Question about Carrier Heating & Cooling
What is Error 4 on screen of carrier window ac dura cool
What is the meaning of FR? Coz my carrier aircon w/ remote appear n LCD FR
All the Error Codes are here, but that doesn't appear to be a normal error code. Look in the manual. You can Google it 'make model manual'.
Carrier Split Air Conditioner AC Error Codes Troubleshooting
Apr 07, 2018 | Carrier Heating & Cooling
Carrier ac e3 error and its not cooling
E3 is a bad outdoor temp sensor. You can check the wiring, possibly chewed by mouse but likely needs replaced.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 03, 2017 | Carrier Heating & Cooling
What does the code E1 mean on Carrier Model # 38KCL112313GP?
thermostat no recognizing ac unit turn off and reboot thermostat
Aug 05, 2014 | Carrier Heating & Cooling
Flashing cf after carrier ac turns off
Here is an Article that I found that has some useful information for you. http://airmaster.net/troubleshooting/carrier-window-room-air-conditioner-troubleshooting CF means Cooling Fail.
Check us out online at AC Services Boca Raton
Mar 12, 2012 | Carrier Heating & Cooling
Carrier all error cod
Hi:
You need to disconnect your AC from the power source first and connect it again and see if the problem is solved or not.
As a second step to solve the problem you should try to reset your AC and see if problem is solved or not.
Other you need to call a Carrier agent in your area.
I wish that will solve your problem.
Please don't forget to rate!
Regards.
Feb 07, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have a 51GR Carrier window air conditioner and the
TRY:
Power off (Disconnect)
Push together "Temp up" and "On/off" and reconnect power while pushing.
Jun 14, 2009 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
