Question about Tools & Hardware - Others
My circupool rj series shows no water and water fault
How can I reset my circu-pool salt generator? it is giving me a high salt light and a check cell light
I have a Circu-pool SJ45, no issues . Have you cleaned the cell. How old is unit. Have you checked pool salt level. Have not seen reset button, will look .
May 15, 2016 | CircuPool Swimming Pool Salt Water...
Water softener 1016182
We are going to need more information to assist you. Such as Model type: Gold series, Medallist, Silver, HE etc. and approximate age of unit. This information will either be on the back cover of the control panel or on the inside cover where you found the 1016182#.
RJ
Jul 07, 2014 | Water Dispensing & Filtration
I'm getting salt lo msg.brand new unit, brand new water, 810 pounds of salt for ten days
Have you tested for salt content in the pool. Most salt generators require between 3000 and 5000 ppm of salt for it to operate correctly. How many gallon pool? 810 pounds of salt should make it around 30,000 gallons?
Jun 30, 2014 | CircuPool Salt Water Pool System
Have a water filter by culligan ..a 01014042 ser # 0703k0196 need a user manual
This is a Medallist series water softener. Her is the link to Culligan for your owners manual.
http://www.culliganwater.com/residential/resources/timers_manuals.php
For future reference it is more helpful to provide the Model and the year it was installed.
RJ
Sep 09, 2010 | Culligan Sediment Water Filter
I have a cable modem that doesn't want to accept the RJ-45 cable (I think that's what it is called.) I've tried several different quality cables with no luck. Strange problem. Any tips?
Some RJ 45 jack cable has fault so try with another RJ 45 jack cable .. Purchase new rj 45 jack cable from nearest computer shop. There must be 2 port on modem 1 for ADSL phone line cable and otthr for LAN ethernet port means RJ 45 jack port. Try with another rj 45 jack cable it should be connect.Make sure that LAN port of modem is not faulty means make sure pins on that port are not break. Let me know if you need further assistance. Thanks for using FixYa.
Jul 24, 2010 | Computers & Internet
My Culligan Silver Series broke elecctronic panel
Unplug it for 2 minutes and plug back in, this may reset it if it is not burned out.
RJ
Feb 06, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Regeneration is nightly as oppsoed to the prrprogrammed 14 days
"DAYS00" indicates it is set to run every day. You may have lost power and it reset to factory settings. If the Gold series softener you have is the Aqua Sensor model (this is a probe in the resin tank that senses a change in the water chemistry and sends a signal to regenerate) the probe can get coated with iron and will either send NO signal or a Constant signal which will make it regen every night.
Usually a Gold series softener is either set up as metered or aqua sensor. There is an option for an override (such as 14 days) or it can be set up as a time clock model. Unplug the softener for 2 minutes and plug back in, re-program the controls to "DAY14". Make sure what the system is suppose to be set up as, Meter, AS, Time Clock.
Here is a link to Culligan for the Gold manual.
http://www.culligan.com/en/service-and-maintenance/customer-support/owners-guide/
RJ
Jan 26, 2010 | Culligan Sediment Water Filter
Modem
Technical Specifications AAL and ATM Support
VCI 0-65535 address range
VPI 0-255 address range
AAL5 support
Bridging
IEEE 802.1.d Transparent Learning Bridge (dynamic learning of up to 255 addresses)
Spanning Tree support
Certifications
FCC Part 15, Class B
CE certification
Connectors
DSL interface: RJ-11 or RJ-45 (Europe)
Ethernet interface: RJ-45
USB Type B interface (5200, 5500 series)
Diagnostic LEDs
Power, DSL, Activity, Ethernet status; USB status (5200, 5500 series)
Management
Intuitive, Web-based GUI management access
SNMP support
Comprehensive hardware diagnostics
Media Interface
RJ-11 or RJ-45 (European) DSL WAN connection
10/100Base-T RJ-45 Ethernet LAN connection
USB Type B LAN connection (5200, 5500 series)
Power
12V power supply included, 700ma max. 5400/5500 - 12 VDC, 1000ma max.
Routing
DHCP server/DHCP client
Network Address Port Translation (NAPT)
Network Address Translation (NAT)
Packet filtering
RFC 2364 Point-to-Point Protocol over ATM PVCs (PPPoA)
RFC 2516 Point-to-Point Protocol over Ethernet (PPPoE)
RFC 2684 (formerly 1483) Bridged Ethernet and routed encapsulation Routing
Standards Compliance
IEEE 802.3
USB 1.1 T1.413 issue 2 G.992.1 (G.DMT) G.992.2 (G.Lite)
Oct 15, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Tools & Hardware - Others Logo
97 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
