Question about Poulan 16" 38cc Gas Chain Saw P3816
Chain saw sharpening angle
What is the correct sharpening angle for this chain?
  • Poulan Master
  • 1,169 Answers
For cross cutting is 30 degrees and if you only do ripping it is 10 degrees.
Posted on Apr 22, 2015
  • Bruce Garwood
    Bruce Garwood Apr 23, 2015
    Thanks for the time and effort. I had gotten several different answers. I just purchased a Oregon electric CS sharpener and I needed the degrees which you provided. Thaanks so much!
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
If you are lucky, you own a Stihl saw. If you do, notice the 'witness marks' towards the rear of each tooth. Those marks are the sharpening angle for normal use. I typically sharpen to 35 degrees for normal sawing though that may not be the preferred sharpening angle. Most people that don't make a living with a saw can't 'freehand' with the file to a specific angle consistently but if you are reasonably close to the 30 to 35 degree angle you should get a fair cut.
Posted on Apr 23, 2015
What is oregon chain sharpen angle
I sharpen to 35 degrees, right or wrong. I'm sure there are more aggressive angles for the larger pro-saws, but this has served me well over the years on many brands of chain.
Jun 12, 2014 | Poulan Pro Chain Saw 46cc 20"
How to sharpen chain saw chain
Hi
You need to purchase the correct diameter file for the size of chain you have fitted on your saw. Suggest also that you buy a Stilh file holder (this is a frame which holds the file, and acts as a guide to give you correct filing angle and depth, just a few dollars).
Do not file too much off each time, I give each tooth two files strokes only. You have to keep the saw sharp all the time, I sharpen every two tank fills of fuel.
Suggest you Google the subject, Oregon chain is a good make and will have details of how to sharpen
Good luck
Jacko from down under
May 15, 2014 | Computers & Internet
Saw is cutting the wood on an angle
the cutters on your chain are not filed evenly. Either take saw to a Stihl dealer and have chain sharpened or get a new chain. Ask them to show you how to sharpen your chain.
Apr 23, 2014 | Stihl 009l
Sharpen my chainsaw chain what angle do i grind
I gave up trying to grind my own chains. I take the chain off the saw and take it to a saw shop. They do a better job than I could. If you grind it wrong it will cut poorly or not at all. If you mess up bad enough like I did you end up purchasing a new chain.
Mar 12, 2014 | Craftsman Garden
I sharpend my chain and filed and flip the bar around. And it still want cut. Do I need a new bar and chain?
I dont me to be rude but two things spring to mind, firstly have you put the chain on backwards? the chain on the top of the bat should have the sharp edge facing away from the saw ( turns clockwise as you look at it from the side of the saw ) and secondly have you sharpened it correctly ( right angles, and taken the depth gauges down to the correct hight ) there should be no need to replace the guide bar, at worst a new chain will do, let me know if you need to know more about chain sharpening.
Feb 16, 2012 | Garden
We have a model 137 chain saw. I need to know what size file to sharpen the chain and the correct angles for this model.
all saw blades are sharpened to the same angle. 37° the file size you are going ot want is 1/4-3/16in.
Apr 18, 2011 | Husqvarna Garden
Saw cut is not straight. It curves until the chain freezes. Model 330 type #1 Chain saw.
This problem is caused by sharpening the chain on one side more than the other or can be caused by having the angle wrong when sharpening one side which causes one side to cut better than the other. The only solution is to get it sharpened professionally. All chainsaw users have to do this every few times we sharpen them.
Sep 06, 2010 | Sport & Outdoor - Others
What is the chain saw blade angle?
This is the angle that you cut each tooth. if you have a chain sharpener you will see numbers on it with a line directly below it. A good standard is 25 degrees, if you want it for ripping purposes you can modify the angle.
moz-screenshot-2.pngmoz-screenshot-3.pngYou really want to match the angle that the blade or chain as been set for.
I would also recommend this website. http://www.wikihow.com/Sharpen-a-Chainsaw
good luck
Apr 18, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Cuts at an angle
The sharpening of the chain is most probably not to the correct angles and not even in relation to the other teeth.
You need to sharpen the chain so all the teeth are to the same length and angle (sometimes there is a small black mark on each tooth to show you the angle and how far you can sharpen back to) . Mark where the smallest tooth is and the bring the others to the same length. Also check the rakers are at the correct height in relation to the teeth that you have just sharpened (use a depth gauge to help)
It is quite unlikely that the bar is bent but taking it off and laying it on a flat surface should tell you if it is. Check the bar for burrs and file them down if there is any.
If you are not sure about any of this then take it to a chainsaw shop and get them to sharpen the chain and check the bar for you.
Hope this helps
Mar 19, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need to know the right angle to sharpen my chainsaw
If your saw still has the original bar and chain, it was supplied with a .325" pitch chain and you'll need a 3/8" round file with a sharpening guide to properly sharpen it.
Here's a link to the Husqvarna site to the Rancher 455 models so you can select the correct manual to download, that matches your particular saw, based on the year of manufacture, etc.
There is some excellent information about maintaining your saw, along with a really good guide with step-by-step instructions for proper sharpening.
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=455&types=O
If you're having trouble figuring out the right manual for your saw, use the online Customer Support page and they'll reply.
Hope you find this Very Helpful - Best regards!
Aug 19, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Poulan 16" 38cc Gas Chain Saw P3816 Logo
346 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
