Question about MotorGuide Boating
I have a motorguide 727 trolling motor. Having problems with my range of motion in the foot pedal
Instead of getting my full range of motion with my pedal I can get like 10 degrees turn one time and the next it's lik 120 degrees but never the same everytime I use it. It usually doesn't hold either when I have my foot on the pedal to hold my position. It seems like its slipping somewhere in the shaft. What do I do To fix this?
SOURCE: Trolling motor will not spin with out being turned by hand.
This may sound really dumb but it's worth a shot. I bought a trolling motor and it did the same thing as yours. I put up with it until I broke a prop blade. When I was changing the prop I discovered about fifty feet of monofilament fishing line wrapped around the shaft, partially melted, hidden by the prop hub. Once removed, it worked fine. Hey, try it, can't hurt.
Posted on Dec 11, 2008
  • 10 Answers
SOURCE: Replacement of motorguide trolling motor prop
Motor Guide hubs come in two different sizes - 3" and 3.5". The 3" size is more for older and lower thrust models. Newer units use the 3.5. The size differences are between manufacturers too. MinnKota's are a little bigger. If you order a new prop, the only issue may be the depth of the prop. I had to use a longer prop nut wrench to tighten the Hydrilla Hacker I purchased.
Triton72
Posted on Mar 26, 2009
  • 36 Answers
SOURCE: trolling motor doesnt work?
Most trolling motors have in-line breakers, I would start there & see if one went bad, then check the wiring under the foot pedal for broken or corroded contacts, then you will have to trace wires & make sure everything is in order starting at the trolling motor plug.
Posted on May 25, 2009
oldfishead
  • 155 Answers
SOURCE: recently purchased a used 74# Maxxum 24 volt
sound like either voltage drop or hi resistance from cables... if you test 24v at the plug then resistance is the problem and may have to rewire to a 6ga wire to carry the load, pretty simple just hook the new cable to the old one and SLOWLY pull it thru, help may be required because you dont want to loose it half way.....hope this helps...GL
Posted on Jul 06, 2009
SOURCE: Foot pedal on Motorguide is out of time with steering...
There should be a couple of allen screws on the shaft that you can loosen, which should allow you to swing the motor head in the direction you want it to be pointing for the desired pedal position. Tighten and carry on.
Posted on Jul 24, 2009
My motorguide x15 trolling motorjust wants to spin around .. it has a remote foot control
Define 'wants to spin around'?
The propeller motor is supposed to spin around :>)
If the whole motor unit is spinning around you need to clamp the motor stem.
For factory support, you can get that from the website.
Xi5 Trolling Motor Xi5 Wireless Trolling Motor MotorGuide
Jul 19, 2016 | MotorGuide FW71 FB Freshwater Series...
My trolling motor stopped working suddenly. It is a 96 motorguide 56. It is completely charged. What else do I check. I check 5 fuses by the battery as well.
First you need to check to see if power is getting to the motor. If power is not getting to the motor, then check the battery. If you are getting power to the motor, then troubleshoot starting with checking to see if power is getting to the foot pedal. From there check the switches, and make sure they all have power. If they do, then most likely it is the brushes which could be worn on the powerhead itself.
Jun 02, 2011 | MotorGuide FW40 FB 42" 12V FLXMT Trolling...
I have a motorguide fw71 fb bow-mounted trolling motor which I believe is receiving a short somewhere. I have the batteries hooked up right with a 30amp breaker going to each and often when I troll on...
Using an ammeter check for current draw and compare that with specs to determine if your draw is excessive. If motor has ever overheated and some of the windings have had the insulation burn off you will have a motor with less resistance and it will draw more current since less back emf is being generated.. Under those circumstances it can overheat and also blow existing fuses. Should that be the case you are looking at shopping for a new motor.
Apr 18, 2017 | MotorGuide FW71 FB Freshwater Series...
How do you reset remote for w75 wireless trolling motor
Its very easy:
Reprogramming the Wireless Foot Pedal or RemoteNOTE: This activation procedure applies to the foot pedal and remote.
IMPORTANT: To activate multiple foot pedals or remotes, the motor must be unplugged from the power source and then plugged
back into the power source between activating each control device.
1. Unplug the battery cables from the power source. Wait 30 seconds and then plug the motor into the power source.
2. In less than ten seconds, press and hold the "+" and "-" buttons on either the handheld remote or the foot pedal controller
simultaneously.
May 07, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
I have a motorguide trolling motor and the front
With the top off take the six screws out and lift the cable and gear out. Next put your foot pedal at mid position. Then make sure the motor is pointed forward and reinstall the slider gear and the six screws. Last put the top on and make sure the arrow indicator is pointing forward and thats it.
Mar 09, 2010 | MotorGuide Standard Motor Replacement...
Jun 01, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Boating Logo
130 people viewed this question
Top MotorGuide Boating Experts
Mike
Phil Walker
Phil Walker
Angel Joseph Jr.
Angel Joseph Jr.
Are you a MotorGuide Boating Expert? Answer questions, earn points and help others
