Question about Refrigerators
My refrigerator water dispenser is intermittently spitting out water from the door approx. every 15 - 45 mins. It is only 2 years old. Should I replace the water inlet valve?
  • Refrigerators Master
  • 5,323 Answers
USE A METER TO TEST THE WATER INLET VALVE FOR VOLTAGE AND FOR OHMS, THE COILS MAY HAVE GONE BAD, THIS IS A LIVE TEST SO UNPLUG THE UNIT B4 TESTING FOR VOLTAGE VOTAGE SHOULD BE 120
Posted on Apr 27, 2015
    Master:
  • 481 Answers
It needs to be determined if the valve is causing it or if the electric control to the valve is (e.g. bad dispensing switch, bad control board).
  • You can try disconnecting power to the valve and see if it still does it.
  • You can connect with jumpers a 120 volts lamp to the solenoid valve connector jack instead of the valve and see if any electricity is bleeding thru intermitently, easier to see than using a voltmeter since you may need to wait 15-45 minutes.
Posted on Apr 28, 2015
LOUD BUZZING SOUND WHEN DISPENSING WATER THRU THE DOOR
The water control valve on rear of refrigerator is weakening. That is typical sound for a coil that opens the side that dispenses water or ice tray refills to vibrate or buzz when weakening. If I had you r model number I could give you the part number. They are not expensive and easy to replace. Thanks, Sea Breeze
May 06, 2010 | Maytag Refrigerators
Whirlpool Water Dispenser not working and not producing ICE.
check the fresh water solenoid on the back of the unit theres a screen in the water line to it that maybe clogged also crak the line lose gently to isure water is passing through it if not? then change the water solenoid
Jan 15, 2010 | Whirlpool GS6NBEXR Side by Side...
I've got a GE side by side refrigerator that's approx.7 years old. This past weekend, I resolved the problem of not getting water out of the cold water dispenser. After replacing the two-way water solenoid...
Check around the door gasket to see if gasket pulls off or is it held on by screws if there are screws you can separate the door and insulate the tube if no screws than replacing the door is the only repair.
Jan 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
No water from door dispenser
you have a frozen wtr line inside door turn it off for a day or 2 then try it again but this time palce a thermometer in frezeer and keep temps at 0 to 4 degrees if it drops below 0 then the line will freeze again
Oct 30, 2008 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser and Ice Maker
it might be your selenoid that closes the ice door in the chute but the water thing is says another thing might be wrong if you need service call 562-688-3627
Oct 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser not dispensing
water line or water tank is frozen intermittantly
Jun 30, 2008 | Jenn-Air JFC2089H Bottom Freezer French...
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
GE GSH25JSRSS Stainless Steel
the water line is frozen inside the door. very common ge problem. you can defrost the dispenser area with a hair dryer. it takes about 30 min to do. it will freeze up again. if the frig is less than 3 years old, even though it out of warranty you can argue with ge and youll get a new door to fix the problem
Nov 26, 2007 | GE GSH25JSRSS Stainless Steel Side by Side...
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
