Question about Kitchen Appliances - Others
How will my ice machine know when to stop making ice when full?
    Top Expert:
  • 12,962 Answers
A feeler arm will detect and shut down unit.
Posted on May 11, 2015
2 Suggested Answers
  • 112 Answers
SOURCE: Should a scotsman ice machine
Yes, all ice machines have a means of automatic shut down when the bin is full. What is the model number of your machine and your bin?
Posted on Jan 04, 2011
The machine will make a couple of cycles of ice then stop. If i turn it off to clean then turn it on it will work for a few more times but then stop again. Any ideas?
Sounds like the bin switch. If it stays in the open position then the machine thinks it is full of ice and go to automatic shut down.
Sep 19, 2015 | Manitowoc Ice Machine QD-0212A Air Cooled...
Ice maker does not make ice
there is sometimes an armature that raises when the ice tray is full.you can raise this arm is you want it to stop making ice.look said arm and lower down into on position.it will fold down into a spot near the full level of the ice tray.
Aug 20, 2014 | Refrigerators
Scotsman ice machine water runs continually never shuts off. It will make ice but really racks up water bill. It is as if the float never senses the reservoir is full. What is my problem?
OK is the bin full of ice to where the ice stops making ? and is the water running over into the ice bin. If this is whats happening then cut the machine off, If water is still coming into sump tray then pull the water inlet valve and replace it. If the water stops when you shut the machine off then check the water float or sensor since i don't know what model you have, If float then replace it , if probe sensor then replace it. Now if there is no water running over into ice bin during freeze cycle then nothing is wrong ice machines use a lot of water every time it go's into a harvest it dumps the water in the sump tray.
Jan 12, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
The machine is good , up and running but it does not stop till its over flowing..how do i look for the stpping device for the machine once its full .??
the bin stat is either out of place or is not adjusted correctly. The machine should stop in no more than 10 seconds after the sensing bulb is submerged in ice. Make sure the bulb is mounted correctly and they come out of their holders on a regular basis.
Sep 30, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I have a model # f-450 mah ice machine. After the bin gets full of ice it stops making the ice but the water continues to run and runs out of the machine. Any ideas on how to stop this?
Sounds like the water valve is stuck. Probably needs replacing. Turn off water after machine shuts down and see if water stops. If it does, water valve is most likely the issue.
Mar 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Should a scotsman ice machine automatically stop making ice once the bin is full
Dec 16, 2010 | Scotsman Ice Machine, Cuber, 1930 lb....
Ice machine has stopped making full amont of ice
you need to clean the eyes on the unit they tell the unt if its full or not,
May 23, 2009 | Refrigerators
Bin control
The bin control shuts it off when the ice bin is full. Without a bin control it should keep making ice and never stop.
Dec 27, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Broken Ice Machine
check the fill cup on the back of the ice maker if it is full of ice then thaw it out, if it has ice in the fill cup no water can get into the ice maker cavity
Apr 09, 2008 | Refrigerators
Ice maker not making ice.
the infa red sensor should be on constant if the switch on the right is in the on position, if the ben is enpty
if the ben is full the beam will flash interpting the ice maker from making ice untill the level of ice drops down below the holes in the bin then it will make ice again
beam part number if needed is4389102 it comes as a kit with the emitter and reciever boards
Dec 28, 2007 | Whirlpool ED5SHAXM Side by Side...
Kitchen Appliances - Others Logo
378 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
