Question about Garden
I have a snapper s28cd curved shaft gas trimmer I purchased from wal mart and it stopped working after 2 uses ? It just won't start now , what should I check first ?
evwood
  • 50 Answers
SOURCE: Trimmer starts immediately, then stops
How old is the trimmer? If still under warranty, Sears can fix this. If not, then my experience has been the problem is a bad coil. This is due to heat build up. When the coil gets hot, it shorts out.
Posted on Dec 07, 2008
trippssmengi
  • 76 Answers
SOURCE: replace a flexible curved shaft
If you go to www.homelite.comin the red area up top click on order parts then click - click to launch homelite parts catalog, then scroll down thru agreement and click agree and then you will need to know your model number and you can get a breakdown of your trimmer wich will give you a good idea of how your machine is put together.
Posted on Jan 05, 2009
#1 Taper
  • 1040 Answers
SOURCE: Polan P1500 trimmer ideles great until i press throttle and stall
Are you taking the choke off after it starts?
Posted on May 25, 2009
SOURCE: Homelite curved shaft timmer line problem
It sounds like its a bump feed which they usually are, try turning on the machine and bump the head off the ground. If this fails to work try rewinding the line on tightly and neatly with no parts of the line crossing over as this could knot it. Quick tip most heads have a arrow pointing the direction to wind the line.
Let me know if that works.
Posted on Jan 09, 2010
  • 7 Answers
SOURCE: shaft disengages and trimmer head stops spinning
something wrong with your cintrifical force clutch . it is problably set too loose so the the shaft wont engage
Posted on May 12, 2010
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Sears & Craftsman 25cc Weedeater brand new starts but will not stay running?
Try leaving the chokey partially engaged. Operate it this way for a few minutes until the engine is thoroughly heated then move to the run position. If this does not work return it.
Aug 13, 2014 | Sears Craftsman Convertible 25cc 2 Cycle...
Weedeater and Homelite shafts interchangeable?
Just give it a try. Some different brands will interchange. I have done this with a Toro and it is still running.
May 18, 2014 | Homelite Garden
Murray m2500 won't start after one day of having it
bad coil in it, i had bought a m2500 murray weedeater from walmart .did same thing i replaced the coil. bad when you buy something from wal mart and have to get it fixxed before you can use it. now it works fine
Apr 23, 2013 | Cars & Trucks
Ryobia trimmer won't idle.
most likely to rich low speed screw try turning it in 1/8 turn it should pick up rpm then back off the idle a scoche
Apr 27, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Will not start
jerry is correct. these small machines are as tempermental as an electrical system on a car.or one that won't start. IT can be one of 5 or 6 problems. you just have to go through the thing one step at a time. I prefer do look at the cheapest thing first.and then work your way up.
Dec 06, 2011 | Craftsman 27cc 2Cycle Full Crank Curved...
Trimmer won't stay running without starter fluid
drain any old gas/fuel mixture out of unit.
purchase new gas and mix with oil as recommended for your engine.
clean the air filter on the unit.
pull the spark plug and clean with carb spray and reinstall...
you also may need to remove the carb and clean any jets with carb spray... old gas can turn into a shellac'ish type goo and foul up the works...
I recommend draining all fuel after usage...
May 29, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Troy Bilt 4CC Trimmer - starts fine but won't turn off - TB425CS
Try cleaning up the switch button with Electronics Spray - you can get it from Wal-Mart for $3.
Usually is a bad contact or could be a broken wire .
Apr 25, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Garden Logo
158 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
