 1300 ( give or take 150 ohms) ohms is required
Posted on Apr 27, 2015
FREEZING UP IN REFIGERATOR SECTION- WATER IN JUG IN DOOR IS FROZEN
Has the temp control not been set too low by accident. If not it sounds like the thermostat contacts are stuck together or the sensor bulb has leaked. Unplug the fridge and try tapping the thermostat switch on the compressor lightly and see if that will make the fridge stop running. If that does not help, the thermostat will have to be replaced.
Feb 06, 2011 | Fisher Refrigerators
Why does the fridge part of my zanussi freezone fridge/freezer, keep freezing the food?
Hi,the problem you are encountering is as a result of the fact that the thermostat which regulates the cooling temperature in the fridge/freezer is bad hence there is no regulation of the cooling temperature in the fridge/freezer section, hence the food in the fridge freezes up.
The solution is to replace the thermostat of the unit,here is how you go about it;
1.You have to disconnect the fridge from the power source.
2.Locate the thermostat at the bottom of the unit,at the top left corner above the condenser.
3.Now you need to locate the wire ends or wire harness and unplug them.
4.Replace the thermostat,reconnect it back,put the back cover back and you have completed the job.
Take care of yourself
Jun 24, 2010 | Hoover HCA390FFK Bottom Freezer...
Refrigerator freezes everything even on low setting
Is it a single or double door? Assuming it is a double door. Normally the upper grade models have an auger motor that opens and closes electronically depending on temperature demand. This auger situated at the top LSD of the fridge normally freezes up due to various reasons. Most common is, product is placed to close to outlet which in turn creates a blow back effect and seizes the mechanism. Need to defrost fridge section for about 2 hours for ice to melt. Retry.
If it is a single door, your thermostat needs replacement. I'm taking it you have adjusted the settings higher(not so cold) but still not correct.
Sep 27, 2009 | Frigidaire FRS26R4A Side by Side...
Fridge keeps freezing up
Then replace the thermostat. It's cheaper that wasting all that beer. Seriously I think your thermostat is broken and stuck on coldest setting. Sea Breeze
Aug 21, 2009 | Kenmore 564-91179400 / 564-911714001
Hi my fridge freezes every thing even at it's
your thermostat is bad, what it does it sense the temperature set buy the control setting, once it goes bad it does not recognize the temperature hot or coold and the unit keep running and freezes everything. thermostat work like the therometer switch, when it reach certain temperature it cut off.
Jul 16, 2009 | Dometic Refrigerators
Power failure in the area, everything is freezing in fridge
If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
Jul 13, 2009 | Refrigerators
Over Chilling Refridgeration set on 7C still goes to 0C Digital thermostat
sounds like a bad thermostat,you can check it with a meter by putting the meter on omes,thermostat in closed position no reading turn thermostat all the way on you should get a reading if not replace,let me know-mike
Sep 29, 2008 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
