Question about Samsung Refrigerators
What does error code 26 E mean on a samsung refridgerator RFG298HDRS? Other than FZ ice maker function error. What do I do to fix it?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 75 Answers
Is this the correct model number?
Posted on May 05, 2015
aborcass
  • 2651 Answers
SOURCE: Refridgerator ice maker not making ice
actually it should be blinking when door opened, try closint the little flap on left side of freezer liner, does hte light then become solid??? if so the electronic control is working correctly.. open the flap acessing to ice maker itself is there any ice in the machine now?? perhaps an ice cubes is jammed and not allowing hte icemaker to advance.. ck the little black nozzle(fill tube) crush it with your fingers is it full of ice???if so your fill tube is frozen and needs to be thawed. this is a pretty hard ice maker to trouble shoot. lastly theres ascrew under the rt corner if ice machine 1/4 nut driver. remove htat screw it releases acover for wires. the ice maker will pull out (youl need to push up a little tab along the left siderail inwhich the ice aker sits , after removed pry off the white cover if ice maker and look at the center gear. sometomes the tabs holding that gear on are broken in which case hte ice maker wont work and needs replacing(you cant sevice the main gear replace the entie assy. let me know what you find( iknow it sounds like a lot but youll be alright!!!!!
Posted on Mar 16, 2008
SOURCE: Ice maker not dumping ice
My lady friend has the same problem with her ice maker. The problem is, the ice tray is broken on the end. I took her ice maker out and found out it was broken. Its going to be hard finding a replacement since they don't make parts anymore.
Good Luck !!!
Posted on Dec 02, 2008
  • 744 Answers
SOURCE: ice maker not working
Check the following:
* Water supply to the fridge
* Open the freezer compartment and check to see if the water inlet fitting is frozen. It can be thawed out with a hair dryer....carefully
* If not the above, check the water valve, usually located on the lower back of the unit behind a cover. It may be malfunctioning or is plugged with debris
* Make sure the stop arm of the ice maker (inside the freezer) isn't stuck in the up position
Posted on Apr 27, 2009
woodchuck789
  • 4070 Answers
SOURCE: Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Aug 17, 2009
SOURCE: blue ice from ice maker
I have this problem too. Seems to be a couple of blue paper washers in the unit that the water filters through and they break up. Ive had this issue go on for more than a year now with Liebherr trying over and over not to claim responsibility. Ive sent them the blue washers and photos and all to get analyzed and they simply do not call me back. Their service center didnt even know there were 2 blue washers in the unit. Seems to be a mess. In any case I still have a very large amount of blue paper dust in my ice and its unuseable. Any solutions?
Posted on Dec 16, 2009
The ice maker in my Samsung French door refridgerator keeps getting frozen up. Help
hi Delunn.
this could be a couple of things wring.
so i think it best you go to this link and see if it helps you out.
ice maker in my Samsung French door refridgerator keeps getting frozen up...
Dec 02, 2017 | Samsung Refrigerators
My Samsung refrigerator Model RFG297HDRS-XAA has 15-E code flashing.
Existing error codes for Samsung fridges run from 1 up to 13, in the majority of models as far as I could find out.
You might be having two error codes instead of one code
error 1 and Error 5.
Error 1 refers to 1. Ice Maker Sensor:
Ice Maker sensor connector missing, contact failure, electric wire cut, short-circuit, Ice Maker sensor failure.
Indicates an error when the temperature sensed by Ice Maker sensor is higher than 150 or lower than -58.
Error 5 refers to 5. Ice Maker Function Error:
Ice ejector and level failed three times or more.
Jul 12, 2017 | Samsung Refrigerators
Error code 15e samsung refrigerator sise by side bottom frezer
existing error codes for Samsung fridges run from 1 up to 13, in the majority of models as far as I could find out.
Feb 05, 2017 | Samsung Refrigerators
Samsung RFG298HDRS bottom ice maker stopped making ice.
Sounds line water line inside unit that runs to the bottom icemaker is frozen.
Nov 13, 2015 | Samsung Refrigerators
Showing code 8E
This error code means the ice maker sensor is bad. On Samsung the sensor is part of the actual ice maker which you can find here.
Ice Maker For Samsung Refrigerator Model RF323TEDBSR
Sep 26, 2015 | Samsung RF323TEDBSR 31.6 cu. ft. French...
SAMSUNG REFRIGERATOR MODEL RS267 ERROR CODE 5E
Error code 5 E : Ice Maker Function Error - Ice-ejector and level failed three times or more. May simply be a trapped piece of ice which is not too rare a problem especially if the freezer door is left open too long.The ice pieces will stick to each other. It may dislodge itself or if the problem persists you may have to de-freeze it ( letting the freezer defrost over night.)
Jun 27, 2014 | Samsung RS267TDRS - 26 cu. ft. Side by...
How do i clear a error code 5e
appears related to Ice Maker Function Error
Go to the following link and you will find the meaning for each error code in the Samsung refrigerators
http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?modelname=RF217ACRS&from_osc=&idx=421434&modelcode=RF217ACRS/XAA&
May 29, 2014 | Samsung Refrigerators
RFG298HDRS/XAA error code 33 E FRIG SEEMS TO WORK FINE CONTROL PANEL IS NON RESPONSIVE TO INPUT
E-33 The initial value of HEX is under "14" for 30 seconds while
a weight sensor in operation.
Nov 27, 2012 | Samsung RFG298HDRS 29 cu. ft. French Door...
the hot thing is normal be alarm when is not hot the condenser coils run on side of walls so is normal the ec means the board under the unit is not comunicating with the display on door it means error comunicating 2 things could be wrong 1 the board is bad need to be repl 2 there is a broken wire inside door. lastime i fix this i order both door and board but i tried the board first and it work so take a chance unles you have any type of warranty then call a tech
Sep 15, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
364 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
