How to fix error code c4
Not spin to dry at the end of the wash
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check pump for blockage
Posted on Apr 27, 2015
SOURCE: Will not spin dry at the end of the wash cycle
How do i get to the brush of a kenmore elite to check it. ia m having the sme problem. My washer works until the spin cycle. i here the motor running extremely loud he button rotates but washer still does not spin.
Posted on Mar 09, 2008
  • 3 Answers
SOURCE: Spin cycle error - UNB
Haier have had one or two problems with there spin,
option 1 make sure the machine is balanced perfect [no rocking at all ] use a level on the machine [ truly ] it works.
option 2 you can not wash one item [ underload the machine or overload the machine this will give same result UNB .
option 3 if you have had the machine a few months and this has just started [ clean the armature on the motor with emery cloth and a quick spray of W D 40 please plug out the machine first
0161 355 8254 if you need help , good luck
Posted on Mar 04, 2009
  • 35 Answers
SOURCE: won't spin
As previously suggested, try cleaning out the drain system. See my solution at http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Posted on Mar 30, 2009
  • 714 Answers
SOURCE: My washing machine does not spin dry the clothes
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve
Posted on Jan 17, 2010
barkencoa
  • 3463 Answers
SOURCE: H20 ERROR SPIN DRYING
The error indicates a problem with the incoming water supply.
Check for restricted or kinked inlet hose/s, check that tap/s are fully turned on and that you have adequate water pressure.
Posted on Mar 27, 2010
IM GETTING AN ERROR CODE C4-00 ON MY SHARP MX2314N. I HAVE CHANGED BOARDS, STILL NOT FIXED. HOW CAN I FIX THIS ERROR?
mx 2314n error code c4-00. You could have one or more of these bad-PTC unit, Secondary transfer PWB, PCU PWB, a connector or harness connection problem.
Apr 11, 2017 | Sharp Office Equipment & Supplies
Model SF 130lj Indicate C 4 when I try to spin. What is the problem?
c4 error code refers to the load being unbalanced. The easiest hing to do is not wash so many clothes at once. If the unit faults out with this code even with small loads, make sure the unit is level and the feet are not out of whack. If the feet are not adjusted correctly, the washer will clang and bang against the floor when it is trying to spin.
Please find this helpful by clicking the button. model-sf-130lj-indicate-c-4-when-try-u40lsvyytnuesyuv3fbafhtd-3-0.jpg
Jan 04, 2015 | Washing Machines
Hitachi sf-95kj washing machine stop and shown error code c4 when it's go to spin mode
A lot of new machines need the hoses cleaned out. The slime up. The pump gets shut down and the unit won't spin. Unplug unit before you service it to avoid shock. Top has to come off, and front also.
Nov 16, 2013 | Washing Machines
Samsung washing machine
Based on my experience, the same thing happens to me as you have mentioned that it happens every end of a cycle. I doubt if it was a fan error or a frequency error. for me, its just a simple overload for the autodrying. for example on my model. the manual says autodrying cotton-cupboard dry must be max 3 kg. since you cannot measure your wet clothes and it sometimes exceed the 3kg autodrying, that is when the FE comes out. but when i remove some clothes or spin the laundry again and put it into drying, everything works fine. when i use the machine with minimal clothes say 2kg dry, the whole cycle up to drying work fine without FE errors.
So i believe its just an error for drying overload. also the manual says nothing about FE nor Error code for drying overload.
Hope this help.
May 31, 2012 | Washing Machines
Dryer does not spin dry, water left in drum...Error code OE
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
May 02, 2011 | LG Dryers
Getting error code LO and the door will not unlock
To unlock the door on most Samsung Washing machines:
Press "end of cycle" for over 5 seconds or press "options & select" until the light goes off.
Else, try holding the buttons "dry" & "spin" together for a few seconds until the lock goes off.
Apr 24, 2011 | Samsung Washing Machines
Hitachi washing machine. Model:SF-P90DJ Fault code F9
my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
Jul 29, 2010 | Washing Machines
Washing Machines Logo
104 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
