Question about Blenders
The blade to crush ice has broken - Blenders
  • Blenders Master
  • 1,237 Answers
Contact the distributor for the brand you have chosen to keep a secret.
Posted on Apr 23, 2015
How much will the coarse blade part cost
Amazon.com 1 cross blade 2.50 plus 3.93 shipping
Amazon.com 2 cross blades 8.49 free shipping
Amazon.com 1 ice shaver blade 3.91 plus 4.99 shipping
Jun 08, 2014 | Magic Bullet Complete 21 Piece Mix and...
Broken blade housing
I have the whole blender. White with a red glass pitcher. I have only used it twice. For ice. What would you pay for the whole blender? You would then have a back up of it all. Works fine. Just too heavy for me.
Jun 18, 2013 | Jenn-Air JBL800 Work Top Blender
Blender leaks from bottom, I first crush ice,then ingredients lkie fruit. Was purchased in May 2011.
Kitchenaid will replace it for free. Call 800-541-6390 , and ask to speak with Bea. Very helpful lady.
Sep 30, 2011 | KitchenAid KSB560 5 Speed Blender
Cuisinart Quick Prep is not working properly
I think the ice was too hard for a hand blender. I think the impact has caused the blade to separate from the shaft or caused the shaft to separate internally. If your blender is still under warranty you might be able to get it fixed. Note: none of the "Smoothy" recipes in the manual call for ice. One uses ice-cream. One uses "partially thawed frozen strawberries" and one uses sherbet.
Oct 11, 2009 | Cuisinart CSB-33 Quick Prep Handheld...
Burnt out motor?
The motor most likely burnt out. Happened to mine to.
Jul 02, 2009 | Cuisinart BFP-703 SmartPower Work Top...
Can not get Margaritaville blender to start
look for rocker switch left side of machine near bottom
Jun 30, 2009 | Margaritaville Frozen Concoction (DM1000)...
Waring Pro Blender is leaking and blade assembly is loose
I know this is an old, old post, but I could not find a solution anywhere, so hopefully this will help someone. We have a model 51BL25, similar to scottman55's blender, and it had the same problem. There are two separate nuts in the blade assembly. One holds the blade on, and the other holds the seal tight. When the latter gets loose, the blender shakes and leaks.
To fix it, first you have to remove the top nut holding the blade on. I had to get in there with pliers, but a ratchet with an extension would be perfect. This nut is right-handed ("normal"). Once that nut is loose, you can remove the nut and the blade. You will also want to remove the washer immediately under the blade (take note of which side goes up).
Now, you can pull the whole axle out by the wheel on bottom of the blender. This exposes a really thin, flat nut. In my case, this nut had come completely off, so nothing was really holding the seal together at all. Again, make sure you remember which direction the nut goes -- it is not quite symmetrical. That nut is what comes loose when the blender starts leaking. By the way, it is a left-handed nut, so it screws on counter-clockwise ("backwards"). Screw it in tight, then put the rest of the blade assembly back together, and your done. If you have the right tools, it should take only maybe 5 minutes.
Depending on your problem/model, this may or may not solve your problem. Hope it helps!
Jan 28, 2009 | Blenders
Looking for Metal blade in Black and Decker -BL12475G
If it is 2 yrs old,Just call the customer service,they will give you the parts for blender for lesser price or else go for new one.
Apr 27, 2008 | Blenders
Blenders Logo
111 people viewed this question
Top Blenders Experts
eyecam
Ross Keen
Are you a Blender Expert? Answer questions, earn points and help others
