Question about Electrical Supplies
What oil used in generator - Electrical Supplies
    Top Expert:
  • Electrical S... Master
  • 44,232 Answers
Most anymore will work fine with 10 w 30 .
Posted on Apr 23, 2015
What kind of oil do you use
Judy, Generac portable generator oil recommendations. Above 40°F, use SAE 30. Below 40°F and down to 10°F, use 10W-30. Below 10°F, use synthetic 5W-30. Oil should be changed after the first 8 hours of operation and every 200 hours of run time thereafter.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.generac.com/service-support/faqs/portable-generator-faqs
http://www.generac.com/service-support/faqs/home-backup-faqs
Best oil for Generac generator Lawn Mower and Small Engine Bob Is The Oil...
Generac Generator Oil Change
Apr 18, 2016 | Generac Electrical Supplies
My honda 2000 whisperer generator runs then shuts off after about 3 minutes. What could possibly be wrong?
Always use ONLY fresh fuel... (page 32 of owners manual) it is very easy to forget about because HONDA is such an awesome machine... but EVEN MORE LIKELY...
HONDA has a very sensitive self protection device
Your oil pressure cut off switch could be responding to the WRONG OIL...
DIRTY OIL...
LOW OIL or WORSE... OVERFILLED Oil.
Check it out in your owners manual. ((below) http://cdn.powerequipment.honda.com/pe/pdf/manuals/31Z07610.pdf
Honda Generators Generator Operation
Honda Power Equipment Owners Manuals
http://powerequipment.honda.com/generators/generator-operation#fuel
Feb 10, 2016 | Honda Electrical Supplies
What oil to use for a pm54-2000 generator
USE A 30 W OIL IN THE GENERATOR MOTOR ASLO DEPENDS ON THE WEATHER .O N COLDER DAYS USE A 10W30
Jun 20, 2014 | Coleman Powermate Powermate 5000W...
What type of oil do i take for a porter cable 5250 watt electric generator?
Your generators take ordinary 10W30 motor oil.
We use these things on the job.
Don't turn engine upside down or on its side to drain oil, or oil will run into carburetor
Oct 24, 2010 | Porter Cable PorterCable BSI525W 5250 Watt...
I would like to know what type and how much oil do I use in my powermate generator with the Subaru 10hp engine. thanks you
Your small engines require ordinary 10W30 motor oil.
Don't turn machine on its side or upside down to drain oil, or oil will run into carburetor.
Use a plastic hose to remove old oil
Oct 22, 2010 | Coleman Powermate Premium Plus 6250W...
Need to know what oil to use in 10 HP 5000 tecumsah engine - goes on our generator and I lost the manual
It depends on what temperature range the generator will be operating in. Below is a chart from Tecumseh that shows different oils for different temperature ranges. It says on their website to use a high quality brand name oil so you don't have to get actual Tecumseh oil.25b21be.jpg
Feb 26, 2010 | Coleman Powermate Premium Plus 6250W...
Lincoln Welder Generator Oil Question
Better late then never! im-308 total lube oil is 4 pints for a briggs and stratton engine
and 3.5 for an onan engine with filter change.
Note: an internal kill switch will shut down the engine if the oil level drops below a minumum
operating level on the onan engine only.
on your welder use a multi-viscosity sae sj grade or better oil. recommended is 10w-30.
if you work in cold environments use 5w-30 oil , it's thinner and will flow easier
during cold starts. Synthetic oil is better. just more expensive. change oil at least
every 100 hours for better performance. good luck!
Aug 19, 2009 | Lincoln Electric Ranger Gxt 250 Amp...
Oil type for Onan 4000 generator
SAE 15W-40 is what i used to use
synthetic? not sure about that one there may be oil pres switch that could give you a problem.
Apr 04, 2009 | Watts Onan Portable Generator - 4000 ,...
Honda 5.5 generator gas is filling oil compartment when not in us
turn the fuel off when not in use,it is going through the carb.to the oil.
Mar 17, 2009 | Honda 3000 Watt Portable Generator
Electrical Supplies Logo
29 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
