Question about Sony Televison & Video
I have a sony flat screen tv. I need help in turning on tv with or without basic cable for free and using an regular antenna.
SOURCE: Insignia Flat Screen TV - no cable signal
Hi, need some help here. I have a flat screen tv that will not go on. Its not even 2 years old. Yet I had to keep trying the wall outlet to get it to turn on. Now it won't go on at all. The tv light use to be blue when it was on. Now its pink? Should I ask santa for another, or can this be repaired without too much fuss/cost? Thanks!!!!
Posted on Dec 10, 2007
SkinWill
  • 148 Answers
SOURCE: Connecting a Playstation 2 console to a Phillips flat screen tv
They may have those inputs disabled on the tv. call the front desk and ask for the house electrician.
Posted on Jun 09, 2008
  • 520 Answers
SOURCE: connecting antenna cable and cable from cable company
Use an A-B switch.
Posted on Jun 26, 2008
electronick
  • 505 Answers
SOURCE: no picture when vga cable is connected
Most tvs can only handle a couple resolutions (ie 640x480) through the pc input. Even some HD tvs can only do 480. Check that your video is turned on and setup to the acceptable resolutions.
right click your desktop
go to properties
click settings tab
click on the 2nd monitor
make sure the box is clicked at the bottom
"extend my windows desktop onto this monitor"
instructions for windows xp
Posted on Dec 16, 2008
SOURCE: Vizio flat screen has very red tint when using HDTV component cables
Ummm... i have the same problem and its EVERY type of cable that causes the red tint. its the tv itself. replacing all the darker colors with red. explain that?
Posted on Nov 15, 2009
What do i need to get regular channels on the tv
How to get regular TV channels?
Your HDTV should have a digital TV Tuner (ATSC) which may need an indoor antenna. Change your TV's input selector to TV or Antenna or Digital (probably one of those three) and scan for channels. If you don't get any channels, then you do need an antenna. Probably another $10.
How to get basic channels on new HDTV without cable - HDTV ...
www.tomsguide.com/forum/53920-4-basic-channels-hdtv-cable What do need to get regular channels on the tv Google Search
Dec 12, 2016 | Televison & Video
I'm going from cable to an antenna, and the remote will not work, I've put in new batteries, any help would be appreciated. I can turn on the tv without it but cannot do anything else.
If your going to a regular antenna, you have to use the tv remote to operate the tv. unless you have a cable box. Sorry if I did not understand the problem. God-Bless!
Mar 14, 2016 | Hannspree HANNslounge 32 in. LCD HDTV 32
Can you hook up an antenna to a maxent 2007 tv to get free basic television stations
Your Maxent instructions should say. My Maxent is a display, basically a monitor only, that has no tuner. Without a tuner an antenna won't help you make use of the signal. Hope this helps!
Mar 05, 2015 | Maxent Televison & Video
I have a 2005 Protron 32 flatscreen TV and recently disconnetted it from Direct TV and just want basic TV 4 6 10..... when I plug the tv into the wall without cable I only get a blue screen. Do I need a...
You do need an antenna and need to access the menu and change input to antenna. Through the menu you should be able to let the tv auto scan for channels.
Sep 17, 2011 | Protron PLTV-32 Television
I have a Sansui SLED 2280 that I'd like to use without cable input. How do I switch to regular over the air (no cable) antenna? Thanks
To switch from cable to air or vice versa on most Sansui flat screen tv's including the SLED2280, go into the menu. Select "channel" on the screen. Press "enter" on the remote. Select "auto ch mem" on the screen. Press "enter" on remote. Select "signal type" on screen. Press right arrow button or right volume button on remote to change signal type (cable or air). To program channels into tv, select "automatic search" on screen then press "enter" on remote. Wait for search to finish.
I hope this helps you.
Bobya
Dec 19, 2010 | Sansui Televison & Video
How do I hook up my tv to regular reception using
you will need to buy a digital converter box to get regular tv. The fcc has changes the way you get tv over the air. check at radio shack and they can get the box for you. should be around $40.00.
Jan 29, 2010 | Vizio Televison & Video
Have xbox 360....got used,no instruct. book,was hooked to flat screen tv, no longer have flat screen tv, have regular tv hook up game comsole to tv, wont work.....why
If it was hooked to a flat screen it was most likely on high def. There is a switch on the connection to the tv to make it work on a regular defination tv. Just slide the switch over to regular and it should work. Hope this helps.
Sep 12, 2009 | Microsoft Xbox 360 Console
My new tv only gets some channels and not others
Have you tried an amplified antenna? It's basically a regular antenna but includes an amplifier to help bring in weak stations. An out door antenna may also help. I live about 3 miles from a TV station and can't pick them up due to the insanely old apartment I live in.
Jun 03, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony TV KV-32v26
Do you mean basic CABLE channels or Aerial channels? If aerial, what kind of antenna are you using (you must have SOME sort of antenna... rabbit ears, set-top, etc...)?
Sep 20, 2007 | Sony KV-32V26 32" TV
Televison & Video Logo
27 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
