Question about Building Materials
Raynor hbw1127 light won't go on with remote or wall unit. Bulbs have been replaced
2 Suggested Answers
  • 3197 Answers
SOURCE: My Raynor Keypad does not work
There should be a small screw about 3 inches up from the bottom. Remove this screw and the cover should slide off.
Posted on Oct 19, 2009
Raynor garage door motor won't run and won't open the door. It is not sending power to the system despite being plugged in to a working outlet.
More than likely, the transformer in the opener is fried. You need to verify 110V power coming into the transformer, and that there is 24V AC power coning out of the transformer
Oct 03, 2014 | Raynor Garage Doors 4050047 Raynor PEC-R4...
CRAFTSMAN GARAGE DOOR OPENER FCC ID: HBW1127 WILL NOT OPEN FROM REMOTE JUST FROM WALL SWITCH.
If it won't reprogram it's your receiver in the the circuit board. The wall switch will still work because it's wired to the opener.
May 02, 2014 | liftmaster Craftsman Garage Door Control...
Raynor garage door opener
There is a limited amount of remotes that are allowed, I believe it is six. You could contact raynor suppport for help.
Feb 05, 2014 | Electrical Supplies
The lightbulb in the unit burns out quickly, every 4-6 weeks. I have Lift Master 1/3 H.P. FCC ID #HBW1127, Part #41A4252-7D
You can buy bulbs designed for garage door openers. They are heavier duty. Also you should unplug the unit and remove the light bulb. Pull out on the center contact of the socket. Replace the bulb and plug the unit in.
Oct 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote works only when Garage Door Opener light is OFF
I discovered that certain light bulbs interfere with the remote sensors. Harware stores have clear vibration reisistant bulbs for garage doors, try them instead. After spending money on a new remote, resetting remotes, and weeks of aggravation...poof.....i found it was the type of bulb I was using. Used a clear bulb and the problem went away. Hope this helps.
May 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Reprogram keypad remote
Setting the code:
1. Press and release the "learn" button on the motor unit. The learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal indentification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the button when the motor unit lights blink. It has learned the code. If light bulbs are not installed, two clicks will be heard.
Apr 25, 2009 | Computers & Internet
Lights flicker when turned off by remote
I had this same problem with a Hampton Bay fan with a remote light switch. I call the manufacturer of the of the switch and was told that the model switch I had would not work correctly with CFL bulbs. The problem is with the dimmer function. You either need to change the bulbs to incandescent, or change the remote receiver in the ceiling. Hampton Bay was kind enough to send me a new receiver that works with CFL. The CFL units are white, and the incandescent is black. Hope this helps you.
Feb 26, 2009 | Universal Remote Control Hampton Bay...
Remote stopped working
already tried a new remote and new batteries. bose says the ir bulbs need replacement so i'm taking it in. shucks.
Dec 23, 2007 | Bose (321GS) System
Building Materials Logo
59 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
