Question about Sewing Machines
How do I fix my Viking sewing machine model6010 it only runs in reverse
I think it is mechanical because I have tried the cleaning oil and hair blower
    New Friend:
  • 186 Answers
Probably a stuck slide block which is common on these machines.
Usually not a difficult repair but the back cover needs to be removed and the mechanism oiled.
Posted on May 10, 2015
RickE1
  • 202 Answers
SOURCE: Viking Husqvarna model 6440 gets stuck in reverse
There are numerous things that can cause this, some very simple, some less so.
1. Fortunatly, the most common one is also the simplest to cure. When you turn the selector (upper left) knob between stitches, one of the things that is happening when you feel the resistance is that it is lifting the followers off the camstack so that it can move to another stitch. When the camstack is normally doing its job, lifting the feed cam follower is what puts the mechanism in reverse. So, while the selector is between stitches, the machine is temporarily in reverse. Also, the dots where the dial is to be placed to change the camstacks is between stitches, so if the dial is on these dots or anywhere else except snapped into a stitch, you will get nothing but reverse.
2. The buttonhole mechanism is stuck in the reverse portion of the buttonhole. Usually if this is the case, the needle position will also be stuck on the left side, and the width control /buttonhole control will not function correctly. Usually you can correct this yourself and I'll explain how in a bit. It is usually caused by lack of use of the buttonhole mechanism.
3. Either the arm that connects the camstack to the stitch length block or the block itself is stuck. Both these parts are spring loadedto bring them in the forward position, so long periods of rest are a contributing factor.
All of these causes except for the first one are because of the mechanism not being exercised frequently enough. These older Vikings do not like to sit still very longYou should fully exercise all the knobs at every sitting.
Ok, try this fix. And this is to free up the mechanisms that are probaby stuck from non use and old oil and grime buildup. Take your seamformer (cam) out of the back. Find a hairdryer and blow some heat in there for awhile. This will soften up any hard oil or grease that may be causing the mechanisms to stick. Then if you can it would be best to have what is called TRI-FLOW oil (the BEST) and spray or drop quite a bit into there covering the mechanisms and let it soak in. You might try a good sewing machine oil soaking or WD-40 in small amounts. Little by little test your knobs, slowly working whatever is stuck lose. Never force the issue. Small amounts of movement little by little will eventually free it up.
Good luck. Hope this helps. If this does not help you may have to take it to a technician and hopefully you won't find out that your take up slide isn't broken which is a major job.
Posted on Nov 25, 2007
SOURCE: Viking sewing machine
http://www.sewusa.com/
Go here! FREE!
Posted on Feb 09, 2008
  • 323 Answers
SOURCE: reverse sewing button stuck HELP!!
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
Posted on Jun 05, 2008
SOURCE: Husqvarna Viking Sewing Machine 6020 sews in reverse
Take it in to be serviced by authorized Viking repairperson. I understand that for ~ $175 they will disassemble your machine, remove all the hardened grease from gears, calibrate the gears & set tension correctly, etc. A small cost considering these older mechanical sewing machines are GEMS and will provide you another 60 years of sewing bliss if taken care of properly.
Posted on Jan 24, 2010
Sewtech1
  • 69 Answers
SOURCE: Viking 2000 6430? sewing machine, only sews in reverse.
Your stitch length dial is stuck. Your machine is in need of oil. If you open the back of your machine and see the bit that moves when you turn you stitch length dial. oil that bit and warm it with your hair dryer. It should become loose. It take a bit of warming and working the oil into the machine. You have to repeat this process a few times.
I do have the service manual at sewingnz@gmail.com
Posted on Jan 26, 2010
Viking 6690 will only sew in reverse what to do
The reverse mechanism has a tendency to stick in these machines. Unfortunately, putting oil on it will not make it come loose. You need to find an authorized dealer that knows your machine and they can take care of it for you. Some areas of this machine must be disassembled to be cleaned properly.
Oct 31, 2011 | Husqvarna Viking 1
Machine only sewes in reverse have cleaned and lubed machine
If this is a 2000, 5000 or 6000 series Husqvarna Viking, you have not cleaned the reverse mechanism fully. It will come loose when completely cleaned and lubed.
Sep 06, 2011 | Husqvarna Viking 1
Our sewing machine is only running reverse (backwards) Can you please provide me we an service manual, type husqvarna 2000, modell 6440
You can find the service manual here.
http://www.sewingnz.com/categories/Husqvarna-Viking/
and a video on this page.
http://www.absolutesewing.co.nz/SewingHusqvarna.html
Your husqvarna 2000, model 6440 machines mechanical parts are in the need for a good clean and oiling. There is an explanation to this on the blog below.
http://sewingnz.blogspot.com/2011/04/repairing-reverse-on-husqvarna-2000.html
Apr 01, 2011 | Husqvarna Sewing Machines
Jan 25, 2010 | Husqvarna Sewing Machines
My reverse button is stuck and so I can only sew backwards.
When this happens, it's usually because the machine has not been used for awhile or the reverse button has simply not been used much. The old grease (or oil) in the machine has become sticky or has hardened slightly and now the mechanism won't move freely. The mechanism most often has to be removed from the machine, disassembled, cleaned and put back in the machine. I can't tell which model you have but this problem is not typically one you can fix at home, it requires a trip to your service technician.
Oct 18, 2009 | Husqvarna Viking 1
Viking sewing machine model 6430 will only sew backwards
Th cam stack gears have gummed up on you you can try getting the back cover off along with the side and soaking the machine down with wd-40 and running it while forcing the reverse button in and out if it breaks free try and soak up as much of the wd-40 as you can and then oil anything that moves. I know this may be discouraging but viking no longer supports this machine and you might be better off taking it to an older viking dealer for help.
Jul 14, 2009 | Husqvarna Viking 1
It doesn't need a part for this repair. The reverse mechanism inside the machine is seized from old grease which has hardened. It should be seen by a technician so the part can be cleaned out. Don't be surprised if he finds a broken take up slide or a cracked pattern mechanism.
Get an estimate before you have any work done and ask about a warranty for the work they plan to do.It may be less expensive to buy a newer machine.
sewman7
May 02, 2009 | Husqvarna Viking 1
Viking sewing machine 21E
Yes you can oil it, but you need a solvent, like terpentine, to clean the inside of old grease and sticky oil. Best done by a authorised technician.
Dec 06, 2007 | Husqvarna Designer I
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
