Question about Snakebyte PREMIUM FITNESS BOARD
My Snakebyte has a red check mark when it checks the status of the board and says it is not operating correctly. How do I correct?
When I go to options and check if the board is operating correctly I get green checks on three corners but a red check in the upper right corner. I would like to know how to correct this
Failed to send test email,please check the parameters or network status. How do i fix this all is good
on the tool bar at the top of e-mail page , you will see an accounts tab
click on that then click on the properties tab
click each tab and check that every send and receive address is correct and all other information is correct
next check the receivers address as any space , mark or anything out of text will stop it from going
Dec 23, 2017 | The Computers & Internet
How do i check the transmission fluid in my 2007 saturn ion level 3 2.4 coupe
There is a RED color coded dipstick under the hood. The fluid is correct when level is in the crosshatch mark on the dipstick, while the engine is running at operating temperature. Use Dextron II fluid.
May 29, 2017 | Saturn Cars & Trucks
Electrolux dishwasher error code 11
You are experiencing a drain valve issue. Main Control Board timedout before receiving status of drain valve. Check wiring between Main ControlBoard and drain valve. If correct, replace drain valve. If error still exist,replace Main Control Board.
Jul 21, 2012 | Electrolux Dishwashers
I cant connect internet
I would recommend a basic ping command to 127.0.0.1 in the terminal to make sure your card is working. If so, and you know your network is set up correctly check your hardware status in the control panel. Is it set up correctly or is it using another device ie the wired network card while you are "using " wireless.
Cheers
Joe
Dec 30, 2010 | Red Hat Enterprise Linux ES Basic Edition
Status Light Problem
Is the status light yellow or red? If it is yellow, then check the dust filter cover. That cover might be off or not secure. If the status light is red and blinking, then try unplugging the TV for a minute. If the error doesn't resolve the TV needs service. If it is out of warranty, you might want to open up the set and look for any obvious problems on the circuit boards (scorch marks, soot, bulging or leaking capacitors (look like cylinders on tripods)).
I hope this helps.
Jul 19, 2010 | Mitsubishi WD-62528 62" LCD HDTV
Red protect light stays on diode inside of amp has black mark next to diode
Use a multimeter to cehck for a short on the diode as you have mentioned a blackening. if so disconnect and test out of circuit. if this is short you have the culprit, if not check the power output section for a short. check also on the speaker connections/ the wires for any short.if so trace and correct. I hope this short will change the status of the protect. Good day
Jul 05, 2010 | MTX X Thunder 600XD Car Amp
Power light flashin orange, status light flashing red on WT610 NEC
if the status light is flashing .5 seconds on and 2.5 seconds off - you need to replace the lamp cover correctly.
if the status light is flashing .5 seconds on and .5 seconds off in 2 - 6 cycles the error is: 2 cycles - the projector is overheated. Move the projector to a cooler location, or/and remove dust in the light path. 3 cycles - the power unit is not working correctly. 4 cycles - the fans are not working correctly 5 cycles - lamp fails to light. Wait a full minute and then turn on again.
Jan 25, 2009 | NEC WT610 DLP Projector
Error code c-5102 in Konica minolta c252
Here’s your GEEK-steer …
This thread appears to cover the solution to your problem related to error "C5102: Main Motor’s failure to turn":
http://www.copytechnet.com/forums/konica-minolta/15515-c252-m1-operation-test.html
In addition, here’s the link to “Bizhub C250P” related support downloads:
http://kmbs.konicaminolta.us/content/support/supporthome.html
Hope this helps, and please post back with a status report and/or any further assistance you might need.
"Today's the best day of my life...and NOW you're part of it!"
Dec 15, 2008 | Konica Minolta bizhub C250 All-In-One...
GA-M57SLI-S4 wont power up !!! what to do !
Hi check the cables from the case to the mother board. They should be marked and the manual that came with the board ,this show you where to connect them on board The std markings are HDD [red led] PWR S [powerswitch] RSW [reset switch] PWR LED [case power light] in most cases check to see if this is correctly connected
To test if there is no fault in the board or power pack. first visualy check the board to see if it shows a red led light when the power is turned on, if not the problem is in the power pack or the wall outlet.
second if the light is on, bridge the pins marked pwr switch on the board with a screw driver and this should start the computer, check the processor and ram if not you have a faulty board.
Sep 17, 2008 | Gigabyte GA-M57SLI-S4 (4719331821180)...
Sound
Make sure your volume is not on mute. If the speaker icon on your lower right has a red x means its on mute. To test go to control panel and double click sounds and test. If Windows sounds work without speakers then problem is with speakers. Make sure volume is up, make sure its properly connected to correct output jack (usually green or light green). Also make sure speaker power on. If those things are correct check your device manager ( right click my computer) select "manage", click on "device manager" and on right pane check to see if theres any yellow exclamation, question mark or red x on the sound device section. Yellow exclamation or question mark means to update or install correct drivers. Check your speaker box if it comes with a CD.
Jul 29, 2008 | Dell Inspiron 530s Desktop Computer...
Snakebyte PREMIUM FITNESS BOARD Logo
234 people viewed this question
Top Snakebyte Video Game Consoles & Games Experts
James Wishart
Are you a Snakebyte Video Game Console and Game Expert? Answer questions, earn points and help others
