NO PICTURE OR SOUND HAVE REPLACED CAPACITORS ON MAIN BOARD TURNS ON BUT NO PICTURE OR SOUND
    Top Expert:
  • Televison & ... Master
  • 75,320 Answers
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Apr 23, 2015
    Top Expert:
  • 6,702 Answers
Why would you replace capacitors in the first place? As an electronic repair engineer, I only replace capacitors when they are defect. And not because something is not working. It could be your power supply is defect, but there can be lots of other causes, like bad connection or broken cabling. It also can be possible the audio amplifier or the screen has a shortage driving the power supply in protection.
Leave repairs to people who know what they are doing. When you have replaced some things in the system, it could be the repair is extra expensive, because you caused more damage than you solved.
Consult a tech, it will save you money and lots of time.
Vizio main board # 3655-0122-0150 7C
Board # 3655-0122-0150 is the main board not the PS board as mentioned in the previous message it can be purchased from shopjimmy but its not a cheap board...below is the URL for the board..How does the set behave? sound no picture, picture no sound, dead, has standby light, poor picture...ect
http://www.shopjimmy.com/vizio-3655-0122-0150-main-board-for-xvt553sv.htm
Nov 10, 2017 | Vizio Televison & Video
Samsung LCD TV Model LN46A550P3FXZA sound is cutting in & out 1-2 second intervals
Your video and audio (sound) signals are generated on the main board. However, for those circuits to work properly, they have to have clean and accurate power from the power supply board. The power supply boards are notorious for bad capacitors. Has your power supply been recapped? Do you see any bulging tops of any of the capacitors? If you are not familiar with capacitors, just google bulging capacitors. There are plenty of pictures on the web to show you what they look like. It is possible that the main you have has a problem. I assume you order the same exact part #?
Nov 12, 2013 | Televison & Video
The t.v has sound but no picture for a while then it comes on
Sounds like a dieing capacitor or two on your main board. You could also check the capacitors on the power board, if there are two diferent power "outs" for sound, and backlight. When you first turn it on, when it has sound but no picture, shine a really bright flashlight against the screen. Is there an image there that's just not lit up? If there is, than it's simply a few capacitors on the power board. If there is NO image while there is still sound, than it may very well be your main board. It may also be the CCFL tube itself, (like the long tube lights you see in most offices) but CCFL issues are rare, and hardly ever worth replacing. (CCFL Cold Cathode Fluorescent Lamp)
Either take it to a repair shop, or send it to the manufacturer unless your comfortable replacing a few components and are handy with a soldering iron.
Jan 31, 2013 | Philips 32PFL3505D 32 in LCD TV
Can you fix a power supply on a Sanyo,no sound,no picture
Sanyo TVs usually only have two boards in them , doing a visual inspection of the power supply capacitors usually reveals swollen or bulging capacitors.
If the capacitors look good, voltage checks would be needed to isolate the problem to either the main board or power supply. Check for 5 volts to the IR board (& or keyboard) , if five volts is present suspect the main board
May 26, 2012 | Televison & Video
Hp tv 52" model id5220 - fan runs continually while plug in but no picture or sound?
The problem is caused by a bad capacitor on the main board of the television, that is why the fan continually rolls but there is no picture or sound.
The solution is for you to unplug your television and leave it for about 2 hours so the high voltage will dissipate, then you unscrew the television open and try to assess the main panel of the television and you will detect the bad capacitors then turn to the back of the board television and solder off the tip of the capacitor then replace it with a new one.
Then couple back the television together. After doing this, the television should be in good shape once again.
Take care and good luck
Oct 21, 2010 | Televison & Video
Tv turns on and i have sound just no picture
The reason your television have sound but no pictures is because there is a problem with the t-com board of the television.
Once you can have the board fixed or replaced because mainly its a capacitor that got burnt on the board.
But replacing the board will do just fine.
Oct 11, 2010 | LG 42PC3D 42 in. Plasma Television
HPT5054 50 in. HDTV-Ready Plasma Television: Samsung HPT5054X/XAA - No picture, Sound OK, Have ...
It's not the x main. 90% of the time it's a y buffer that goes out. It's usually the top buffer. 3/4 of the time the buffer takes out the y main board too. You cannot just replace the y-main or buffer because it will just burn out the other within seconds. Also about 1/4 of the time it'll take out the top transformer on the power supply too. The solution? First disconnect the power to the y main board. turn on the television and check the voltages coming off of it. Careful it's high voltage 208V! Remember it's DC too. Then disconnect the buffers from the y main board. You can try powering the y-main up to see if the little LED lights up. This does not indicate it's working though but it'll tell you if it is possible to fix. The fixes for these boards is only for electronics guys. It usually involves replacing 1-3 capacitors and 1-4 FET's. Since a bad buffer can take out a good y main in seconds it's usually recommended that one replace all 3 boards at the same time. It's a $250 fix. How do I know all this? I've now repaired 5 of these televisions. I owned one and spent close to 600 repairing it. I bought misc parts and broken sets online for months before I had 2 different repair guys walk me through the process of repairing them. I had so much cash tied up in parts that I bought 3 more dead sets and repaired them to justify all my spending. I've never had an x board fail. I've had EVERY top buffer fail. I've had all but 1 y-mains fail. and 1 lower buffer fail. I've also had the y buffer fry it's top chip, blow a capacitor and FET on the y-main, and fry the top transformer on the power supply before my eyes. It only took 5 seconds. Replacement of the 3 y boards will almost always fix the sound but no picture problem. Hope this helps!
May 16, 2010 | Samsung HPT5054 50 in. HD-Ready Plasma...
No picture when you turn it on
if you get the sound but no picture when you turn it on then it might me faulty capacitors on the main board causing this and had to be replaced.but if you r not getting both sound and picture it might be faulty fuse thats blown off.
Nov 30, 2008 | Mitsubishi Televison & Video
Tv has no picture only sound
on the main power supply board the capacitors are blown or bulged.which supports the picture to display on the screen.replace that capacitors and ICS from the main board.
if donot have any technical knowledge call a technician.it is much advisable.and it is worth reparing.
thanks.
Oct 14, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
