Question about Garden
Can I get a manual?
Choke linkage seems worn. Need to replace. Need to know what the parts are called.
    New Friend:
  • 12 Answers
Best thing to do is take it to a lawn mower repair place, the parts are not that much more expensive then ordering on line or from the company, they will even copy their parts explosion schematic for you, rather then trying to hunt a parts explosion manual down. Everyone wants money for something that should be free, especially tech manuals.
Posted on Apr 23, 2015
1997 Honda CB750 choke return problem
Hi, Ken for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Honda, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://honda-cb750-s.456789.n3.nabble.com/Carburetor-Linkage-Re-assembly-Problems-on-a-CB750K-td4051468.html
1997 Honda CB750 choke return problem Google Search
Honda Nighthawk CB 750 1991 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB750 Owner Manual
Dec 30, 2016 | 1997 Honda CB 750 Nighthawk
I need a diagram or schematic of the carb showing the throttle and choke linkages so I can set my linkage for choke and throttle
U need a service manual unless you know someone who knows what is what. Nest time you will take a picture in advance before you disassemble something.
Jul 18, 2015 | Garden
I wish to install a manual choke since the automatic choke no longer works
Brent,
Most any auto parts store will have a manual choke conversion kit for about $10us.You will have to be a little creative to hook it up. But...your engine shouldn't need to be choked once it runs awhile and is still warm. I would look for other causes like binding linkages, unhooked springs and loose carburator mounting.
Nov 17, 2013 | Ariens Riding Lawn Mower. 42 in. 19 HP...
Ford mustang problems
Your neutral safety switch is not shifted into park so you need to manually shift it into park. If that does not fix it you need to replace your linkage because it is worn out
Jun 08, 2013 | Vehicle Parts & Accessories
Choke cable 3020 won't pull out. seems to be stuck. sprayed with lubricant. no luck
hello,
If you have sprayed the cable with lube you need to make sure the cable is actually freed up you will have to disconnect it from the choke linkages in the engine, if when you do this the cable moves freely then you know the problem is in the linkages themselves lubricate all these untill it all moves freely...
Hope this helps
Kind Regards
Brad
Dec 30, 2009 | John Deere 3010,3020 Tractor Basic...
Have a 1982 Honda CB650SC NightHawk and had the carbs off and know the choke won't work.when you when you try to turn the choke off it's like the cable is
Check the routing of the choke cable and, basically, make sure it does not get kinked or pulled tight when the handlebars are turned from side to side. Then, remove any excess free play in the cable by turning the adjustment fitting that's part of the cable. You want it so that the choke mechanism on the carburetors begins to move as soon as the handlebar mounted choke lever is moved. If the cable is worn worn - or broken - replace it.
Nov 22, 2009 | Honda CBR 600 F(2)N Motorcycles
Toyota Corolla CSi hatch revving too high
Some possibilities:
--the choke cable or the choke linkage on the carburetor is sticking, holding the revs too high.
--the gas pedal linkage, the pedal cable, or its linkage to the carburetor are sticking.
--the engine computer (if it has one) is failing, or has poor connections, or isn't grounded properly.
--various other sensors (if you have them) could be failing.
--the mechanism (computerized or mechanical) calling for more fuel to the carburetor when the air conditioning (if you have it) is turned on could be sticking or not working properly.
You should be able to test most of these possibilities while the car is standing still, with the engine running. Start with the choke -- have a helper move the knob and see if the engine responds properly, especially in the "off" position. Then have the helper operate the gas pedal while you watch what's going on with the carburetor.
Have your helper turn the a/c on and off. If you see a mechanical linkage to the carburetor move when the a/c is turned on, it should move back to its original position when it's turned off.
If any of these linkages (including the gas pedal linkage under the dash) are sticking, try spraying the affected area with a lubricant (like WD-40). If that doesn't help, spray lubricant into the cables, or replace them.
If all else fails, carefully check all vacuum lines in the engine compartment. An intermittent leak (or blockage) could be affecting engine speed.
Aug 15, 2017 | 1993 Toyota Corolla
Wiper linkage broken
need to replace new cap
Nov 18, 2008 | 1996 Honda Accord
Clutch pedal linkage
This shaft is removable, and the assembly, if not worn extremely bad, can be rebuilt. The assembly is called a quadrant. You can go to the local FORD dealer, and tell them to pull up a picture of the quadrant assembly, and you can pick out the parts you need to make the repair. If the shaft has worn out the quadrant bracket, then you will have to replace the assembly.
Sep 07, 2008 | 1996 Ford F350 Crew Cab
JENN AIR LP CONVERSION PROBLEM
I'm not aware of any "choke". I would put the orifices in and see what you get. Make sure you put each orifice in the correct burner or it won't work. They are different sizes. Smallest hole goes to the smallest burner and so on. Let me know how it turns out.
Oct 10, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Garden Logo
106 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
