How to find IP ?
I forgot IP of device and reset to factory default but also don`t know the default ip too . Need someone to help me out this issue Thx
  • 78 Answers
Most manufactures will have it on their website under support.
Posted on Apr 23, 2015
Where can I get an I.p. address for my tablet . Im not sure what happened , I put it back to factory settings and after that there was no ip address. Please help?
What most likely happened is when you factory reset the device, the wireless setup that you use to connect to the Internet was reset as well. You need to go into the wireless setup area and look for networks to connect to. The one that you use regularly (assuming you are where you use the device), should be among those listed. You then tell the device to connect to the network. This is where the device will ask you for the network password if it is a secure network (and most are). Once you input the password, then the network router will assign an IP address to the device and connect it to the network. After that you can access the Internet normally. If you don't know or forgot the network password, someone in the household (or business) should be able to provide it so long as you are authorized to connect.
Dec 11, 2015 | Sungale Tablets & eReaders
Forgot my password for wrt120n
Looking for the Linksys WRT120N default password? You probably have little reason to access your router on a regular basis so don't feel too bad if you've forgotten the WRT120N default password.
However, when you're troubleshooting a network problem and need to get in to the device, the WRT120N default password suddenly becomes very important.
For most versions of the Linksys WRT120N, the default password is admin. As with most passwords, the WRT120N default password is case sensitive.
In addition to the WRT120N default password, you can also see the WRT120N default username and WRT120N default IP address in the table below.
Note: The Linksys WRT120N default password may be different for certain hardware orfirmware versions.
If I have that information, I'll include the exact WRT120N version number along with the correct default password. You can usually find your Linksys WRT120N version number on the bottom of the router.
Be sure to change the default router password on your WRT120N to something more secure as soon as you're in. Then use a free password manager so you'll never forget your new WRT120N password.
Help! The WRT120N Default Password Doesn't Work!
At some point during the life of your particular Cisco Linksys WRT120N, the default password, username, and/or IP address might have been changed.
In most cases, if the Linksys WRT120N default IP address has been changed, the new IP address for the WRT120N will be the same as the default gateway IP address configured for your network connection.
See How To Find the Default Gateway IP Address for help.
In situations where the WRT120N default password or WRT120N default username has changed, you'll need to reset the Linksys WRT120N to factory defaults. You can usually do that via a special button or sequence of actions.
The WRT120N manual will have specific directions for performing a factory default reset. You can download the manual for the WRT120N from Linksys Support.
Please let me know if any of the WRT120N default login data below needs updated. For other questions about the WRT120N default information on this page, see my Default Password FAQ.
WRT120N Default Password & Other Default Login DataVersionDefault UsernameDefault PasswordDefault IPPrivilegesAll[none]admin192.168.1.1Administrator
Jan 13, 2012 | D-Link 802.11g Wireless Router WBR-1310...
I forgot my Password for NETGear WGT624 Please help
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
Jan 17, 2011 | NetGear WGT624 Wireless Router
Need to know username and password
If you forgot your router password,you will have to reset the router back to factory defaults and log in using the default password.-->
To restore the factory default configuration settings without knowing the login password or IP
address, you must use the Default Reset button on the rear panel of the router.
Connect to the wireless router by typing http://www.routerlogin.net or the router's LAN IP
address (default is 192.168.1.1) in the address field of your browser and then press Enter. A
login window opens:.
Enter admin for the router user name and your password (or the default, password).
For more details use the netgear instruction manual--->HERE!
Jan 03, 2011 | NetGear WNR834B RangeMax NEXT Wireless-N...
I have given up on loggin into the the device. All I want to do now is RESET everything back to default and rename my network and give it a new password.
Most of these devices have a hardware switch to perform a RESET. You didn't include a manufacturer or model, so it'll be up to you to locate this switch. Typically, it is located in a recessed area (so it won't be activated accidentally) and must be held 10 - 30 seconds (again, depending on brand / model / etc.) where upon the device will reboot and be reset to factory defaults.
Factory defaults may conflict with other equipment on the network, so it may be best to disconnect the router from everything except for the local computer before the reset switch is activated. You'll have to reboot your computer (or reset your computer's IP address) after the reset of the router. You'll need to know the factory default IP address, username and password of the router - which is available from the manufacturer for that particular model. After that is obtained, login to the router by accessing the the default IP address in your web browser.
Nov 10, 2010 | Computers & Internet
I want to reset using RS323 port , i forgot its ip adress
Hi
You can reset the device through RS232 port then please follow the below steps.
You need a laptop with Console port and a console cable for EOC-8610 EXT, You really dont need the IP address if you want to do it via console (RS232) interface.
1. Connect the console cable one end to EOC-8610 EXT RS232 port and other end to Laptop serial port.
2. Open Hyper terminal and select com-port option and then provide the username and password for the device management.
3. Go inside the system menu and select Reset Factory default.
Remember if u set to load the factory default settings, the device will loose its config and will boot up with factory default configuration.
Nov 03, 2010 | EnGenius / EOC-8610 EXT / 54Mbps /...
I am trying to set up a new printer to a Linksys router model no WRT300 Ver 2.0. I have lost my IP no and also my Network Security Key, Is there any way to retreive these nos Gordon Stephens
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Aug 21, 2010 | Linksys Wireless-G WRT54G Router
CANNOT FIND IP ADDRESS
Just make use of this site http://www.ip-details.com/ip-search/ for Checking The Ip address of your PC.
i Used this site for checking the IP Address , this site provides information at cheap cost
Feb 10, 2010 | Gateway Wireless-B Router (wbr-100)
Default IP Adress of the modem Hughes HN7000S
The Hughes addresses are 66.82.4.8 and 66.82.4.12.
Mar 06, 2008 | Computers & Internet
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
