Question about Air Tools & Compressors
Can my 3peak HP 4gallon pancake air ace compressor run air tools
    Sergeant:
  • 206 Answers
It will run a nail gun or two but will not run air ratchets or hammers etc. there is just not enough air volume.
Posted on Apr 25, 2015
    Master:
  • 403 Answers
Find the rated cfm the compressor is capable of producing at given pressure and select which tools meet air volume requirements.
Posted on Apr 23, 2015
  • 583 Answers
SOURCE: Need help with parts for air compressor.
Hi ,Crazy horse. information perfect . with a14.5 inch pully on the compressor and amotor running at 3450 rpm you can get with a 5 inch pully----1189.6 revs per min ---- with a 4 1/2 pully ---1071..6 revs per min so you hve to decide whether you want the max or the min from that compressor... If it was for me I would use the 5in . and set psi. with the cut in ---cut out switch ,this will be a good unit ,,if you need any more help don`t hesitate to call and thanks for the opportunityto help it is great when some one gives you good info .you did well
Posted on Aug 12, 2009
Testimonial: "Thank you so much! I had searched every where and no one could answer that question. I feel comfortable now! Job WELL done!"
roniecon
  • 6826 Answers
SOURCE: no air pressure thru quick connect to tools-bag regulator?
I dont know if it is like mine,but if you can let the air out of it and remove the regulator knob,and it`s components,you may can set it to just to be open all the time,in other words,by pass the control knob valve.Shout back at me if I can help.
Posted on Nov 06, 2009
compman66
  • 169 Answers
SOURCE: Hi, I bought a used Air Ace air compressor. 5 Peak
send me a photo of the compressor and if there are any model numbers or serial numbers and I will see if I can identify the pump for you. my e-mail is steve@morrismachineservicesllc.com
Posted on Jan 15, 2010
Testimonial: "I will get that info over the weekend and sent it to your e-mail Thanks"
atthings
  • 59 Answers
SOURCE: hdc 3 hp pancake air compressor - unable to
Try resetting the pressure switch which should have a regulating device in it somewhere.
Posted on Jun 06, 2010
  • 36 Answers
SOURCE: My Porter cable CFFN250b-2 pancake 6 gal 135 PSI
head gaskit blown
Posted on Jul 30, 2010
How to change a regulator on a bostich pancake compressor
Usually they are just threaded into the unit, Empty the air, then remove it,
Oct 11, 2014 | Stanley Bostitch CAP2000P-OF 2 HP Peak 6...
I was given a 3-HP HDC pancake compressor a few days ago and the man (he was throwing it away) said it worked although a bit slow to build up pressure and that it needed a new gasket. Is it worth keeping...
Hi app_3rp778
I would suggest that you replace the head gasket, it should not cost too much to replace it.
I would guess the gasket would be around $10-$15 usd
If you replace it yourself it would be very advantageous as the repair cost would only be the gasket.
If you take it to a repair shop, I would guess they would charge around $50-$60 usd for the repair of the compressor and replacement of the gasket
Do some research on the web for your parts or check out the webpage below.
Have the parts sent to your house...will be cheaper to take the part to the repair shop then to have them order it...they normally charge 200% on parts.
Also look at the following webpage for repair of the gasket and some more hints on how to repair a porter cable compressor pancake compressor, it is not your compressor but it will be somewhat like your compressors repair procedures.
Please take time to rate me
Bud
http://www.ereplacementparts.com/porter-cable-cf2600-type-pancake-air-compressor-parts-c-129_1662_2167.html
Oct 27, 2012 | Hdc Homer Hdc 2 Hp, 4 Gallon Pancake Air...
Runs but will not build or hold pressure
You need a qualified technician for the suction system need to be check and replaced if needed. There might some air leaks in the suction system. Thanks for asking FixYa.
Jun 14, 2011 | Hdc Homer Hdc 2 Hp, 4 Gallon Pancake Air...
Husky pancake runs in reverse
I am a little confused here ... I have a Craftsman pancake, a Craftsman 6 hp (same compressor design) and several other name brand pancake compressors at the job. The compressor doesn't care which way the motor runs though mine all run in the same direction. As long as the piston goes up and down, the reed valves know when to open and when to closed based on the pressure. It sucks in from the 'room' on the down stroke and blows into the tank on the upstroke.
Yours isn't doing this? If it is creating a vacuum in the tank, I would have to say someone put the valves in upside down.
This is very curious.
You could reverse the black and white wire but as I understand the physics of it, it will not matter where the hot wire is since it is AC. The motor may be reversable but I'm thinking it is probably not in this case. That costs extra to make into the motor.
Please inspect the valves to make sure they are capable of 'inhaling' (the site will delete the other word I used) on the down stroke and 'exhaling' into the tank on the upstroke.
Please let me know what you find out.
Thanks for your curious question at FixYa.com
Jan 15, 2010 | Air Tools & Compressors
I need a drain plug for a Clarke Air pancake two horse compressor. Model AC2001 Serial # 1005188 Where can I locate one? Dan
Master tool repair is a good web site to get things like that, they sell a lot of generic parts like that
Dec 29, 2009 | Clarke Power Products Inc AC2001 2HP 4...
Got a Husky 6 gal pancake, 1.5hp. motor runs- no air pressure ??
the regulator may be turned down, find the regulator turn it to the right to allow air into the tank, tank must have air in it to deliver air
Oct 19, 2009 | Campbell Hausfeld No.FP2028 Gal Pancake...
Air Tools & Compressors Logo
106 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
