Question about Coffee Makers & Espresso Machines
Prime light came on.did all cleaning..air drying..etc. refilled.plugged in machine. Not ready light came on and cold water started immediately coming out and won't stop till add water light comes on
  • Diane Drumm Apr 23, 2015
    Forgot to add..it is a B60 kuerig. Did not push any buttons but water just came out. Cannot access menu
  • 509 Answers
Sounds like your refill float that stops the water fill process when its full is stuck from most likely setting to dry upside down jar and jolt the machine heave up and down a few times plug it in try it do this until it stops on its own or you may have to take it apart also make sure the water line is turned back on if this is hooked up to operate on its own water supply.
Posted on Apr 23, 2015
5 Suggested Answers
  • 25 Answers
SOURCE: Keurig B70 Not Ready Message
Unplug the unit for 20 seconds- 1minute. Plug it in again. You should be able to program from the menu. Hope this works.
Posted on May 14, 2009
SOURCE: cleaning machine propt will not go away
I have the same machine and had the same issue all day yesterday. Tech support will tell you to clean the tamper (round disk behind the tan/gray "flap"), which you should do. That didn't do it for me, however, so I kept cleaning. I cleaned out the chute where coffee powder goes. Then, after turning off the machine and removing the tray, I used my fingers to go up/under/behind as much as I could get to. I found the motherload of old coffee grounds. It's hard to describe where, but it was all around that metal area in the center. Just keep poking, but use your fingers so you can feel where the coffee is. I tried q-tips, but that didn't work..you have to feel it. After I got all the gunk out, I ran a cleaning again - no tablet - and it no longer said "press rinse" at the end of the cycle. It asked me to dump the tray, and then it went to "ready"! Yahoo - saved a bundle in shipping and repair.
Posted on Aug 29, 2009
SOURCE: clean machine/machine ready light won't go away
Have experienced the same problem for the last nine months. Was finally able to solve it today by following this guide: http://www.wholelattelove.com/articles/jura_capresso_cleaning_guide.cfm
Having cleaned the shower screen I ran the regular cleaning cycle and now the display indiucates "Ready" as it should do.
Posted on Jul 31, 2010
SOURCE: Serina espresso machine water low light won't quit blinking
It just needs to be reprimed...put a cup uner the frother wand and turn the water nob all the way on...keep it on till the light stops blinking.
Posted on Jan 17, 2011
Will not complete wash cycle.when emptying first fill pump continues long after water is out then spin light and timer saver lights start flashing
It is taking too long to drain. This could be from plugged filters bue to debris or from a piece of clothing. If this is a front load machine, you can take the front kick panel off. Then you can see the drain plug and unscrew it to clean it out. Be advised that if you do this, you will get all the water that is left in the machine coming out through this opening. Get ready for it with a wet and dry vacuum etc. If this is a top loader you can still do the same thing, the problem is that you have to tip the machine to get to the filter.
May 08, 2015 | Washing Machines
Cannot get past prime funtion
Dirty tubes, manually clean,
Nov 17, 2013 | Keurig B60 Coffee Maker
I have twin 135 hp Yamaha outboard engines. Neither engine will start when cold.Putting small amount of gas into air intake and engine starts, engine starts fine when hot. Choke solenoid working
just like a car before the car start the fuel pump shoots gas in the carb or a lawnmower you gotta prime it all the gas that was in the carbs when you shut them motors off has done evaporated check your fuel cells see if there is a hand pump to prime the carbs unless its electric fuel pumps either way them carbs have to be primed
Dec 22, 2012 | Motorcycles
The display keeps flashing Not Ready. Water is full. I've unplugged the machine and plugged it back in. Why won't it get ready?
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
May 29, 2011 | Keurig B70 Coffee Maker
I submerged my 2006 700 king quad what to do? I turned off key but water filled everything. I have drained oil. Motor will turn over. I have not tried to Crank. What should I do
If water is in fuel tank, drain and refill with clean fuel. Replace fuel filter. Remove spark plug and crank engine over several times to clear cylinder of possible water. Clean and dry plug, reinstall, refill oil and try to start engine.
You may get a pleasant surprise.
Jul 19, 2009 | 2001 Suzuki Burgman 250
All leds flashing, after cleaning program
unplug it.... for about ten minutes or so
Mar 18, 2009 | Solis Palazzo Espresso Machine
Refilling system
Run a clean cycle, might sort it out,
Sounds like it is scaled
Dec 14, 2008 | Jura Capresso Impressa S8 Coffee Maker,...
Solis Palazzo - stuck in descale mode?
Are you refilling the tank during this process? You need to let in run dry, and then the buttons flash. Then, refill the tank with clean water, and let the tank run dry again.
Dec 11, 2007 | Bosch Benvenuto B30 Espresso/Coffee Maker
Coffee Makers & Espresso Machines Logo
76 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
