Question about Pioneer VSX-D308 Receiver
How to adjust front speaker level on vsx-d308 pioneer surround sound ?
Can't seem to turn up front speaker channel only rear and surround sound seem to turn up and center works as well.
  • Pioneer Master
  • 5,487 Answers
Did you use to be able to turn up the front levels and now you can't?
Or is it the first time you have installed it?
If it previously did then clearly there is a fault.
However if not. Then like many receivers the front volume is simply controlled by the main volume control. If this is the case then you need to adjust the other channels to give you the best sound. The best way to do this is get one of those THX DVD discs. On the menu to the disc you will find a setting for setting up the sound THX screen. It will produce a test tone for each speaker. You then adjust it for the best sound quality. This way the sound field will sound great for your living room and Dolby movies will have you jumping out of your seat when an unexpected sound appears on the left channel and voices won't get drowned out by noises from the back.
Posted on Apr 28, 2015
SOURCE: Pioneer Multichannel Receiver VSX-D508 (including cd player & tape deck)
receiver on the screen displaying power off
Posted on Apr 15, 2008
SOURCE: VSX-D308
Maybe the audio amplifier IC is damaged and you gotta change it.Good luck.
Posted on Jun 12, 2008
SOURCE: Pioneer VSX-D308 Receiver Problem
go through your mode channels to put it on surround sound
Posted on Oct 14, 2008
lynchms
  • 93 Answers
SOURCE: Center Channel not working on pioneer vsx-d608
Be sure the sound source has a center channel output ie. not a 2 channel source only, try the test tone setup for 5 or 6 channel balance, if no sound from the center channel still then it is looking like maybe the center channel is blown.
Posted on Jan 28, 2009
SOURCE: reciever only allows 2 channels(speakers) at a time.
Two solutions:
1. make sure you are sending a 5.1 signal to the receiver (my DVD player was configured to only send stereo even if I picked the 5.1 soundtrack, i had to fix that). Read the manual to see the indicator lights that would light up if you are sending a DTS signal or Dolby Digital.
2. Use the 'surround modes' to at least get pseudo surround
Posted on Feb 18, 2009
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
Pioneer VSX-818V-K Receiver
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Jan 08, 2014 | Pioneer VSX-818V-K Receiver
My pioneer av receiver vsx1020 produces same sound in front and back speakers
Try changing surround modes. You might be in 5 channel stereo mode.
Mar 14, 2013 | Audio Players & Recorders
Pioneer VSX D903S ...HOW do i adjust the rear speaker volume....it is currently much too low
You make surround channel adjustments using the on-screen GUI interface. This can be done either by using the remote (recommended), or by using the appropriate controls on the receiver. [The GUI mode is active when the GUI button and the ring surrounding the Multi-Jog dial is glowing amber.]
Nov 07, 2011 | Pioneer VSX-D903S Receiver
I have a Pioneer VSX-D510 reciever with 5 speakers and sub. The sub keeps making continual popping sounds at higher volume levels when watching movies, tv etc. Have to turn most of the way down. Also,...
Manuals help a lot.
Tell us about the speakers. Maybe they're not compatible.
As far as what to expect to hear from surrounds, that depends on the sound engineering.
Test tones for speaker setup will get it all dialed in. Page 17.
Mar 05, 2011 | Pioneer VSX-D510 Receiver
My Pioneer vsx-d308 keeps giving me an "overload" message and will not work
Do you guys know how to turn up front speakers on this amp????
Sep 02, 2010 | Pioneer VSX-D308 Receiver
Problem for Pioneer VSX-818V-K 5.1 Channels Receiver Surround sound doesn't work, display reads 2CH IN,surround speakers are enabled,automatic test will find surrand speakers
Test with an surround sound media ie. Blu-ray or DVD)_. Disconnect the front and all other speakers that are working to see if sound from the missing speakers are heard. If this doesn't work then start by tracing and checking all the wires from the receiver to the speakers for bad/shorted/open connections.
PLEASE VOTE IF THIS WAS HELPFUL. THANKS & GOOD LUCK.
Oct 23, 2009 | Pioneer VSX-818V-K Receiver
Pioneer receiver vsx-d510 sub not working
Rear Surrounds are not supported on this unit, they would be the 6th and 7th channels in a 7.1 rig. I think you mean Surrounds (channels 4 and 5 in a 5.1 rig).
Lets ponder: How is there any relationship between Surrounds and your separately-amplified Subwoofer? I don't see it, unless you inadvertently chose OFF for the Sub definition when you were in the Speaker selection menus adding the Surrounds. Look again.
Jun 21, 2009 | Pioneer VSX-D510 Receiver
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
Jun 09, 2008 | Pioneer VSX-D308 Receiver
Pioneer VSX-D308 Receiver Logo
290 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
