What is the LOC/BSM button??? And what does it do???
Bsm-3 installation manual?
Hi Jim!
I've provided a link to your owners manual, installation begins on page 9.
Hope this is of help to you.
(Sorry, I inadvertently posted a Merc 9.9 service manual as well and can't seem to remove it.)
-Steve
http://www.simrad-yachting.com/Root/Simrad-Documents/BSM-3_IM_EN_988-10719-001_w.pdf
Sep 01, 2014 | Boating
Handset msg says.."Press HS LOC
Since you declined to specify the model of your Uniden DECT 6.0 phone, I can only direct you to select it from the list beginning here. The manual should have illustrations giving the locations of all buttons.
Sep 22, 2011 | Uniden DECT 6.0 Cordless Phone ID
My fridgidaire affinity dryer has loc error and will not let me start it
The control is locked to avoid having someone accidentally start or stop the dryer. Press and hold the Options and Select buttons for 10 seconds or until the "LOC" on the display is cleared. Locking the control is done the same way it is unlocked.
Mar 04, 2011 | Dryers
How do you unlock a kenmore elite cooktop?
You can do this by:
Check the oven display to see whether the screen says "LOC." When "LOC" is displayed, the oven lock is activated and the door cannot be opened. You need to make sure it is locked so you do not mistakenly lock the door.
  • 2 Press and hold the "Stop" button on the oven control panel until "LOC" disappears from the display. Some oven models have a button marked "Oven Lock," which should be used instead of the "Stop" button.
  • Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
  • Feb 03, 2011 | Kenmore Elite 44173 30 in. Electric...
    When i turn it on loc comes on and i cant get it to work. i tried yesterday and it said pause then error
    The control is locked as what "LOC" indicates. Press the Options and Select buttons simultaneously for 10 seconds or until "LOC" is no longer displayed. Pressing the same buttons for 10 seconds will lock the control. There is actually a padlock sign marking between these buttons to indicate that these buttons are used for locking and unlocking the control.
    Sep 04, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
    Display says loc
    The LOC is for the buttons, it's a safety feature. One of the buttons should say "lock" or something next to it in small text. Hold the button down until the indicator goes off. If this does not solve the problem how about a make and model or something to help us out??!!
    Aug 08, 2009 | Ovens
    Pioneer premier deh-500ub presetting stations
    Storing the strongest broadcast
    frequencies
    BSM (best stations memory) lets you automatically
    store the six strongest broadcast frequencies.
    1 Use MULTI-CONTROL to select BSM in
    the function menu.
    2 Press MULTI-CONTROL to turn BSM on.
    The six strongest broadcast frequencies are
    stored in the order of their signal strength.
    # To cancel, press MULTI-CONTROL again.
    Tuning in strong signals
    Local seek tuning lets you tune in only those
    radio stations with sufficiently strong signals
    for good reception.
    % Press LOCAL repeatedly to select the
    desired setting.
    FM: OFF—LEVEL1—LEVEL2—LEVEL3—
    LEVEL4
    MW/LW: OFF—LEVEL1—LEVEL2
    The LEVEL4 setting allows reception of only
    the strongest stations, while lower settings let
    you receive progressively weaker stations.
    You can also perform this operation in the menu
    that appears by using MULTI-CONTROL.
    Selecting alternative frequencies
    When the tuner cannot get a good reception,
    the unit automatically searches for a different
    station in the same network.
    1 Use MULTI-CONTROL to select AF in the
    function menu.
    2 Press MULTI-CONTROL to turn AF on.
    # To turn off, press MULTI-CONTROL again.
    ! Only RDS stations are tuned in during seek
    tuning or BSM when AF is on.
    ! When you recall a preset station, the tuner
    may update the preset station with a new frequency
    from the station’s AF list. No preset
    number appears on the display if the RDS
    data for the station received differs from that
    of the originally stored station.
    ! During AF search, sound may be temporarily
    interrupted.
    ! AF can be turned on or off independently for
    each FM band.
    Apr 20, 2009 | Car Audio & Video
    Ford F150 Pickup 2005 power doors unlock but will not lock
    I had almost the identical problem on my 2005 F150 FX4 Extended cab last weekend. The power door locks would not lock using the keypad, remotes, or door buttons. Almost all other functions worked correctly. The doors unlocked, the radio delay functioned, and the interior lights dimmed. When I used the remote the horn would beep twice indicating that a door was open even there was no message on the message center that a door was open. When I used the keypad or remote, I could hear a soft click from behind the seat. I think it was coming from the body security module or body security module - whatever Ford is calling it this year. I pulled the fuse for the Power Door Locks(BSM). As I removed it, I heard a soft click - sort of like a relay resetting. It may have come from the VSM/BSM. It may have possibly been a stuck actuator releasing. I don't think so. It wasn't that load. In any case, everything is functioning correctly now.
    Tracy
    Oct 29, 2008 | 2005 Ford F-150
    Scan Seek feature
    the BSM feature negates the need fo a seek button. use it instead.
    Jun 26, 2008 | Pioneer DEH-P3900MP CD Player
    Washing Machines Logo
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
