I need the codes for the norcent tv to program it with the one for all remote.
    Top Expert:
  • Televison & ... Master
  • 75,571 Answers
0182,0188,0174,0170. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Posted on Apr 23, 2015
    Top Expert:
  • 10,875 Answers
Manual code method
1. Press and hold the SETUP button until
the red indicator stays on, then release
the SETUP button.
2. Press and release the desired mode
button (TV, DVR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4-digit code from the code
tables (on separate
sheet). Note: after a
valid code entry, the
red indicator turns
off. For an invalid
code, the red indicator
?ashes.
4. With your device on,
press ON/OFF. If the
device turns off, no
further programming
is required. Note: If
some buttons do not operate your
equipment, try one of the other codes
for your brand.
If your device does not respond after you have
tried all the codes for your brand, or if your brand is
not listed, try searching for your code by following
these steps.
1. Manually turn on the device (TV, DVR, etc.) to
be controlled.
2. Press and hold the SETUP button until
the SETUP button.
3. Press and quickly release the desired
mode button (TV, DVR, etc.). The red
indicator blinks off once.
4. Press the CHAN+ button repeatedly
(up to 300 times) until the device to be
controlled changes channel.
The red indicator blinks off
with each button press. If
you accidentally overshoot
the code required, press the
CHAN- button to backtrack through the library
until the device changes channel. Pressing
CHAN+ changes direction to forward again.
5. Press and release ENTER to install the code.
Most users will store DVR codes under the DVR
button, Cable codes under CABLE, etc. If
(for example) you want to store a DVR code
under CABLE, ?rst follow the procedure
for Direct Code Entry (page 7) and press
enter
there are a few one for all remotes,if i knew what one i could help you more,i will list links to each manual for each one,
cant find any codes,buy a new remote for your tv here,,
Norcent RC00169P L19W698 L22H998 L22W898 L24H898 LT 1931 LT1931 LT 2231K...
SOURCE: Remote code for Emerson SLC195EM82 TV
Here is a list of remote codes for Emerson TV: 004 009 014 023 024 025 026 027 030 032 033 034 035 036 037 038 039 040 041 042 043 045 046 049 053 116 135 147 177 179
Give them each a try (a pain I know) and please rate me if they work!
Take Care,
-WN
Posted on May 06, 2008
SOURCE: Universal Remote codes for Norcent Plasma HDTV 42
Try other manufacturers' codes. I used 10178 (a code for MGA TV) and it worked on my Norcent. The other codes for MGA are 10150 and 10030.
Posted on Aug 14, 2008
  • 21 Answers
SOURCE: Programing Code for RCA Universal Remote Control
It does not have any code.
Posted on Oct 22, 2008
SOURCE: TV remote code for Norcent lt2720
I'm pretty ignorant on a lot of this stuff, so no bets here, but I did get the Dish network remote to power a Norcent tv on and off by using the code posted in the manual for an NCT television. Good luck.
Posted on Jan 18, 2009
  • 20 Answers
SOURCE: I need codes to program direct tv remote (20.0IR EchoStar 158926)
Press 'Menu'
Scroll to 'Customer support' and Press Select
When the application loads you'll see the codes menu.
Posted on May 30, 2010
Need a remote control for my Norcent LT-2231 TV
Hello
Just buy one PHILIPS UNIVERSAL REMOTE CONTROL MODEL NUMBER [CL 034]. Your Norcent TV is listed it its codes. Codes are:
0223 0905 0207
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
Feb 16, 2011 | Norcent Technologies2703 27" TV
What is the norcent tv romote code for time warrner cable???
Looks like Time Warner uses basically 9 different remotes. Not knowing which one is yours im giving you the link so you can choose which remote is yours and find the codes.
I check one of them and found these codes 1089, 1589, 1590, 1365, 0748, 1591, 0824 for Norcent so I bet you will be up and going in no time.
Click the link. Click the picture of your remote then select device which is tv then select brand which is Norcent. It also gives you complete instructions on how to program the remote.
Good Luck!!!
Nov 25, 2010 | Norcent Technologies Televison & Video
CANNOT PROGRAM REMOTE TO NORCENT TV
hi are you use universal remote if yes let me think that u use RCA UNIVERSAL REMOTE do this press and hold on remote the TV button at same time press and hold power button on remote solid light until come up then press N HOLD play for five sec until your TV sleep then press and hold REVERSE EVERY 2 SEC until your tv comes up then press stop, do all that when you are point to your TV . good luck.
Apr 28, 2010 | Norcent Technologies LT4247 42 in. LCD TV
Tv would not respond to remote control comands .I just got a new remote control
You may need to program the remote with a code. The remote codes for the Norcent TV's are...
0216
0043
0056
Once you program the remote to one of these codes it should work!
Nov 09, 2009 | Norcent Technologies LT-2022 20 in....
Can't find code for Norcent or Avorcent television
Here are the codes that I got from my new Philips remote: dvd players.... 0294 0899 0394 0194 0494 TV...0223 0905 0207
Sep 02, 2008 | Televison & Video
Program the remote
try the auto scan feature explained in the instruction manual for the remote
Jun 09, 2008 | Norcent Technologies LT-2722 27 in. LCD...
Remote Codes
I purchased mine in April 2006 and was told by the cable installer that it was one of the few with NO code so I have to use my cable remote for on/off & volume, bummer!
Mar 19, 2008 | Norcent Technologies LT-3222 32 in. LCD...
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
