Question about Eclipse 180 4 Gb Portable Media Player Red 3.7v Li-ion Battery Hi-speed Usb 2
My computer doesn't recognize the set up program. it open the video program and not the music
When i connect it to the computer it does not open what do I do?
have you a disc it may need a program for the computer to recognize it
Jul 09, 2015 | Dane-Elec Music One MP3 Player
Can I sync two different iPods to the same computer
1. The automatic settings in iTunes and iPods will not allow you to sync two iPods with one version of iTunes or sync an iPod with multiple versions of iTunes without the content being completely erased from the iPod. 2. This can be very aggravating if more than one person in your household owns an iPod or you want to add music from a friend's iTunes library to your iPod. Changing the iPod settings through iTunes will let you sync more than one iPod on one computer.
3. Open the iTunes software. Connect one of the two iPods to a USB port found on the one computer. If a small window opens in iTunes after the program recognizes the iPod, you can close the window by clicking "No" or the "X" in the window. 4. Click the name of the iPod positioned under "Devices" on the left side of iTunes. When you highlight the iPod name, a variety of tabs will appear at the top of the iTunes program. 5. Choose the "Summary" tab and options will be listed in the middle of the program. Select the option labeled "Manually manage music and videos." If a window opens, click "OK." 6. Click "Apply" in the bottom right corner to change the settings on the plugged in iPod. Leave iTunes open. Repeat steps 2-6 with the second iPod you want to sync on the one computer.
Apr 09, 2013 | Apple iPod Audio Players & Recorders
I can not connect my cell phone to my PC computer. when i connect, it asks me must insert driver first
you must use zune to connect it
below explanation about zune :
Zune software is required to get your music, videos, and podcasts from your computer to your phone. It is used to sync music, videos, pictures podcast etc. between your computer and phone. If you don't have the Zune software installed on your computer, go to www.zune.net to download and install it.
How to Set up Zune to sync your computer and phone?
1. Connect your phone to your computer using the USB cable.
2. Zune automatically opens on your computer, if you haven't opened it.
3. Wait for Zune to recognize your phone, and then follow the onscreen instructions to Set it up.
Dec 25, 2010 | HTC HD7 Cell Phone
I bought an LG envy3 and downloaded LG outlook sync. The program works okay- but the computer doesn't recognize that the phone is connected via its USB. The music sync function works, the computer...
Music player must be closed and not running in the background when you attempt to sync. Basically you have 2 programs on your computer trying access the phone at the same time. Get the Full User Guide from LG, and set it to "prompt for Mass Storage mode," instead of "Always allow," - and when the media player comes-up on the computer, Deny or say NO, which will let you synchronize.
Sep 01, 2009 | LG enV VX9900 Cellular Phone
Ipod music is gone, but still says it has stuff on it
If you do this through itunes, it should be okay. The trouble is everytime you want to update your ipod, you will need to connect it with itunes and itunes will need to have your existing library that you created for you ipod to perform a quick and troublefree update.
If you are going to get an external harddrive you will need to re-direct where itunes is saving your music and video files. Because itunes will be using your internal harddrive for the system files (that is where windows is), it will automatically save the music to your internal drive. I suggest reloding an updated version of itunes from http://www.apple.com/itunes/ here and when asked where to install it, redirect it from C:programfiles.......to your external harddrive. This way the itunes music folder will be on your external harddrive.
Hope this helps
Nov 02, 2008 | Apple iPod MA446LL/A MP3 Player
Sync device
Open Windows Media Player - click on the Sync tab (Microsoft has a video tutorial on how to sync on their website)
or
Open Rhapsody or other music service and sync from there - detailed instructions available on music service's website
Note: if your computer does not recognize that your Mp3 player is plugged in, then you will not be able to sync no matter what program you use
Jun 18, 2008 | Insignia Audio Players & Recorders
Computer does not recognize Gigabeat Device
Check the manufacturers website for specific Vista drivers.
Mar 08, 2008 | Philips GoGear HDD075/17 MP3 Player
Videos
You need to use the sansa media converter program that came with the sansa on the CD. This is used for photos1.gif and for video. The supported files are listed on the screen once you open it.You shouldnt have any problems transferring music to it using that program
Jan 25, 2008 | SanDisk Sansa e260 MP3 Player
Help
http://www.cobyusa.com/_en/support_md_drv.php?prod_id=MPC7085
That is the video converter you'll need to put videos on.
To transfer music try using Windows Media Player, if wmp does not recognized it; open My Computer, look for "Coby Mp..." or something like that.open it and drag media to the corresponding folder.
Hope that fixed it
please rate.
Dec 28, 2007 | Coby MP-C7085 MP3 Player
I have a question
That's a slightly vague question, but I can tell you a couple things...
I guess one thing you'll want to know is how to upload stuff.
You'll first need to connect your psp to the computer via the usb cord you got with your psp. Then go into the psp settings menu and scroll up till you get to usb connection. Click that and then you'll be connected to the computer. I don't know what kind of computer you have but it should have a pop-up that tells you something is plugged in. Mine personally says something like the computer recognized a removable drive would you like to open it? If your computer does that click yes, if your computer is an older computer and doesn’t do that… go into My Computer and open the psp drive
The psp drive will contain a couple of folders
PSP
MP_ROOT
MUSIC
VIDEO
If you want to put music and pictures on your psp, all you’ll need to do is open the correct folder and put in the music and or pictures you wish to upload.
*If you want to play WMA you’ll have to go into settings and enable WMA play or else the psp won’t play them, and also make sure your photos are .jpg or .jpeg
If you want to play a video on you psp you’ll have to load a psp video converter on you computer to convert the files to the correct format. Once they’re in the correct format you’ll need to open the file MP_ROOT folder, and then open the 100MNV01 folder and place the file into the folder.
Once you’ve uploaded what you’ve wanted press O on the psp, which will bring you back to the menu.
Dec 28, 2007 | Sony PlayStation Portable (PSP) Console
Eclipse 180 4 Gb Portable Media Player Red 3.7v Li-ion Battery Hi-speed Usb 2 Logo
61 people viewed this question
Top Eclipse Audio Players & Recorders Experts
Oloyede Monsuru
juanmireles1
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
