Question about Sharp AL-1655CS Laser Printer
Changed the ink cartridge and the drum, now it makes the loud clicking noise during printing
    Sergeant:
    Champion:
  • Sharp Expert
  • 345 Answers
Remove the toner cartridge if you can and shake thoroughly, then try putting it back in.
Posted on Jul 10, 2015
3 Suggested Answers
CosmaP
  • 409 Answers
SOURCE: LOUD GRINDING NOISE
The black dust is toner. Be carful as it is carcenagenic (dont get it on your skin) you will need to dispose of the leaking toner cartridge and get a new one. also you will need to clean the printer very carfully to get rid of the spilt toner. A combination of spray duster and a toner hoover are the best way. do not use a normal hoover as you will kill it.
It is always possible that you have done serious damage to the printer using a non standard toner cartridge. I would recomend getting a qualified person to give the printer a good service.
Posted on Jun 03, 2009
SOURCE: making clicking noise when turned on..folding
I had the same problem. It was the fuser gear grinding against the other gears that was making the noise, and it was dirt that was hanging up the fuser rollers, that was causing the problem. I took apart the fuser unit, cleaned the rollers, greased it up and problem went away.
Posted on Feb 02, 2010
Changed the ink cartridge and drum. now it makes this loud clicking noise during printing
hope you removed all the packing material from the drum before you installed it.
Apr 23, 2015 | Sharp AL-1655CS Digital Laser Copier...
Tip
Noise while printing - Diagnosis Pt 1
<p>Unexpected noise (such as clicking, thumping, or grinding) from an branded device are heard during printer operation.<br /> <br /> <span><b>NOTE: </b></span><br /> Noises can be caused by a number of things, some of which may not be addressed in this document. This document deals strictly with the isolation and potential resolution of known noises through troubleshooting.<br /> <p>The following table describes some of the noises to be expected in a printer functioning normally:<br /> <span>Noise occurs:</span> <br /> <span>Additional information:</span> <br /> During power-up<br /> When the printer periodically makes humming and buzzing sounds as the carriage assembly moves around on the right/left side of the printer, the printer is actually cleaning the ink cartridges. This is a normal operation for the printer. This sequence may happen in the following conditions:<br /><br /><br /> <ul> <li> <p>Before and/or after printing<br /> <li> <p>During power on <br /> <li> <p>After the printer has been on standby/idle for some time<br /> <li> <p>After replacing a cartridge<br /> <li> <p>In the middle of a long print job (such as printing many photos)<br /></li></ul> During printing*<br /> <ul> <li> <p>Paper pickup: There will be some noise during paper pickup due to the movement of rollers and gears.<br /> <li> <p>While printing: The unit has printed a few lines or the paper has been fed into the printing area. There will be some noise during printing due to the movement of rollers, gears, carriage and paper (paper feed and ejection).<br /></li></ul> During paper ejection*<br /> At the end of the print job, there is a louder clicking noise as the paper is being "pushed off" to the output tray.<br /> During copying/scanning<br /> The scanner may make pulsing and dragging noises as it scans portions of the document or it may make a long rolling sound if it is doing a continuous scan. After scanning, it will make a long dragging noise as the scanner is brought back to the home position (could be on the left or right side).<br /> Post-printing with no additional jobs in the queue<br /> Post-completion of a print job and without another job in queue: At the end of a print job, there will be a noise on the left/right side of the printer as the pens are being capped. The printer may try to do this a couple of times, which is normal.<br /> Between print jobs<br /> The printer may make humming and buzzing sounds as the carriage assembly moves around on the right/ left side of the printer during the cleaning of the ink cartridges.<br /> In the accessories<br /> There may be some noise associated with accessories (ADF, duplexer, etc.) during the initial positioning and during normal operation.<br />
on Mar 10, 2011 | Office Equipment & Supplies
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
Bad printing after changing 2 inks also clicking noise not before
shouldn't be the ink. I assume you have an epson as in the picture. my ink refill kit mentions that "epson intellidge chipped cartridges" require an "ink level resetter" to complete the kit. So if you have these cartridges even once refilled the chip tells the printer the cartridge is still empty so you'll need to reset the chip with the ink level resetter.
Aug 20, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Won't print. makes loud clicking noise from right side front of unit (ink cartridge parking area)
Please have a look at the noise troubleshooter available for your printer at the HP online support site. Click here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 29, 2009 | Office Equipment & Supplies
When printing, the printer makes a loud sound
I first guess that it is the drum going out. If you have changed the drum......it is more than likely your fuser. Have you ran a supply check to get the status on your supplies?
Feb 18, 2009 | HP LaserJet 2840 Printer
VERY LOUD NOISE WHEN PRINTING WITH MY SAMSUNG CLP-300
You all say that the toner cartridge is okay, so it could be the hole OPC Image Drum or the ITB which is the tranfer Belt.
The Tranfer Belt is behind the Image Unit.
Dec 19, 2008 | Samsung CLP 300 Laser Printer
Makes noise
Click HERE for HP troubleshooting for your printer.
Jun 06, 2008 | HP Officejet 5610 All-In-One InkJet...
Brother mfc8440 clicking sounds while printing
I had the same problem when I used a refurb toner cartridge, had to replace cartridge with oem for it to print. After a while started making same noise, had to take it in to have parts replaced. Now I don't take any chances on non-oem parts, it's not worth it.
Mar 19, 2008 | Brother MFC-8440 All-In-One Laser Printer
Loud clattering noise
-Open the Front Cover. -Remove the Toner Cartridge -Remove the Drum Cartridge -Next locate the black gear attached to the end of the Drum and turn it with your fingers. -Check to see if the gear is locked, or difficult to turn. The gear will only turn in one direction. -If the gear won't turn at all, or if it catches while you are turning it, or if you hear the same noise when you turn the gear that you heard when the machine was on, the Drum Cartridge is the cause and will need to be replaced.
Jun 22, 2007 | Xerox WorkCentre XE88 Laser Printer
Sharp AL-1655CS Laser Printer Logo
59 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
