Question about Kitchen Ranges
How do you remove door glass to clean? - Kitchen Ranges
    New Friend:
  • 12 Answers
The oven door should lift straight up with the door open to the first stop. Then there might be clips or tabs at the bottom of the door to release it from the support arms.
Posted on Apr 23, 2015
How do i remove the glass from the door
The oven door glass panel is a sealed unit that is not intended to be removed for "cleaning". The unsightly residue between panes accumulates because the metal seal expands while the oven is heating.
Jul 30, 2016 | Ovens
How to remove glass on oven door for cleaning,zanussi instruction manuals
Oven door glass is not designed to be removable for cleaning.
Jul 19, 2014 | Zanussi Ovens
How do I take the glass out my oven door model AP578X-8
Hi, I have pasted the instructions for your Smeg oven you below:
9.4 Removing the internal glass panels
The glass in the door should always be kept thoroughly clean. To facilitate
cleaning, it is possible to remove the door (see 9.2 Removing the door) and
place it on a canvas, or open it and lock the hinges in order to extract the glass
panels.
The glass panels of the door can be completely removed by following the
instructions provided below.
Warning: before removing the glass panels, make sure that at least one of the
door's hinges has been locked in the open position as described in "9.2
Removing the door". This operation may have to be repeated during the glass
removal process if the door is accidentally freed.
Removing the internal glass panel:
• Remove the internal glass panel by
pulling it upwards, following the
movement indicated by the arrows. Doing
this detaches the 4 pins attached to the
glass from their slots in the oven door.
Removing the intermediate glass panels
(on some models only):
• Some multifunction models have an
intermediate glass panel. Remove the
intermediate panel by lifting it upwards.
Cleaning:
• It is now possible to clean the external
glass panel and the panels removed
previously. Use absorbent kitchen roll. In
the case of stubborn dirt, wash with a
damp sponge and neutral detergent.
Replacing the glass panels:
• Replace the panels in the reverse of the
order in which they were removed.
• Reposition the internal glass panel, taking
care to centre and insert the 4 pins
attached to the glass into their slots in the
oven door by applying slight pressure.
You can go to the website for further information: http://www.u-manual.com/download-manual-now-for-free-10/210209/oven-smeg-ap578x-8.html#.UumokD2Sxvg
Jan 29, 2014 | Smeg Ovens
On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Aug 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
How do you clean inbetween the oven glass door?
To clean between you need to remove one of the pieces of glass...usually the inside is the best....
There are a few screws on the inside of the door theat hold the frame, which holds the inside glass...
remove the frame and carefully remove the inside glass... clean the inside of the outside glass, then clean the inside of the inside glass and then reinstall the froame over the inside glass...
Now you have a clean ove glass again...
heatman101
Nov 16, 2010 | Microwave Ovens
There are stains in between the glass on the door. How can I remove and clean this?
Hello :
Disassembling the door yourself will void the warranty and may require a service technician to repair any damage or put the door back together. It is recommended that a service technician complete this for you. It is not recommended that you disassemble the door yourself.
Things You Will Need:
Glass cleaner
Soft cloths
Glass stovetop cleaner
Steps to Remove the Glass:
Make an appointment with a service technician to remove the glass from the door.
Use glass cleaner to remove as much of the debris as possible.
For tougher stains and food debris, use a glass stovetop cleaner to aid with removal.
Once the stains and debris are removed, allow the service technician to reassemble the door.
Cleaning Through the Door Vents:
When the glass cannot be removed or is no longer covered by the warranty, there are other, more creative, ways that can be used to clean it.
Long handled cleaner
Bottle brush
Yardstick/ruler wrapped in cloth
Bent hanger wrapped in cloth
Dryer vent brush
Glass cleaner
Soft cloths/towels/long socks
Duct tape (optional)
Steps to Clean Between the Glass:
Some Microwave ovens have small vents along the bottom or top of the door. These vents go in between the glass (and are likely part of the problem with other materials getting in there as well). By inserting a towel on a long-handled stick, you can gently clean between the glass without disassembling the door.First, find the vents on the door if you have them.
It may be easier to remove the door from the hinges and lay it flat on the floor. Many microwave oven doors simply lift right off of the hinges, others will require loosening a few screws first. Replacing the door should be easy to do at the end of the cleaning and will not void the warranty.
Start by choosing a long-handled cleaning tool. There are a variety of options available, so be creative.
Secure a towel or soft cloth (long socks work well) to the handle with duct tape or other strong tape. Make sure it’s well fastened so it doesn’t come off and become stuck in the door.
Moisten the towel or soft cloth with the window cleaner or other cleaning product.
Insert the cleaning tool through the vents.
Move the cloth back and forth to remove the debris from between the glass.
Remove the cloth.
Repeat with a clean cloth until all of the debris is gone.
Replace the door on the oven and enjoy the clear, clean view.
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 30, 2010 | Whirlpool MH7140XF Microwave Oven
Glass Door stain
you can clean it but its not easy u have to remove the door put it on the floor remove the screws from the side and the bottom the glass should slide out then then u remove more screw to get the other piece of glass then u clean it and put it all back togather
Mar 16, 2009 | Kitchen Ranges
Clean Oven Door Glass
To remove oven door:
1. The oven door is held to the oven door hinges by two
screws. (One in each hinge.)
2. To remove the oven door remove the two screws.
Two screws
3. Close the door to the broil stop position and lift up.
then remove the door handle and take out all the screws around the edges of the door and pull the out side cover from the inner but a word of caution there are about three or 4 pieces of glass they are tempered and about 100 bucks a piece and most times they wont get real clean and will get messy again
May 24, 2008 | Frigidaire FES367 Electric Kitchen Range
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Kitchen Ranges Logo
52 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
