Question about Garden
How to get my soap pickup to work - Garden
    New Friend:
The plastic soap bottle has a rotatable ring around the neck. Rotating it regulates the amount of soap flow. Clockwise increases the flow and counterclockwise all the way turns off the soap completely. There is an arrow and incline cast into the ring indicating more or less soap.
Posted on Apr 23, 2015
Karcher K2 seams to be directing pressure to soap
If you use the wrong tip when trying use pickup tube, you will force water into the tank. You can only use the low pressure suds tip. There are typically 4 tips- 0 deg, 15deg, 40 deg and a soap tip. You cant pressure wash and use soap at same time.
Oct 04, 2014 | Garden
Chemical wont siphon
In most cases this is because you have a high pressure tip, the red, white, yellow or green tip, on the wand. The detergent system will only work if you have the black, soap tip on the wand. With a pressure tip on the wand, there is too much back pressure for the syphon system to work. If you are using the soap tip, check the feed tube for the detergent for blockage, especially at the pickup filter and where it attaches to the water line.
Sep 16, 2012 | Powerboss 020309 3000 psi 2.5...
Craftsman pressure washer how to adjust soap 2300 psi
A common mistake made when using the soap pickup function on pressure washers is to use one of the high pressure tips, usually green, white, yellow or red. If you are using one of these there will be too much back pressure in the line for the soap dispenser to work. You have to use the low pressure, soap tip, usually black, for this function to work.
Jun 28, 2012 | Garden
It will not **** in cleaner soap
Your heading is for chain saws but going by your problem I'll assume you are having problems with your pressure washer. The most likely reason your washer won't draw the soap into the water stream is you are using one of the high pressure tips, usually red, white or yellow. The only way the soap system will work is if you use the low pressure, soap tip which is black. Another thing to check is the soap line and pickup filter to make sure they are clear and allow the solution to be picked up.
Apr 14, 2011 | Garden
Paper feed not collecting paper, clicking noise
Clean the pickup roller(s) (in the paper tray) with mild soap and water if you can remove the pickup roller easily or with a q-tip if you can't. DO NOT USE alcohol as it will dry out the pickup. Use at least two q-tips, don't stop cleaning too soon. You can use a little fine steel wool to rough up the roller surface too. Replace the rollers if that doesn't work. Usually cleaning them is a stop gap measure. This works for the top rollers too.
Sep 09, 2009 | Brother HL 1250 Laser Printer
Wiring for a dean edge 4 string with one soap bar pickup
You might find it at http://www.mediawebsource.com/guitar/pickup.htm If you can figure out what brand the pickup is you could check the manufacturers site. http://www.guitarelectronics.com/category/wiringresources/ has original factory wiring diagrams for guitar and bass for various pickup manufacturers. Hope this helps.
Jul 10, 2009 | Dean Edge 4 Bass Guitar
On my karcher pressure washer, how do i get the soap to come out of the spray nozzle?
Two nozzels came with your washer one has a cone shaped head, the other one is blunt, attach the blunt one to the trigger. You will notice on the barrel of the nozzel it says "mix" turn the indicator line to "mix" and it should work. This is a very low pressure setting and is used to "apply" the soap only. You cannot despense soap in the hight pressure mode.
Apr 13, 2009 | Karcher K2.26 Electric Power Washer
KOLHER Soap dispenser won't dispence soap.
Pull the dispenser out. Put it in semi hot water foe a few minutes to clean it. Then put the pickup tube in a glass of water and pump it untill water comes out. They get clogged with soap after so long.
Good Luck
Kurt
Mar 01, 2009 | Kohler K-5988-2-7 Entree Self-Rimming...
Price pfister soap dispenser will not work
Replacement parts can be found on amazon. Click here Watkins Hand Soap Made Naturally Since 1868 and take a look. I hope this was helpful. Cheers
Dec 13, 2008 | Price Pfister Marielle Kitchen Faucet with...
Garden Logo
209 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
