Question about Air Tools & Compressors
Broomwade britishmade 1956 compressor
Manual
    Top Expert:
  • 43,064 Answers
You will never find one for that old of a unit .
Posted on Apr 23, 2015
Need wiring diagram for a single phase brook motor n a broomwade compressor
I suggest you contact Brooks if they are still in business. If not there is lots of motor info on the net.
Traditional single phase motors are fairly straightforward and similar to each other. The main thing to watch out for is to have the start and run windings wired with the same polarity. If the polarity is reversed on either winding the motor will run backwards.
Feb 06, 2016 | Air Tools & Compressors
How to rewire a broomwade 3 phase compressor 1970
Look for a stardelta wiring diagram and you need to fit a thermal cutout and also a pressure switch
Mar 12, 2015 | Air Tools & Compressors
How do i rewire a broomwade 3 phase compressor 1970
Rewire for ?? High voltage motor wiring is L1-T1, L2-T2, L3-T3, T4-T7, T5-T8, T6-T9. Low voltage is L1-T1-T4, L2-T2-T5, L3-T3-T6. The motor protection overloads will need to be sized accordingly, to the motor's FLA ( full load amps) for the voltage used. The control needs to be looked at also, if there is a control transformer, the transformer needs to be wired or repaced for the new supply power voltage used.
Where is the fuse box on a 1956 Chrysler?
If you have owner's manual it would be there. But If missing,
manual in library, or
http://www.manualslib.com/
Mar 08, 2015 | Cars & Trucks
What is the dwell on a 1956 235 6 cylinder
the dwell angle and the point gap are closely related and seldom alter unless the point cam is worn or the point rubbing block is worn To go back to 1956 I will have to open some old manuals to get the dwell so if you make a comment I will see what I can get for you. As you can appreciate the dwell angle is the degrees turned that allows maximum saturation of the coil to produce the hottest spark and that is why I mentioned that the point gap is critical to get the correct dwell.
Jul 26, 2014 | Chevrolet 1500 Cars & Trucks
Jawa Manuals cz 150
I need a manual for the jawa cz 150 (1956)
May 03, 2013 | Motorcycles
I am looking for a diagram of the wiring harness for a 1956 international pickup truck or any type of wiring diagrams for this vehicle
1956 gmc truck fuel gagage want work, i just put a new tank and sending unit still not working. any help
Apr 03, 2012 | Chevrolet Classic Cars & Trucks
I have an old model b compressor circa 1956 and the diaphragm in the switch box is leaking where will i get one from please.Many thanks,Gaz
NO SUCH LUCK, I HAD ONE WITH THE DIAPHRAGM AND THE COMPANY WAS NO LONGER IN BUISNESS HAD TO REPLACE WITH A NEWER MODEL AND DO SOME CHANGING AROUND BUT THE COMPRESSOR RUNS GREAT. ALSO THE NEW SWITCH RAN ME AROUND $76.00
Sep 24, 2009 | Ingersoll Air Tools & Compressors
Compressor fridge 1956 dead!
<grin> Not under warranty any more?
Compressors have changed some since that was built but they still do the same basic job; turn a gas into a liquid so that the circulating liquid can remove heat from the unit while expanding into a gas again.
The coolant current units use is also different but serves the same purpose so I would say your old friend can be repaired.
Compressors range from ~$120 to double that (+ coolant cost) and labor is unpredictable since we don't know where you live but it is about a two-hour job. I would guesstimate between $300-$400 US - if it is quoted at lower than that, even better.
If you are in the US, check your local Better Business Bureau website for an honest service company and if more than one is listed, I'd call to get a preliminary bid on the repair.
You might inspect the condition of the gasket since a hardened one that no longer fits flush can cost a couple of bucks a month for lost energy by running the compressor longer than should be necessary.
Oct 02, 2008 | Whirlpool ED5VHGXM Side by Side...
Air Tools & Compressors Logo
70 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
