Question about Fisher Washing Machines
My fisher & paykel intuitive doesn't spin it drains but that's it it also was getting stuck on cycles before braking down and not spinning could it be moisture do I have to change the circuit board?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
Your washer is trying to tell you something is wrong. When the cycle interrupts and the machine starts to beep, it is in "fault mode" and it is correctly trying to tell you what is wrong with it. On models that have no LCD display, (GWL10, GWL11, etc) the LED lamps that normally indicate the various stages of wash cycles become "fault code indicators". On models with a LCD display, such an IWL12 for example, the LCD display will show the fault with a description. On all Fisher Paykel washers, you will find a detailed "tech sheet" located underneath the touch module of the machine, on the left side, in a plastic bag next to the water inlet valves/mixing chamber area. This sheet contains detailed info on fault codes and diagnostics. We always ask that people first read over this sheet and become familiar with these codes and what they mean. In many instances this will get you pointed in the right direction. To gain access you must UNPLUG the washer, and remove the two phillips screws that secure the control panel frame to the washer top deck. It also helps to remove the lid for ease of removal of the control panel from the deck.(simply open the lid 3/4 of the way up and lift it right off the hinges) Be careful not to damage or tug on the wiring connector from the motor control to the touch module.
NEVER attempt to enter diagnostic mode without first re-attaching the control panel to the washer.
Posted on Apr 23, 2015
  • 92 Answers
SOURCE: IW712- fisher paykel intuitive eco.
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
Posted on Feb 22, 2008
aborcass
  • 2651 Answers
SOURCE: Fisher and Paykel Smart Dribe 608
not familliar with that exact model number ( we dont have that over here in the US) we have simalair f&p gwl10- gwl11) that problem sounds as if either the pump is bad and overheating before pumping all the water or a diverter valve is not fully closing allowing water to remain in tub.
Posted on Mar 29, 2008
  • 22 Answers
SOURCE: washing machine will not spin or drain
look at my post "eco smart won't drain, smells hot". It could be something stuck in very lowest part fo drainage area. you have to remove the motor on bottom of washer to see into this area and remove blockage.
Posted on Oct 21, 2008
SOURCE: Fisher & paykel top load washing machine
We had the same problem with our washing machine being full of water and beeping during the rinse cycle. The problem is that the filter, which is located under the washing machine, is plugged with something. Ours was plugged with a cotton swab. You have to tip the washing machine up and remove the filter and unplug it. The filter is in the center of the bottom of the machine. It twists off. I had to get the cotton swab out of inside the machine through this opening.
This machine plugs up a lot - I've never experience this with any other washing machine. Good Luck!
Posted on Nov 07, 2008
SOURCE: Our Fisher & Paykel Washing Machine is not
Emptied washer, tipped it on its side, detached drainage pipes underneath, and pulled out old fabric/lint/blockage with tweezers. Plugged in, switched on, all good.
Posted on Sep 30, 2009
Model gw 712. Why are lights 3, 5, 7, and 8 flashing?
Hotpoint, GE, RCA Washer Repair - Does not spin or drain ...
? 6:13
https://www.youtube.com/watch?v=69az-ZA3eSQ
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Hotpoint, GE, RCA Washer Repair - Does not spin or drain - VWSR4150DAWW ... Fisher & Paykel ... my washer won't drainnor spin. what is the problem? .... But in the end, this video helped me fix our washing machine.
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesHow do I remove the lid on a F&P intuitive eco washing machine to get to the motor panel?? IMadeIt ... It runs until the spin cycle and it drains but won't spin.
Dec 18, 2015 | Fisher and Paykel Washing Machines
Fisher & Paykel GW612 won't spin
you want to check the drain pump if there is nothing stuck there sometimes a drain restriction will cause the machine to stop
Jan 27, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Hi i have a fisher & Paykal IW812 Intuitive Eco washing machine it gets to the rinse drains a little water then nothing happens time still counts down but nothing happening gets to the spin cycle then...
Hi just read your posting.Unless the machine shows an error code the diagnostic mode will not help.Does the machine agitate in the wash cycle?Does the machine drain the water completely?Does the machine spin the clothes dry.Please reply with additional information on the questions I have posted and I am sure I can help you rectify this fault.Looking forward to your reply.
May 21, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Intuitive Eco switching itself off during cycle.
Could be a bad drain pump or controller or rotor position sensor. You will need a Tech to take a look. Unfortunately with these machines there can be many reasons for a failure. Call F/P to get a certified technician out there.
Jun 14, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher paykel will not complete rinse spin cycle
will sence it will spin once the water is out .that must mean your pump is restricted.unplug go to buttom of washer find pump and clean out
Dec 31, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel clicking sound
it sounds like the bearings are going out as it spins faster the noise quietens down because the bearings are more spread out and as it slows they fall lower leaving an area that it causing "friction" of a kind
Dec 27, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
My fisher and paykel smartdrive 708 stops at rinse/spin cycle with machine still full of water
with no error code ... I would check you drain pump or drain hose... you first may want to try a shop vac connected to the end of a drain hose .. let me know if it helps
Dec 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
My washing machine will not drain the water on the spin cycle. I tried re-staring from the 2nd rinse but now it won't spin at all. My washer is an Intuitive
You probably have something stuck in the pump system that is jamming the inpeller that turns to **** the water out. The machine will not spin without draining first.
Jul 05, 2008 | Fisher and Paykel Washing Machines
Gwl 10 washer
Check that the pump isnt blocked.
Mar 01, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
