Need new pass word. Non are working - Computers & Internet
    Top Expert:
  • 10,875 Answers
Try,idontgiveinfosofixyacanhelpme
Posted on Apr 22, 2015
Vdo m5 bike computer has no speed reading . Cadence reading is fine. I replaced all new batteries. Just can't make it work, sometime display shows transport . Don't know what is that meaning ?
The computer goes into Transport Mode when it detects the bike is moving without the wheel moving (as on a car carrier) so that means the wheel sensor is not working. If you take a magnet and pass it right by the sensor several times and get no cadence count then the wire is broken or the cadence portion of the computer is non-functional. Unless it's the wire and you can fix it you need to buy a new computer.
Aug 18, 2017 | Cadence Cycling
I have an older cat eye computer. Wires. The cadence function stopped working. All other functions are good. I installed a fresh battery, I adjusted the sensor location. Still does not count cadience
Aug 16, 2017 | Cat Eye Cycling
Battery will not work either. help
Sorry you lost your Mom. As for the scale, if you made sure a new battery was correctly installed, it may have failed. Scales are a frequent failure item.
Jul 19, 2017 | Health & Beauty
Security fuse 1999 pontiac bonneville
Need a little more info . Security fuse ????? Do you mean anti-theft ? The SECURITY light is lit on the instrument cluster ? Content theft or vehicle theft ?
Vehicle Theft Deterrent (VTD) Description
Ignition Key
The ignition key for vehicles which are equipped with the PASS-Key® II system consists of the following components:
• A typical square ignition key blank
• A resistor pellet
The PASS-Key® II ignition key has the same mechanical key cuts as a non-PASS-Key® II ignition key. You can not service the key blank and resistor pellet separately. There are 15 different ignition key assemblies, each with a different key pellet resistance value.
When you service the PASS-Key® II system, obtain all ignition keys. Verify the proper key code values withJ 35628-A Interrogator.
Steering Column (Ignition) Lock Cylinder
The steering column (ignition) lock cylinder that is used with the PASS-Key® II system contains a set of electrical terminals. The terminals are used to contact the resistor in the ignition key.
The wire routing for the contacts inside the steering column is very critical. When you service the lock cylinder, maintain proper wire routing.
When you replace a steering column lock cylinder, make new keys. The new keys must match the following items:
• The PASS-Key® II code of the PASS-Key® II system
• The mechanical cut of the new steering column (ignition) lock cylinder.
Measure the resistance of the pellet on the key , go to radio shack an buy a resistor of same value an solder into wiring harness .
pulling fuse won't work , power's the PCM as well . Plus software in the PCM won't let it start if it doesn't see input signal from the Theft deterrent module .Take an get it fix right .
Feb 23, 2017 | Pontiac Cars & Trucks
How to tune up a 1995 Geo Prizm? not passing smog, They told me to tune up and get new cataylic converter, but wont guarantee it will pass smog test.
A tune is just replacing the spark plugs every 100,000 miles and the air filter every 30,000, clean oil is also a help in passing smog, the new converter is what will most likely do the trick.
Dec 28, 2016 | Geo Cars & Trucks
How to fix an air compressor on a 2000 ford expedition
compressor is non repair item, you a new one or a rebuild one good source is Arnott industries. check the solid state relay first make it works before changing compressor.
Nov 06, 2013 | Dorman 2000 Ford Expedition A/C Compressor...
I have nissan sentra b15 2001 the car starts but do not exlarate , the scaner detect the air flow sensser is bad , i got new one but now the car cranck but wont start yes i have spark
did you replace it with new one, or used one?? also have you replaced your air filter and used NISSAN only air filter. something tells me that you had non nissan/aftermarket air filter installed and that is why your air flow meter failed. you need to use nissan air filter ONLY in your model nissan. sentras do not like non nissan air filter, because non nissan filters are not coated in small amount of oil and let foreign particals / dirt go pass the filter and that will fry your $500 air flow meter.
Sep 16, 2011 | 2002 Nissan Sentra
Working principle of super heterodying receiver
you can find it easy with google, but here is how it works...the incomeing rf signal is mixed with a signal of another frequency from the local oscillator and then passes through a non linear device (semiconductor). after passing through the nonlinear device the output will contain the original frequency,the local oscillator frequency, and frequencies equal to those added together and subtracted from each other,these signals are then passed through filters to obtain only one which will be either the rf frequency plus the local oscillator frequency or the rf frequency minus the local oscillator frequency. This new frequency is then coupled to the intermediate frequency amplifier stages where most of the amplification takes place before the audio is removed and passed to the audio stages.
Jan 13, 2009 | Computers & Internet
Non working haogen wall heater
First, you'll need to check all connections going to the unit.  Often, a poor connection will blow bulbs and not allow enough current to pass for heating.  Also, check any switch external to the unit.  Use a good meter to check for resistance.  It should be nearly nil.  Be sure to do all checks with the breaker off!
Nov 14, 2008 | Fujitronic FH747RI Halogen Compact Heater
SMOG TEST
If it was originally intended for Texas, it's probably been made as a 49-state-compliant vehicle (CA has stricter emissions). To pass in CA, you may need some new parts for the truck in order to get it to pass. Or you may find that the best course of action is to sell the truck and buy a CA-emissions car.
The CA DMV may well have information available on how to get non-CA-compliant cars to pass the CA emissions testing.
Aug 25, 2008 | 1997 Nissan Pickup
Computers & Internet Logo
David Payne
David Payne
