Question about LG 55lw5300 55-inch 1080p 120 Hz Cinema 3d Led-lcd Hdtv With 3d B
HOW DO YOU HARD RESET THIS TV. IT WILL COME ON BUT THE VOLUME GOES UP TO 100 AND U CANT DO ANYTHING BECAUSE ITS GOING NUTS. IT CLICKS EVERYTHING AT ONE TIME AND WONT LET U CLICK ANYTHING
  • LG Master
  • 5,259 Answers
That sounds like an electrical fault to me, especially when the volume goes up without touching the volume control. Take it to your TV repair place.
Posted on Apr 27, 2015
My hinsense remote is stuck on volume. I can't get to menu. the volume is on the screen it's up to 100. I try to lower it from the side panel on the tv everything seems to be stuck
Try a reset to your TV first. If it do not help, check and replace its main system control memory IC. It is faulty. The fault is with your TV; not with remote control.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Apr 24, 2017 | Televison & Video
I have a LG47LS4600 powers up but volume goes to 100 i can push vol down it will but when you let go it goes back to 100
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
Dec 04, 2016 | LG Televison & Video
Fixing my rca 46la45rq tv it only has a blue screen when i turn on the tv on i cant change the channel input or anything the volume does not work either could you please help me
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jun 22, 2016 | RCA Televison & Video
Toshiba tv 40RV52U volume locked on HIGH
May 31, 2016 | Televison & Video
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
Power outage
It sounds that the main system control memory IC data has been currupted.
Sep 26, 2013 | RCA L32HD31 32 in. LCD HDTV
The volume on my plasma tv goes up to 100 and when i lower the volume it will take a second volume for the volume to go up to 100 how can i fix my tv to lower the
The tact switch is most likely defective which is keeping the volume up engaged. Replace the tact switch should fix the issue. If not the button assembly pcb will need replacement. You can get replacement boards from www.tvcircuitboards.com
Dec 10, 2012 | LG 60PC1D 60 in. Plasma Television
Volume Control
Look for any jammed buttons (keys) on remote control and/or on control panel.
Aug 12, 2012 | Televison & Video
Hi Guys, you must be getting this a lot, but i am going nuts! I have a Hitachi 5K320 250Gb Harddrive that for some reason I cant get in anymore. I have very important stuff on there that i need for my...
I know it sounds a little nuts but try it with the drive upside down or on either side or on end supported by some books, you can also try cooling it off in a fridge for a while. when a drive starts to go and starts making clicks and vibe noises you have very little time to get everything off. before you try anything make sure you have space to save the files if you do get in.
Also look into Puppy Linux it runs in ram without running the hard drive,
Puppy may be able to read your drive.
I'll check in with you later, off to work.
Regards
TickMagnet
Aug 16, 2011 | Hitachi Travelstar 5K320 320 GB SATA Hard...
Samsung le40r74bd problem
I just had this problem with my 3 year old 32" Samsung LCD. The volume would go up and down by itself, normally just constantly going up even when it reached 100%.
I thought it might have something to do with the volume buttons on the TV itself so seeing as it was out of warranty anyway I decided to unplug it and open it up.
I gave it a good clean and I disconnected the cable for the panel of buttons on the LCD itself (volume, menu, channel etc) seeing as I never use them anyway. I then put everything else back together and tested.
It seems to be working fine now. Previously (for the past 3 hours) ever time I turned it on the volume level would come on instantly and stay on until I turned the TV off. So I’m quietly confident the problem has been fixed. But I must admit it’s only been 10 minutes, so who knows, it might come back.
Dec 18, 2009 | Samsung LE40R74BDX 40 in. LCD Television
LG 55lw5300 55-inch 1080p 120 Hz Cinema 3d Led-lcd Hdtv With 3d B Logo
257 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
