Question about Saeco Odea Go
How to fix a problem with the turbine on my Saeco Odea Go?
I disassembled the machine to clean it and when I assembled it again by mistake I put the connector of the flowmeter (turbine) only over 2 of the pins not over the 3 pins. The mashine stopped to brew coffee and when i opened it again I found the mistake and put the connector properly. But nothing changes. Everything is working except brewing coffee. In test mode all seemed well except that during the pump test the steam led is not blinking like it should because of the turbine. I think the improper connection of the turbine must not have damaged something in the mainboard. The turbine is clean and working. Just how to make the mashine to read the data from it again?
  • Ivan Balabanov
    Ivan Balabanov Apr 27, 2015
    I replaced the turbine and now everything is working fine. I just cant imagine that my mistake can damage the pump.
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 48 Answers
During water pump test the led flashing with the speed of the turbine rotate.Tell us if during the test if water running (I think that there is no damage from the ''mistake'' you made). Take a look at the tubes of the turbine and make sure that you have put correct input - output.
Posted on Apr 23, 2015
Testimonial: "During the pump test the led is not blinkink with the speed of the turbine rotate. It is firm steady light and no blinking. The pump is working and the water comes out from the steam valve. No damage. And yes. The tubes of the turbine are in their correct state."
  • vendingbar
    vendingbar Apr 26, 2015
    When led is not blinkink means that the machine does not see the rotation of the turbine.The cable of the turbine has two sides,the one goes on the turbine and the other on the board.Check if it is ok.If you can ad a picture of the turbine on the machine it could be very helpfull.
mirran
  • 515 Answers
SOURCE: Saeco Royal Digital Not brewing Coffee
If you try to make a cup of coffee, hold the button to see if there will comes some coffee, it can be the memory that have loose the settings. If so you have to program the machine again.
Best regards
/Mirran
Posted on Oct 26, 2008
EsWorld
  • 1618 Answers
SOURCE: Saeco Odea Go - slow to brew coffee, comes out of steam valve
The steam valve needs to be replaced, because the pins have been damaged from high pressure buildup, could have been caused from a very fine grind. You can also check the screen in the brew unit that might be blocked and causing the high pressure backup.
Posted on Nov 15, 2009
  • 81 Answers
SOURCE: I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Posted on Mar 28, 2010
espressonist
  • 1711 Answers
SOURCE: Saeco Magic Comfort Plus dumps
From your description we understand that your machines vital parts like water pump, grinder, group and gears, boiler, electronic board all are working fine since there is a final result the coffee.
The only problem you face is that due to long time use some coffee liquid have dry out layer by layer and have goggle the Teflon pipe of the plastic unions so the coffee cannot be deliver through to the coffee tap and as a result is ending in the coffee drugs drawer.
So you need to disassemble you machine and remove the Teflon pipe which is after the coffee croup and by using a thing metal wire like a paper clip or similar you can check the pipe and the plastic unions to find out where they are goggled from dry coffee. You can immerse them in boiling water from some minute so the dry coffee to dissolve and be removed completely. By this chance you can remove also the coffee group filters and also clean them with hot water.
We have here below the link with exploded parts view of your model which will help you find the parts and understand how your machine is constructed.
http://www.partsguru.com/user/E003039-ed1.pdf
Also you may now you don't have any problem but we suggest performing at least once every month de-scale so to keep your machine in perfect condition.
Also if you might need nay part replacement you can even order it from the same side in this link
Posted on Dec 11, 2010
  • 1089 Answers
SOURCE: We've had our Saeco Incanto for about 2 years,
HI
I would suspect that the grinder has seperated. If you take out all the beans and look at the cork screw in the center, it won't be. It will be off to one side just a little. That is why you are not getting a good grind. the beans are going to the larger side and being chopped into large grinds. You might be able to take the grinder apart and snap it back together. Or it might be broken and it will have to be replaced. Email me if you need one.
Posted on Jan 19, 2011
Saeco Odea Giro Alarm stay led on (Intermittent)
Martin
Try to clean the water flow sensor
See more diagnostic option in the following picture
you should see the pump flow meter light in pulses -
if not check / clean the flowmeter and its contacts / connector
see more diagnostic in chapter 5.1.1 of the service manual
can be founed in the following link
http://www.partsguru.com/user/SERVICE%20MANUAL%20TALEA%20ODEA%20REV.03%202.pdf
Apr 18, 2014 | Saeco Odea Giro Plus Coffee Maker
Prime water circuit error gaggia platinum vision coffee maker
The turbine flow meters contacts are corroded, or the turbine itself is broken.
Apr 10, 2014 | Saeco Odea Giro Plus Coffee Maker
Saeco Odea Go descaling
fill the tank with detergent and let the hot water run for about 15 seconds. Then turn off the machine for about 15 minutes. Then turn the machine back and let the hot water. Then rinse the water tank and fill it with clean water. Run hot water again to empty the tank. Fill clean water again and then you can put down coffee :)
Dec 02, 2013 | Saeco Odea Go
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
Jan 12, 2011 | Saeco Odea Go
Re Odea Giro Plus - Cannot stop the red alarm
The problem is with the flow meter which is a turbine unit that is installed before the pump.Either there is a blockage or the unit is bad.Have to open the machine to get into it.
Jan 06, 2010 | Saeco Odea Giro Plus Coffee Maker
New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
Dec 24, 2009 | Saeco Odea Giro Plus Coffee Maker
My Saeco Odea Go always seemed very noisy?
maybe pump make noise,check holder of pump,or replace pump
Aug 29, 2009 | Saeco Odea Go
Saeco Odea Giro highlights the "!" light and wont spurt water.
Try this open the steam knob for about 5 seconds then turn it to the rest(off) position, make sure that it is in the off position.
Jun 12, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco Odea Giro - Clogged and coffee come out in water tray....
This has happened to our machine that we use for our youth group. We sent it in and they said it was clogged also. Not having a clue what they meant. It happened again and I figured it out. When you remove the brew group there is a hole just above it that dispenses into the brew group. Make sure it is not clogged. Give it a try Good Luck
Mar 08, 2009 | Saeco Odea-Giro Espresso Machine
Saeco Odea Giro tuning on/off
turn off each night and when going away! the machine will last longer.. without repair! also saves money (they use alot of power!
Dec 09, 2008 | Saeco Odea Giro Plus Coffee Maker
Open Questions:
See all Saeco Odea Go Questions
Saeco Odea Go Logo
210 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
