Question about Maytag Refrigerators
I have a Maytag PTB1953DR refrigerator, would the timer be shot again?
I have a Maytag PTB1953DR refrigerator. The freezer coil was frozen again so I replaced the thermostat on the coil. This is the second time. I replaced the timer about two years ago, would it be shot already?
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 310 Answers
The timer should last a lot longer than that, but I have received bad ones right out of the box. Depending on model year, the full current of the compressor and the defrost heater are present in the defrost timer contacts. The defrost heater should be checked with a volt-ohm meter if continued icing takes place. The defrost heater will have a positive ohm reading if it is okay. If the meter reads infinity or 0.0 ohms, the heater is bad.
Posted on Apr 25, 2015
Maytag French door refrigerator not cooling refrigerator.
There is a defrost coil and timer to control it, you will have to check those to see if they work, If you are unplugging it to defrost it would take hours to clear the ice.
Jan 20, 2014 | Whirlpool GX5FHTXT Bottom Freezer French...
Maytag Performa - PTB1953DR - FRIDGE IS NOT STAYING COLD, WE HAVE IT UP THE ENTIRE WAY AND IT IS COOL BUT NOT COLD. FREEZER IS STILL FREEZING BUT NOT WHAT IT SHOULD BE, ICE CREAM IS FROZEN BUT NOT HARD.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Maytag 18.9 Cu. Ft. Top-Mount Refrigerator...
Maytag side by side, MAD2432GRQ is leaking water,drain is not draining, its frozen and coils are freezing up
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 29, 2010 | Maytag Refrigerators
Maytag refrigerator, feezer side coil frozen and frigirator not
Defrost circuit failed, needs to be able to defrost the coils so air can pass through them thus cooling evenly. You can check the heaters located on the coils probably near the bottom back wall of the freezer with a ohm meter if you read through, the heaters are good, if you get no reading the heaters are bad. Or could be defrost timer or on newer models the adaptive defrost control which is a circuit board. If its an older model you can manually turn the timer with a screwdriver if you feel resistance, then you should replace the timer. Also in the circuit is the defrost thermostat located on the coils, this is the least expensive of the 3 components to replace. You should have a schematic located under the fridge, use this to determine which type of timer you have and for further trouble-shooting. Please let me know if this helps
Aug 22, 2009 | Maytag MCD2257HE Side by Side Refrigerator
Refrigerator is warm, but freezer works. Coils are frozen.
you are having a defrost problem, probably needs if it is a maytag, it probably needs a control.
Jun 15, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Coils freeze up,refridgerator and freezer stops working
The defrost cycle is not working properly, there are three things involved in system. #1 Defrost timer in refrigerator #2 Thermostat on coils to tell if unit is frozen #3 heater element located under coils thaws coils when frozen. the defrost timer if it is manual < located at the front of light assembly panel in top of refrigerator there will be a hole with a plastic piece that resembles a screw strait screw head> it turns and every 8hrs aprox. it stops operations and starts defrost cycle by allowing voltage to the thermostat and if thermostat is frozen it allows power to element for thawing coils. If defrost timer is manual look for direction it is facing and mark edge to see if timer is turning< very slow turning and is easiest way> if you can get an ohm meter ohm the element on high setting< if it has continuity element is operable> check wiring just to be sure not problem. If you find the timer does turn and doesn't stay in one position over 40 minutes then the thermostat is bad.If element fails tesing then the element is bad and if timer stays in one position then it is bad. If unit is equiped with electronic defrost timer and element is good in would replace timer and thermostat to guaranty that resolved problem
Apr 22, 2009 | Refrigerators
Maytag MZD2766GE side by side, fridge not getting cold.
Your timer for the automatic defrost is defective. Replace it. If you thawed out the back of the freezer, this could be good for 3-7 days and it will freeze up again. I had the same trouble.
Bobby Johnson
Mar 08, 2009 | Maytag MZD2766GES Side by Side...
Frozen evap coil
In the upper food section in the middle of the light/temp control panel.
Jan 10, 2009 | Maytag MBB2256GES Bottom Freezer...
Maytag wide by side.
If it happens again, check the defrost timer. If it does not self defrost, the cooling coils (evaporator) get plugged with ice and although it is frozen, the ice stops the transfer of heat. Unplugging the unit allowed it to defrost so air could circulate again.
Jul 08, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerators Logo
88 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
