Question about Britax Baby Gear
Can I repair brakes on a britax b smart 2011 - Britax Baby Gear
Car seat adapter for britax chaperone
Being different manufacturers, it is very unlikely an adapter is available. Think Toyota engine parts being used on a Nissan.
May 02, 2013 | Peg Perego Duette SW Complete Double...
Can you get replacement wheels for a britax b smart 3 2011/12 edition I think it is ?
I couldn't find any information about replacement wheels for the Britax B Smart 3 online, but you can contact their spare sparts customer service by email at:
spares.uk@britax.com
Feb 05, 2013 | Baby Gear
Britax voyaga ultra rear brakes can you replace
Not as far as I know (I own a stroller repair company). We can fix BOB brakes, which is owned by Britax, but are unable to buy Britax brake parts.
Have you tried contacting Britax directly?
Dec 25, 2012 | Britax Blink Baby Gear
Binding on front brakes
CAR BRAKE PROBLEMS
It can be issue with master cylinder or the problem is there is still some air there in the system that has to be bleed. Or else the parts replaced are not aligned properly/.I suggest everything back.
There are few help links mentioned below to troubleshoot the issue.
Click the link below and follow its procedure: -----
All types of brake problems and repairs
http://howtobyme.blogspot.com/2011/11/abs-and-service-light-comes-on.html
Brake Fade Issue?
http://whoisbyme.blogspot.in/2012/07/brake-fade-issue.html
Brake System Troubleshooting?
http://technoanswers.blogspot.com/2011/11/brake-system-troubleshooting.html
Car Brake lines have no pressure?
http://schematicsdiagram.blogspot.com/2011/12/car-brake-lines-have-no-pressure.html
Car Brakes Dragging?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-dragging.html
Car Brakes grabbing?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-grabbing.html
Car Brakes Making Noise?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Brakes Pulling?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-pulling.html
Pulsating Brake Pedal?
http://repairhelpcenter.blogspot.com/2011/12/pulsating-brake-pedal.html
Spongy brake pedal?
http://repairhelpcenter.blogspot.com/2011/12/spongy-brake-pedal.html
Hard Brake Pedal?
http://repairhelpcenter.blogspot.com/2011/12/hard-brake-pedal.html
Fading Sinking Brake pedal?
http://whoisbyme.blogspot.in/2012/06/fading-sinking-brake-pedal.html
Feels Like Brake pedal Pulsating
http://repairhelpcenter.blogspot.in/2012/06/feels-like-brake-pedal-pulsating.html
What is Brake Drum Bar?
http://repairhelpcenter.blogspot.in/2012/02/what-is-brake-drum-bar.html
ABS light stays on but brakes work fine?
http://howtobyme.blogspot.com/2011/11/abs-light-stays-on-but-brakes-work-fine.html
Vibrations while braking On Chevrolet Van?
http://technoanswers.blogspot.in/2012/04/vibrations-while-braking-on-chevrolet.html
Dragging brakes?
http://howtobyme.blogspot.in/2012/03/dragging-brakes.html
Brake pedal stuck?
http://howtobyme.blogspot.in/2012/03/brake-pedal-stuck.html
After replacing brake rotors and pads, brake pedal remains on floor?
http://technoanswers.blogspot.in/2012/02/after-replacing-brake-rotors-and-pads.html
How to replace Brake Power Booster?
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-brake-power-booster.html
1997 Chevy Tahoe Brake lights not working?
http://technoanswers.blogspot.in/2012/02/1997-chevy-tahoe-brake-lights-not.html
How to service Drum brakes?
http://repairhelpcenter.blogspot.in/2012/02/how-to-service-drum-brakes.html
What type of problems usually noticed on Drum brakes?
http://repairhelpcenter.blogspot.in/2012/02/what-type-of-problems-usually-noticed.html
How to test Drum Brakes?
http://repairhelpcenter.blogspot.in/2012/02/how-to-test-drum-brakes.html
Brake Bleeder Screw Function?
http://repairhelpcenter.blogspot.in/2012/02/brake-bleeder-screw-function.html
Toyota Tundra: Parts diagram to replace Brake Drums?
http://technoanswers.blogspot.in/2012/06/toyota-tundra-parts-diagram-to-replace.html
Squeak and grinding sound is heard when brakes are applied?
http://technoanswers.blogspot.in/2012/02/squeak-and-grinding-sound-is-heard-when.html
Brake Pads Inspection on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/brake-pads-inspection-on-acura-integra.html
How to remove Brake Pads on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-brake-pads-on-acura.html
How to remove Brake Disc Rotor on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-brake-disc-rotor-on-acura.html
Brake Caliper OVERHAUL on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/brake-caliper-overhaul-on-acura-integra.html
How to remove Brake Caliper on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-brake-caliper-on-acura.html
How to remove Parking Brake shoes on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-parking-brake-shoes-on.html
How to remove Parking Brake Cable on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-parking-brake-cable-on.html
Brake pedal is pulsating and vibrating?
http://repairhelpcenter.blogspot.com/2012/01/brake-pedal-is-pulsating-and-vibrating.html
2002 Ford Windstar: Brake Warning Light ON dash?
http://schematicsdiagram.blogspot.in/2012/06/2002-ford-windstar-brake-warning-light.html
These details will help.
Thanks.
Dec 10, 2012 | Cars & Trucks
The 2 clips that attach the body section to the chassis on the Britax b stroller have sheared off (during airline transit) can this be repaired or replaced?
hi my advise here is to contact britax direct due to the saftey if you try to fix yourself
they will advise you on what to do
please tell me what counry you are in please if you need contact info i will post it here for you
Feb 15, 2011 | Britax B-Ready Stroller - Black
How do you attach britax cosytoes to their b-smart 3 pushchair?
hi
here are the instruction for the buggy the pages you need are 25-26
http://www.britax-roemer.de/uploads/cms/file/091112_B-Smart_D-GB-F.pdf
Oct 18, 2010 | Britax Baby Gear
Britax vigour removing the seat to clean, how do I do it? Confused with how to get it off the seat reclining lever
Its like a bike brake cable. It was fiddly, but we managed it. If you get stuck, try taking it to a local bike shop who could undo it for you.
Aug 28, 2010 | Britax Vigour Standard Stroller
Repair of Britax car seat
HI,
If you email service.uk@britax.com they will be able to let you know.
I hope this helps.
Nov 23, 2009 | Britax Baby Gear
Britax Vigour 4 main bracket broken
Ya you can contact britax directly and they will be able to help you. Or if you live in London there is a company called buggy pitstop that does repairs and cleaning on all different brands of pushchairs, they are very good.
Sep 29, 2009 | Britax Vigour Standard Stroller
Baby Gear Logo
218 people viewed this question
Top Britax Baby Gear Experts
thegtw
CheckitRight
CheckitRight
Jennifer Rock
Jennifer Rock
Are you a Britax Baby Gear Expert? Answer questions, earn points and help others
