Question about Invacare Pronto M51 Power Wheelchair
Left wheel will not move when engaged how can this be fixed
    Scholar:
  • 61 Answers
This could be a few things. You may have a bad motor, a bad cable, a bad brake unit that will not release, a bad controller.
Try the easy stuff first:
1. I would make sure the motor is plugged into the controller first. sometimes a bad connection will do this.
2. Check all the wiring to see if there is any damage to the motor and the brake (4 wires - the brake will have 2 black or white wires and the motor will usually have a red and black)
3. Listen for a clicking sound from the brake - if no click then it is very likely that it is bad.
4. Check the brushes - if they are less than 3/4 inch long, they are worn badly and need to be replaced. Usually if they are this worn the motor is going to run very rough - replacing the brushes will only be a temporary fix - you will need to replace the motors.
5.You can switch the motor leads and see if you get the same results - be careful - switching the motor leads makes everything run the opposite way (right would be left) - if the problem goes away, you had a bad connection.
6. If you still have problems, it would be best to get a tech to look at it.
I don't really think you have a bad controller. from what I understand, the chair runs, but only with 1 motor - if the controller was bad, it would not work at all.
Posted on May 08, 2015
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Left motor gears/clutch do not fully engage.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
I have a craftsman revolution riding mower and its having troubles turning to the left. model 247.28933 any ideas??
Check the steering rack cogs r
Are not missing each other as you turn the wheels left if the teeth gap increases as the wheels turn the rack is worn and will need adjusting so the teeth meat better or the rack will need to be replaced this . Part can be quite expensive I had a countax ride on same problem would not turn to the left easily or the steering wheel would just spin. Around but the front wheels did not move until you pushed them by hand 're engaging the cogs on the rack it was nearly £ 596+ vat just the parts needed to repair it
Jun 26, 2016 | Craftsman Revolution 42" Briggs Stratton...
How do I get the left wheel of a Murray snow thrower to engaged when the traction lever is engaged?
You will find there is a shear pin that has broken in the wheel that will not engage. Not sure if its a pin or bolt. I had to replace one several years ago.
Jan 24, 2016 | Murray Feiss Murray 27" Dual Stage Snow...
Left wheel does not enage, even though easy-turn lever is released
ALLEN SOUNDS LIKE BRAKE CALIPER IS FROZEN IF YOU CAN DRIVE IT GET IT TO DEALER FOR HELP
Jan 24, 2016 | Cars & Trucks
How do I fix a rear wheel that's locking up on my Toro zero turn mower?
Replace axle or check to make sure everything is still good and greased
Jul 24, 2014 | Toro TimeCutter SS4260 - 22HP 42 Zero Turn...
Front wheel gear not engaging
move wheels out to meet gear if gears stripped switch wheels from front to back
May 05, 2012 | Pentair White/Gray Legend Platinum...
When four wheel engaged truck will not move forward to the right, will move forward to the left and straight chevy 1500 03
I would suspect you may have a right or left CV joint binding on either front drive axle.
I would have the truck put on a hoist and the axle joints checked for wear. I believe you will find your answer there.
Good luck.
Jan 30, 2010 | 1999 Chevrolet K1500
Loud clicking noise when 4wd is engaged on left wheel when turnin
Check your cv (constant velocity joint) , It may have a big clearance which is the source of the noise when turning left or right and when 4wd is engage. Juts like front wheel drive cars, if the cv joint is with clearance it will tend to sound in the left or right turns. It is not exactly clicking sound , nmore like knocking sound , low in pitch, but not heavy.
Nov 17, 2008 | 1996 Isuzu Trooper
Loose brake on left wheel
You can adjust the tension in the brake cable, there are instructions in the manual. Also check that you have the brake handle in it's furthest position. It can be quite stiff and takes a bit of force (especially if new) but it may go one click more than you currently have it.
Feb 09, 2008 | Bugaboo Cameleon Jogger
Invacare Pronto M51 Power Wheelchair Logo
271 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
