Question about Cub Cadet Garden
Starts first pull runs good for a minute dies like out of fuel restart runs rough dies quickly
    Problem Solver:
  • 12 Answers
Take the fuel tube out of the gas tank, make sure it is clear, check the little filter in the tank connected to the hose, make sure that is clean. If this doesn't fix it, take the carb off and clean it up, you can get a rebuild kit for it from a lawnmower dealer, and the kit is just a couple if diaphragms. It might be a pinhole in one of the diaphragms. Replace the diaphragms, making sure that the mating surfaces are really clean. Before you reassemble it, take carb cleaner and pressure spray the holes going thru the carb, then reassemble. Good luck....
Posted on Apr 23, 2015
Toro model 20333 - starts, runs rough for about 1 minute, then dies and will NOT restart. I walk away for 3 or 4 hours, come back and it will start on first pull, but repeats the whole scenario.
Sounds like a sticky needle valve or problem with the carburetor float system. After waiting, the float bowl slowly fills with fuel. Then after starting, it can't fill fast enough to keep the engine running. This unleaded fuel with Ethanol cause may of our problems with small engines today. I run non-ethanol unleaded fuel and have much fewer fuel problems. There may be some water and other "trash" in the float bowl, if it hasn't been cleaned recently sir. good luck
Jul 21, 2017 | Cars & Trucks
Car starts but will not stay running
Sounds like your fuel pressure regulator. Check vacuum connection at fuel pressure regulator. That's the only easy check. the rest may have to be trial and error, i.e replacing fuel pressure regulator and then fuel pump if that doesn't work.
Mar 04, 2014 | Volvo S90 Cars & Trucks
Trimmer starts easy and runs/cuts good from cold after about ten minutes or so it starts to lose power and run rough weaker and weaker until it dies
these little engines wear out so quickly and repairing them is not an option anymore.. I would buy a new unit for next year..
Jan 28, 2014 | Stihl Garden
95 VAN SPORT STARTS FINE UNTIL MOTOR STARTS TO MISS THEN LOOSES SPARK
I Think Your Problem Is Still With The Fuel Supply,Have You Changed all Fuel Filters,Follow All The Fuel Lines Make Sure There Are No Kinked Fuel Hoses,Some Times You Find Small Filters In The Top Of The Fuel Injectors.
Hope This Helps
Apr 06, 2013 | 1995 Pontiac Trans Sport
Starts fine runs good for a few mins and dies
Will it restart after it dies? If so, then if could be a clogged fuel filter.
Jan 31, 2012 | Dodge Pickup Cars & Trucks
Car will start and run till it starts to warm up and then it will run rough and die. I can restart it but it will run for a minute and then die again like its not getting gas. I have changed sending...
unplug coolant tempurature sensor. if it runs better, then the sensor is your problem. a bad coolant sensor adjusts air to fuel mixture, depending on temp. of engine. it will run to rich and not enough of air if bad. it will also run rough at idle. if check engine light is on get it scanned for the problem code.
Aug 10, 2011 | Chevrolet Cavalier Cars & Trucks
My buick starts and runs for a minute and dies battery power good plugs and wires good and plenty of spark. also pulled off fuel line turned key and gas did come out wondering if possible regulator for...
check the fuel preasure , also will it restart after it dies, if you have spark and fuel it should run, maybe not enough fuel preasure? thats only if it wont restart, good luck.
Oct 10, 2009 | 1995 Buick LeSabre
Fuel system
Check the fuel system, chenge fuel filter. clean the fuel tank.
Oct 16, 2008 | 1994 Toyota T100
Garden Logo
240 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
