Question about Proform Walking Belt For The Lx 660 Treadmill. Model Number: Pftl59210
Belt is folded in the middle. How can I straighten the belt so I can use my treadmill?
  • 64 Answers
SOURCE: I lost my owners manual for my Proform 585 treadmill
Iconfitness.com
Posted on Jun 08, 2009
  • 95 Answers
SOURCE: walking belt folds
It sounds like one of the adjusted bolts or endcaps that adjusts the walk belt is broken,look at the bolts where you adjust and see if the side the belt is shifting to is broken.It may have ruined the belt also but you wont be able to tell till you correct the tracking problem.
Posted on Aug 01, 2009
  • 18 Answers
SOURCE: Running belt is sliping when on treadmill
If the front roller is stopping with the walking belt, it is the drive belt. You may be able to tighten it, if it's not too old. The easiest way is to remove the belt by turning the motor by hand while pushing the belt away from the motor. Then adjust the motor back a 16th to an 8th of an inch or so, put the roller side of the belt on the roller side of the pulley, so that you have enough slack to put the belt on the motor. Now, while you pull the belt onto the front roller pulley, turn the motor and walk the belt back on. If it won't go on, this way, you probably have the motor too far back, making it too tight. Good Luck!
Posted on Mar 11, 2010
maxtreadmill
  • 832 Answers
SOURCE: Can I glue the torn edge of my treadmill belt?
I would question why it traveled to the right and cause you grief. Before anything else run the unit and see if its going travel to the right again if it does then check right end cap for breakage. To your first question no you cannot glue the belt they use a high temperature gluing process for the seams you'll have unfortunately replace the belt.
Posted on May 20, 2010
Testimonial: "Thanks for the advice. I'll check the machine as you suggested. "
Andriod Man
  • 271 Answers
SOURCE: Hello! We have a ProForm 550 treadmill. No
several things could be happening, 1) the rear end caps that hold the roller can be broken not keeping in adjustment the roller. 2) the walking belt bad. 3) roller back or front worn(less likely). also make sure if your belt(the new one if you need it) uses lubrication or not.
good luck to you.
Posted on Feb 08, 2011
Can I fix a NB1500 treadmill belt that is bowing in the middle? I've tried adjusting the tighteners on the back and cannot eliminate the bowing in the middle.
No, you need a new belt as it is stretched because that is where it gets pounded all the time. $50 to $100 depending on the quality you choose.
New Balance 1500 Treadmill Walking Belt 20 x 119 - Treadmill Doctor
https://www.treadmilldoctor.com/new-balance-walking-belt-1500
Replacement Walking Belt For The New Balance 1500 Treadmill. Belt size 20" X 119".
New Balance 1500 Treadmill Walking Belt - eBay
www.ebay.com > ... > Fitness Equipment & Gear > Other Fitness Equipment & Gear US$94.99 - ‎In stock
New Balance 1500 Treadmill Walking Belt in Sporting Goods, Fitness, Running & Yoga, Fitness Equipment & Gear, Other Fitness Equipment & Gear ' eBay.
Amazon.com : New Balance Treadmill Running Belt Model 1500 ...
https://www.amazon.com/Balance-Treadmill-Running-Belt-Model/.../B00H4QKAOO Rating: 5 - ‎1 review
This is a 1-ply Residential walking belt, some sellers will try to sell you a 2-ply belt (claiming better quality) for your treadmill, which is not recommended for ...
Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt ...
https://www.amazon.com/Newbalance-Treadmill-Running-Belt-Model/.../B008EYOF... Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt Model 1500 : Exercise Treadmill Belts : Sports & Outdoors.
NB1500 treadmill belt Google Search
Aug 14, 2017 | Exercise & Fitness
Belt does not move after being folded up what can I do?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 03, 2016 | Proform 585 CS Treadmill - Treadmills
I have a 5.op Smooth folding treadmill that I bought in 2002 and has worked perfectly until now. the walking belt has frayed on the right side and now has a cut in it. I've tried to readjust the
Step 1:
Please adjust acordinbg the Video.God bless you
Step 2:
see the next video how to loube and rollers bearing too.
Step 3:
if you need to replace the deck belt please go to
www.fitnessrepairparts.com
Jan 07, 2013 | Smoothfitness Exercise & Fitness
Proform sports 1000 treadmill how to adjust the drive belt
HI,
Watch the following video to adjust the treadmill belt. All the treadmill's uses the same way.
Oct 09, 2011 | Proform Sport 1000 Folding Treadmill...
I have a ET-388 threadmill. however when i walk or run on the machine the sound is very heavy. can you tell me what is wrong of is it normal?
hi,
Its time to lubricate your treadmill.
You must obtain the proper lubricant for your treadmill. There are several different types. Contact your manufacturer for what type is needed. Using the manufacturer provided allen wrench, loosen the walking belt approximately 10 full turns on each side of the rear roller. Apply approximately 1/2 ounce of lubricant directly in the middle of the walk area underneath the walking belt upon the deck. Retighten the rear roller 10 turns on each side. Run the treadmill at 6.0 mph for 2-3 minutes to spread the lubricant evenly. Wipe excess lube from the sides of the belt. Walk on treadmill to check for proper tension on belt.
for make it easy for you I have added a video. ok
Jul 14, 2011 | Spirit Esprit by ET-8 Folding Treadmill
Belt on treadmill is moving towards the right and bunching up
you need to adjust the travel of belt. to do this you need a allen wrench that came with it. if you have it run treadmill at slow speed,go to the rear right at the right end cap there is a hole, use the allen wrench and unscrew slowly while watching the belt until returns to the middle. if it slips when walking go back to rear and adjust by screwing in one turn on each side until belt wont slip.
Feb 09, 2011 | Proform 380 Treadmill Walking Belt
Treadmill want fold up am i doing something wrong
Yes.... An elongation may occur within the treadmill belt... Due to stress contributed during the fold up...
Oct 09, 2010 | Cadence Weslo SL25 Treadmill Walking Belt
Walking belt folds
Jul 18, 2009 | Proform Sport 1000 Folding Treadmill...
I need help adjusting the belt on the trimwalk manual treadmill
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
May 13, 2009 | RTO 9002 TrimWalk Trim Walk Folding Manual...
Proform Walking Belt For The Lx 660 Treadmill. Model Number: Pftl59210 Logo
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
