Question about Garden
Looking for the fuses
I hooked up the battery cables to the wrong posts when i tried to start it
  • Garden Master
  • 2,478 Answers
Most have a fuse rear of engine on right side
Posted on Apr 23, 2015
HOW TO JUMP START
The red cable ends must be connected to the positive post on both batteries. Hooked up wrong blows a fuse
Oct 11, 2014 | 2004 Chrysler Sebring
Sorry for the lack of info The starter is new, disconnected the battery replaced the starter ad when the battery was connected the starter starts turning with out the ignition on but not engaging. The...
Well, if your starter starts to turn when you hook the battery cable up, then you have hooked the cable to the wrong post on the starter. You have two large posts and one small post on the starter solenoid, the battery cable goes on the large post that has nothing else hooked to it. The other large post should have a large braided cable going into the starter motor housing. If the starter still will not turn the engine over when it is wired correctly then you will need to look closer at the flywheel ring gear.
Sep 06, 2014 | 2007 Toyota Tundra
My wifes 2001 Honda Odysseys battery did in a parking lot. Mall security hooked up the jumpstart cables wrong (I guess) now it won't start at all. Could he have overloaded the fuse? and is there
you need to look at the fuses in the under hood fuse box f you look at the center of the fuse and see if the line is broken in the center if so its bad
Sep 23, 2012 | 2000 Honda Odyssey
Ok 1994 vw passat... battery wont hold its charge.. new battery new alternator.. battery cables look old and worn.. when I turn the key sometimes there is nothing just the fourways trun on.. I then unhook...
the wires on the positive post are the large cable goes to the starter, one of the smaller wires goes to the charging circuit and the other goes to the fuse/relay power center, now how to check for a draw on your battery, first you need to remove the battery and have it charged you can take it to auto zone and they will charge it for free. after you have the battery charged hook up the negative battery cable but do not hook up the positive cable, make sure every thing is turned off and all doors and trunk are closed, then take a 12volt test light and hook it between the positive battery post and the positive battery cable if the test light lights up you have a draw, if it lights start pulling fuses one at a time till the light goes out. when you find the fuse that turns the light out you found the circuit that is drawing on the battery. now i cant tell you what in that circuit is drawing you will have to come back on and tell us what fuse it is and we can look up what all is on that circuit, if the light stays on after all fuses have been tested unhook the alternator if the light goes out you got a bad alternator......GOOD LUCK
Jan 15, 2011 | Volkswagen Passat Cars & Trucks
Hooked up battery cables backwards now my 200
check main fuse box for ign/inj/ecm fuses.
May 25, 2010 | 2000 Saturn SL
I blew the main fuse by jump starting it. I think that I hooked up post wrong and the main fuse did its job, as the car is not mine but my sons, I want to fix it.
you will have to replace that fuse first then re try it, good idea to charge the battery with the cables off if you have to wait and get the fuse.
Jan 26, 2010 | 2003 Mazda Protege
The car lose the batery charge in one night and if I retired the B2 fuse the batery is ok I need the fuse diagram to try resolve the problem.
You need to look up the b2 fuse in your owners manual and find out every thing that it runs.With a test light hooked to the ground post of your battery and the pointer hooked to your cable,remove the negative cable from the battery.Start unplugging the components that the fuse protects and when you get to the problem the light will go out.
Oct 23, 2009 | 1994 Land Rover Range Rover County
Car wouldn't start, bought new battery, still won't start.
it sounds like the battery was drained again but this one should be under warranty.Get it running again and look into those cutoff switches that automatically shut the lights.Until then.be extra careful, maybe even leave yourself a note on the drivers door to
'shut the lights'.
Dec 06, 2008 | 1991 Honda Accord
Replaced the battery but when I go to start the fuses blow
you carnt get them to fit the terminals properly one terminal on your battery is bigger than the other,if it is blowing the fuse when you crank it over it might be a starter problem
Nov 23, 2008 | 1991 Ford Probe
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
